Page 39 of 51 FirstFirst ... 293031323334353637383940414243444546474849 ... LastLast
Results 381 to 390 of 502
Like Tree1Likes
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #381
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by sxtnitehawk View Post
    ok.
    do i have to use your settings screen(s) to change the settings? because my skin already takes care of naming inputs and outputs as well as selecting which port is routed to what name...
    If your skin takes care of it dont use my settings at all, come up with your own set of labels and supply their values through skin.ini or however else its done. There's nothing binding you to using the settings file, but it does have to exist at least for RRFusion to run.
    also...while your plugin may have monitors that can read any port on any brain... i have calculations that require the same access...
    for the moment, all of my inputs are on 1 brain, but that's only because i dont have multiple brains in the car yet....
    can you please make it so i can read all inputs at the same time by adding an instance selector to the label code?
    The next time i work on RRFusion, probably at the point that i start working with the v6 brain, i'll add it in.
    Live mp3Car Facebook Chat
  2. #382
    Jul 2005
    Gday Sonic.
    Is just like to take this opportunity to thank you for all the time uve put into this plugin! this has made my life so much easier and couldn't have achieved what i have thus far without your help! so thanks!
    As far as my question i basically just created a quick video to explain what i want todo, i cant really find any information or explanations on how to acheive if then else statements or similiar to trigger relays and halt relays... if you could maybe link me to info? or maybe you can enlighten me here on the basics and i can try and nut this one out..
    Thanks for your help..
    The video:
  3. #383
    Sep 2007
    Export, PA
    to do IF...THEN...ELSE statements in RR, use the RRExtended plugin and use teh BYVAR, BYRANGE, and BYIND commands. I use these quite often in my skin to do some pretty trick stuff
    From what i can see you're doing, you're going to have 4 sensors tell you the air pressure inside each bag, correct? The way I would do this, is have the FULL button turn on your outputs for the pumps/solenoids/whatever, then create a timer (also in RRExtended) that will shut off the outputs when the inputs read a certain level. its a pretty simple setup and I use very similar commands for my own stuff...
    Any idea if you can/will add the instance modifier to the label code? I really need to be able to access all of the inputs at the same time without using the monitors you give us because my stuff works on its own calculations and timers and such...
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
  4. #384
    Jul 2005
    im not really sure what the instance modifier is or how to implement it nitehawk, i thankyou for pointing me in the right direction, alot of this is new to me so its hard to grasp the way the skins interact and are coded, im used to php code.. so this is totally new to me, any more guidance would be appreciated for sure.
    i know what im trying to acheive is very easy im just not sure on how i can get it done.
  5. #385
    Jul 2005
    ok so i think i have my head around the BYRANGE, i think the newest version of that plugin has different names from what u mentioned.
    but im not quite getting how i can set up the timers? or how they work.?
    wouldnt i need to loop the function?
    EDIT:
    Ok so i played alot here and learning as i go.. i have come up with this but im sure this isnt the most efficient way of doing this so it someone could enlighten me, that would be nice.. heres what i have which in my mind does some things i want but not all.
    "FULL","GblTmr_Add;Tmr2;1;FILL"
    "FILL","BYRANGE;rearright;0;190;RUNFULL<<NULL<<Gbl Tmr_Del;Tmr2"
    "RUNFULL","BAG5||BAG6||BAG7||BAG8"
    "BAG5","RRFUSION_DIGITALOUTPUTSWITCH;$MYFBINSTANCE $;5;1"
    "BAG6","RRFUSION_DIGITALOUTPUTSWITCH;$MYFBINSTANCE $;6;1"
    "BAG7","RRFUSION_DIGITALOUTPUTSWITCH;$MYFBINSTANCE $;7;1"
    "BAG8","RRFUSION_DIGITALOUTPUTSWITCH;$MYFBINSTANCE $;8;1"
    Ok 'FULL' is called off the button press, once run if the 'Rear Right' airbag sensor reads between 0-190 PSI, it will run 'RUNFULL' which opens all 4 solenoids to fill all the air bags for one complete second, then it loops, untill it reachs 190psi then it deletes the timer..
    now a few things here,
    * i would want it to check all 4 sensors, so i would make 4 of these blocks and call all four off the button press? if i did this each would only open one solenoid each as it only checks one airbag sensor.
    secondly, i would like it to just hold a function until 190psi is met then shut it off, instead of a 1 second flutter for an amount of time, which can take upto 10mins to fill all 4?
    Thanks for your help guys, im starting to get my head around this more.
    Ryann,
  6. #386
    Sep 2007
    Export, PA
    "FillBags","AllOn||SetTimers"
    "AllOn","BAG5||BAG6||BAG7||BAG8"
    "BAG5","RRFUSION_DIGITALOUTPUTSWITCH;$MYFBINST ANCE $;5;1"
    "BAG6","RRFUSION_DIGITALOUTPUTSWITCH;$MYFBINST ANCE $;6;1"
    "BAG7","RRFUSION_DIGITALOUTPUTSWITCH;$MYFBINST ANCE $;7;1"
    "BAG8","RRFUSION_DIGITALOUTPUTSWITCH;$MYFBINST ANCE $;8;1"
    "SetTimers","Btimer1||Btimer2||Btimer3||Btimer 4"
    "Btimer1","GblTmr_Add;Timer1;.25;CHECKFILLED1"
    "Btimer2","GblTmr_Add;Timer2;.25;CHECKFILLED2"
    "Btimer3","GblTmr_Add;Timer3;.25;CHECKFILLED3"
    "Btimer4","GblTmr_Add;Timer4;.25;CHECKFILLED4"
    "CHECKFILLED1","BYRANGE;RFBAG;0;190;<< <<BAG5OFF"
    "CHECKFILLED2","BYRANGE;RRBAG;0;190;<< <<BAG6OFF"
    "CHECKFILLED3","BYRANGE;LFBAG;0;190;<< <<BAG7OFF"
    "CHECKFILLED4","BYRANGE;LRBAG;0;190;<< <<BAG8OFF"
    "BAG5OFF","GblTmr_DEL;Timer1||RRFUSION_DIGITALOUTP UTSWITCH;$MYFBINSTANCE $;5;1"
    "BAG6OFF","GblTmr_DEL;Timer2||RRFUSION_DIGITALOUTP UTSWITCH;$MYFBINSTANCE $;6;1"
    "BAG7OFF","GblTmr_DEL;Timer3||RRFUSION_DIGITALOUTP UTSWITCH;$MYFBINSTANCE $;7;1"
    "BAG8OFF","GblTmr_DEL;Timer4||RRFUSION_DIGITALOUTP UTSWITCH;$MYFBINSTANCE $;8;1"
    Now granted, this can be done a little bit better, but i threw all that together just from memory as i dont have any documentation in front of me at the moment...
    What this does it is turns on all of the bag ouputs, then creates timers to monitor the pressures, when each monitor sees the correct pressure (measured at 0.25second intervals to prevent overpressurizing), it will delete the timer and turn the output off again.
    You can simplify it even more using some other variables and such to help cut the BAGOFF down to 1 command, and i would also advise using the HOLD and RELEASE functions in RRFusion instead of just SWITCH, but i dont have documentation in front of me so i cant begin to tell you what the syntax is... HOLD turns an output on, and RELEASE turns an output off...
    Hope this helps
  7. #387
    Jul 2005
    Thankyou so very much i cant wait to check this out in detail tomorow!
  8. #388
    Jul 2005
    Ok so another couple of hours gone and ive stumbled across a problem..
    i have all 3 buttons coded now, but ill chase an answer for the 'FULL' and 'LAYED' button problem and i think i should be able to fix the "RIDE' button after that myself, id hope. ok
    So in the function BYRANGE, ive been putting in test numbers instead of feeding in the PSI readings because i have all this inside and away from the vehicle.. now with test numbers inserted they always work flawlessly the first button click, its any other button click after that it seems to die. now im thinking i need to reset variables somewere on button click... i have it currently closing all fusion brain relays before attempting to test and run a new button click. but it seems i think having problems with BYRANGE.. can anyone look at this and figure it out? do you think its me feeding in fixed numbers? and not reading from the label?
    Please note, the code had been changed since the video recording... to only turn on the instances once its checked the BYRANGE, as before it was turning on instances first then checking the pressures.
    "fb1r","RRFUSION_DIGITALOUTPUTRELEASE;$MYFBINSTANC E$;1"
    "fb2r","RRFUSION_DIGITALOUTPUTRELEASE;$MYFBINSTANC E$;2"
    "fb3r","RRFUSION_DIGITALOUTPUTRELEASE;$MYFBINSTANC E$;3"
    "fb4r","RRFUSION_DIGITALOUTPUTRELEASE;$MYFBINSTANC E$;4"
    "fb5r","RRFUSION_DIGITALOUTPUTRELEASE;$MYFBINSTANC E$;5"
    "fb6r","RRFUSION_DIGITALOUTPUTRELEASE;$MYFBINSTANC E$;6"
    "fb7r","RRFUSION_DIGITALOUTPUTRELEASE;$MYFBINSTANC E$;7"
    "fb8r","RRFUSION_DIGITALOUTPUTRELEASE;$MYFBINSTANC E$;8"
    "fb1h","RRFUSION_DIGITALOUTPUTHOLD;$MYFBINSTANCE$; 1"
    "fb2h","RRFUSION_DIGITALOUTPUTHOLD;$MYFBINSTANCE$; 2"
    "fb3h","RRFUSION_DIGITALOUTPUTHOLD;$MYFBINSTANCE$; 3"
    "fb4h","RRFUSION_DIGITALOUTPUTHOLD;$MYFBINSTANCE$; 4"
    "fb5h","RRFUSION_DIGITALOUTPUTHOLD;$MYFBINSTANCE$; 5"
    "fb6h","RRFUSION_DIGITALOUTPUTHOLD;$MYFBINSTANCE$; 6"
    "fb7h","RRFUSION_DIGITALOUTPUTHOLD;$MYFBINSTANCE$; 7"
    "fb8h","RRFUSION_DIGITALOUTPUTHOLD;$MYFBINSTANCE$; 8"
    /, LAYED BUTTON __________________________________________________ ________________________
    "LAYED","RELEASE1||SETTIMERS1"
    "RELEASE1","||BAG5OFF||BAG6OFF||BAG7OFF||BAG8O FF"
    "SETTIMERS1","Btimer1||Btimer2||Btimer3||Btime r4"
    "Btimer1","GblTmr_Add;Timer1;.20;CHECKFILLED1"
    "Btimer2","GblTmr_Add;Timer2;.20;CHECKFILLED2"
    "Btimer3","GblTmr_Add;Timer3;.20;CHECKFILLED3"
    "Btimer4","GblTmr_Add;Timer4;.20;CHECKFILLED4"
    "CHECKFILLED1","BYRANGE;15;10;200;fb1h<<BAG1OFF<<N ULL"
    "CHECKFILLED2","BYRANGE;5;10;200;fb2h<<BAG2OFF<<NU LL"
    "CHECKFILLED3","BYRANGE;91;10;200;fb3h<<BAG3OFF<<N ULL"
    "CHECKFILLED4","BYRANGE;5;10;200;fb4h<<BAG4OFF<<NU LL"
    "BAG1OFF","GblTmr_DEL;Timer1||fb1r"
    "BAG2OFF","GblTmr_DEL;Timer2||fb2r"
    "BAG3OFF","GblTmr_DEL;Timer3||fb3r"
    "BAG4OFF","GblTmr_DEL;Timer4||fb4r"
    /, FULL BUTTON __________________________________________________ _________________________
    "FULL","RELEASE2||SETTIMERS2"
    "RELEASE2","||BAG1OFF||BAG2OFF||BAG3OFF||BAG4O FF"
    "SETTIMERS2","Btimer5||Btimer6||Btimer7||Btime r8"
    "Btimer5","GblTmr_Add;Timer5;.20;CHECKFILLED5"
    "Btimer6","GblTmr_Add;Timer6;.20;CHECKFILLED6"
    "Btimer7","GblTmr_Add;Timer7;.20;CHECKFILLED7"
    "Btimer8","GblTmr_Add;Timer8;.20;CHECKFILLED8"
    "CHECKFILLED5","BYRANGE;189;0;190;fb5h<<NULL<<BAG5 OFF"
    "CHECKFILLED6","BYRANGE;189;0;190;fb6h<<NULL<<BAG6 OFF"
    "CHECKFILLED7","BYRANGE;195;0;190;fb7h<<NULL<<BAG7 OFF"
    "CHECKFILLED8","BYRANGE;195;0;190;fb8h<<NULL<<BAG8 OFF"
    "BAG5OFF","GblTmr_DEL;Timer5||fb5r"
    "BAG6OFF","GblTmr_DEL;Timer6||fb6r"
    "BAG7OFF","GblTmr_DEL;Timer7||fb7r"
    "BAG8OFF","GblTmr_DEL;Timer8||fb8r"
    Another video also.
  9. #389
    Woodbridge, VA
    Blog Entries
    55
    I honestly wish i could help but all that "RR syntax" i'll never understand lol. If it boils down to an RRFusion problem i'll work with you to solve it.
  10. #390
    Jul 2005
    hopefully somebody can chime in. thanks sonic
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
