Page 43 of 51 FirstFirst ... 33343536373839404142434445464748495051 LastLast
Results 421 to 430 of 502
Like Tree1Likes
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #421
    Feb 2012
    Chattanooga, TN
    I am looking at getting Fusion Brain and connecting it to a carputer to display gauges for very sensors like boost Air Fuel ratio and other things like that. My question is I read that RR updates once every second but then read a few pages back that the screen refresh rate for RR was 100ms or 1/10th of a second which would be acceptable but I would really like something a little faster is that even possible?
  2. #422
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by sdhsbaseball View Post
    RR's refresh rate can be manipulated on a per screen basis for faster updates. It's definitely possible, but I don't know how specifically to configure it. I'm sure its somewhere in the documentation.
    Live mp3Car Facebook Chat
  3. #423
    Feb 2012
    Chattanooga, TN
    After reading a bunch of threads on creating flash gauges I have a few questions that I hope people can answer. I have created and attached one gauge so far and I feel like if I can completely understand what all goes into creating one gauge the rest should be easy as pie. But I do have a few questions
    • I know that the gauge says boost on it but for understanding what is all going on I would like to be able to just have it read in cpu temp or cpu usage or just any input that I can use or simulate to understand how everything works until my fusion brain gets here.
    • With that being said if I want to take a input between 0-3.3v for the fusion brain how do I convert that to a number, do i do that when im creating the flash gauge in swish or when Im imputing it into RR?
    • Also is it better to create gauges in flash or swish?
    Large_Boost_Gauge.swf
  4. #424
    Feb 2012
    Chattanooga, TN
    Anybody???
  5. #425
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Is anyone successfully using the latest version of this plugin with a v1 brain? I recently tried to upgrade everything on my system and with the latest version I could connect fine, but every time I toggled a digital output on it would not stay on constantly. Just wondering if the error is on my end or an incompatibility with the original brain firmware.
    Thanks.
  6. #426
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by mezz64 View Post
    Thanks.
    v1 brain? I didnt think they mass produced the v1, they selling at version 3. And I still have my v3 installed in the car using RRFusion everyday.
  7. #427
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by Sonicxtacy02 View Post
    Perhaps not a v1, but the first publicly available version, whatever that may be. I keep having to go back to an older version of the plugin because the new one (both on RR and CF) just continually toggles my digital outputs on/off when I try to turn one on. I'm going to do a test with a fresh RR install on an old laptop and see what happens. That should narrow it down.
  8. #428
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    So after testing on the laptop I see the same behavior. Out of curiosity what timer interval do you use for send/receive and what value do you use for shutoff time (time=1.2^x) when communicating with a v3 brain?
    I've been playing with my own plugin solution based on mx270a's work and the low level info document for a v3 brain and while it's significantly better (as far as the connection) than the current version of this plugin it still drops out occasionally. As far as I can tell mx270a's program uses 0 for the shutoff time and I haven't had a chance to test with a higher number yet to see if it fixes my problem.
  9. #429
    Woodbridge, VA
    Blog Entries
    55
    My v3 code is identical to mx270a's work way back when. And the interval used by default is 1 second, but it can be adjusted in the rrfusion_settings.xml file. I'm away from my dev machine with RRFusion until monday but i can share the read/write code with you then. Kinda odd that i'm using a v3 in the car and have been for years but some people (not just you) have this same issue.
  10. #430
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    The solution to my problems lied entirely in the shutoff time interval. I increased that to close to a minute (Probably doesn't need to be that high) and everything has been working great since using my kang of mx270a's code converted into a plugin.
    I don't really see any negatives to having the timeout value set that high since as soon as the carpc hibernates the fusion brain looses power and everything turns off anyway.
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
