Page 38 of 48 FirstFirst ... 2829303132333435363738394041424344454647 ... LastLast
Results 371 to 380 of 471
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #371
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    43
    Thanks to 2k1Toaster i will have a new version 6 fusion brain in hand very shortly. This will ensure that RRFusion will be v6 compatible by release. Also means i'll have two FBs to test with for multi-brain support.
    Live mp3Car Facebook Chat
  2. #372
    Sep 2007
    Export, PA
    good deal cause I wanna redo all my carpc wiring anyways and have the FB isolated outside of the case......its a royal PITA trying to unplug and pull all of the sensor wires out of the case.....
    that and the v6 will give me a lot more outputs per brain so for a little while i might not even NEED multibrain support
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
  3. #373
    Woodbridge, VA
    Blog Entries
    43
    Version 2.1.5 has been released. This fixes a pretty huge dummy bug for v4 brains, should solve multi-brain as well. No v6 goodness yet waiting on some work with 2k1 on that.
    ---------- Post added at 11:41 AM ---------- Previous post was at 11:40 AM ----------
    if you dont mind try 2.1.5, i can totally see why the last version couldnt connect to v4 brains now
    Quote Originally Posted by sxtnitehawk View Post
    blue is spot on.
    in the background i have timers running to monitor some key functions of the car which will later be used for electronic boost control, etc...
    once i have everything setup... i'll be monitoring throttle position sensor, map sensor, tip sensor, tach, speed, fuel level, etc... map, tip, and tach will be used to control boost levels, tach and speed to determine what gear the car is in so i can have per gear boost control settings, fuel level so i can prevent boost if i'm low on fuel, etc... all of those require timers as fast as i can get them, whether they're shown that fast on the screen or not...
    and i never see you on msn...lol
    edit:
    just checked debug:
    [2/10/2011 11:32:54 PM]Failed to initialize that Fusion Brain. Make sure it is connected and that you are specifying the correct USB VID/PID number.
    hit disconnect, got an error. unplugged that brain, plugged it back in, hit connect after reloading rr and both were found, but still no 2nd instance outputs turned on.
  4. #374
    Nov 2009
  5. #375
    Sep 2007
    Export, PA
    I just downloaded the newest release....havnt even bothered trying to use it because as soon as i went looking through the skin commands...major flaw in your ducomentation for analog input label code.....................where the heck do you specify port number?!? lol...
    I'll test everything soon enough...I'm going to have to stick with V4 brains unfortunately because they moved from 5V sensors to 3.3V sensors and I don't feel like spending a ton of money for their voltage divider boards and then have to figure out all new calculations for all of the stuff i'm monitoring.....really a shame they had to go and do that...
  6. #376
    Woodbridge, VA
    Blog Entries
    43
    you didnt bother trying because of a mistype? Couldn't have just installed the app and tried it in carwings? Or even look at the skin file? C'mon now.
    the correct label for the analog inputs is "RRFUSION_ANALOGINPUT;<Port>;<Type>". Instance in this case is assumed by the instance toggle command. I made it this way because no one's going to display all labels of all instances.
  7. #377
    Sep 2007
    Export, PA
    i was only kidding about why i hadn't tried it yet...i've been busy with other things and havnt had a chance to try it out yet...
    that's a poor assumption though man... you've effectively limited it to a single brain instance again because i cant monitor inputs on more than one brain at a time... the whole point of multi-brain support is to be able to use both brains at the same time...
    you put a lot of work in on this and i do appreciate it...but this isnt multi-brain ready. having access to outputs on all brains is useful...but without having access to all inputs as well, it's very limiting and make's multibrain support kinda useless...
    can you put in an instance selector in the label code as well?
    Also, can you make it so that the settings you have in your ini file can also be stored in skin.ini? cause i want to keep all of my settings in 1 file...
    Lemme know.
  8. #378
    Woodbridge, VA
    Blog Entries
    43
    Lemme know.
    What do you mean you cant monitor it? You can still use the threshold monitor method of monitoring an analog value. It accepts port and instance data. The only thing this prevents is displaying the data for more than one instance in skin.
    As for the .ini request, you would really want to put ALL of the settings from RRFusion_settings.xml (not an ini file anymore) into skin.ini? Have you looked at the .xml to see how incredibly confusing that would be?
  9. #379
    Sep 2007
    Export, PA
    ok.
    do i have to use your settings screen(s) to change the settings? because my skin already takes care of naming inputs and outputs as well as selecting which port is routed to what name...
  10. #380
    Sep 2007
    Export, PA
    also...while your plugin may have monitors that can read any port on any brain... i have calculations that require the same access...
    for the moment, all of my inputs are on 1 brain, but that's only because i dont have multiple brains in the car yet....
    can you please make it so i can read all inputs at the same time by adding an instance selector to the label code?
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 02:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 08:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 02:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 08:40 PM
