Page 5 of 42 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 420
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #41
    FLAC -zip-'s Avatar
    Ontario/Canada
    Hi Sonic, sent you a PM.
    Sound Stage
    Eclipse|MTX|Infinity
  2. #42
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    hmm i havent seen anything yet???
    Live mp3Car Facebook Chat
  3. #43
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Sorry Sonic! I have not yet been able to test it. I grabbed it off the shelf, and realized I do not have a wall wart here to power it. It's been crazy here, and will try to get out to rat shack or something to pick one up here in the next day or so.
    My Fiero Build Thread
  4. #44
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    I'll be try'n it out tonight hopefully or early tomorrow. Working an off shift this evening.
  5. #45
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Problem...
    Where is it looking exactly for the vid/pid device #? I have all the correct drvs installed as I can control it using the FB SW.
    Upon clicking the connect button, I get this message:
    Code:
    VID/PID for device #0 not found in the registry.
    Are the Fusion Brain drivers loaded?  = Yes
    Is a Fusion Brain connected? = Yes
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #46
    Woodbridge, VA
    Blog Entries
    32
    i know i already told you the answer blue via msn.... but for everyone else it reads the registry entry HKEY\LOCAL MACHINE\SYSTEM\CURRENTCONTROLSET\ENUM\WINUSB. inside this entry there is a key named 0 and the value is the device instance of your fusion brain. if you go to that entry and dont see a 0 key simple add a string value, name it 0 and enter your device instance as the value
  7. #47
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I did get this work, the prob was you need to be using the latest FB hardware drivers.
    After that it worked.
    Some things that I observed while messing with it.
    #1 On a reloadskin command it should set the outputs to their previous setting, as of current version it sets them all off.
    #2 Like above but when its first connected, have a way to set the outputs at startup. Like if I always want #3 output on when connecting
    #3 Set some permanent defaults so that it should always work, even if user forgets a setting.
    Overall... Its a great start... looking forward to see future improvements.
    Are you at some stage planning on releasing the source? Just curious...no biggie if not.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #48
    Woodbridge, VA
    Blog Entries
    32
    you can set the ports at startup.... you simply add the toggle commands to ONSKINLOAD. Keeping the settings is possible though i guess. Permanent defaults will be added as well in final release.
    as for the source... once the final version is done i'll clean it up and release it i spose.
  9. #49
    Woodbridge, VA
    Blog Entries
    32
    ok i got positive feedback from 3 people now.. and i've since made the improvements blue suggested. There is now a command to save the FB digital output settings to a text file that is automatically read when rr is loaded. this will also solve any hibernation issues with simple additions to exectbl.ini( just add FBSAVE on suspend and FBRESUME on resume).
    There is one remaining issue looming which i can not test until my 2nd FB is shipped.. and thats of course how to integrate 2 or more fbs into the plugin. 2k1toaster has layed out the guidelines on how to get it to work but due to my noobish programming skills i cant implement til i can test..alot lol.
    so should i release a new beta? it'll be basically the final "single" fb version with all features tested working.
  10. #50
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Uh... that would be a good idea, to dbl check if there are no other issues that you might have induced after adding said improvements..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
