Page 4 of 22 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 217
Thread: RRTubeEx [Youtube Plugin]
  1. #31
    Nov 2004
    St Louis
    Quote Originally Posted by EL CAMINO View Post
    ohhhh, i see now, that means we might have to read those values from an ini like before, or from skin.ini, what you think is better? i'll vote for skin.ini.
    Skin.ini works for me cause I run three different primary skins and that way I can have it sized exactly for each since they're not the same.
    OBTW, I'm working on an RRcode section for the EXECtbl.ini that will automatically switch TRACKNAME and AlbumART in the menuXXX.skins for this plugin, I am stumped by one issue right now that has to do with how you stop the audio when starting the uTube playing. It works fine if RRTube is run from audio, but if its run from FM, the FM isn't muted. Have you considered using the mute command instead - that should work with all audio sources.
  2. #32
    Dec 2007
    El, when searched, i get -1, subscript used with nn-array variable... Not all the time but almost half the time... Any clue?
  3. #33
    Dec 2007
    El, how about a button for list of files you saved/downloaded. I understand you can access them from video, but would be nice to play them inside rrtube skin...
  4. #34
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    Quote Originally Posted by brandensin View Post
    can you tell me what was that search that give you that error?
  5. #35
    EL CAMINO's Avatar
    Jul 2005
    Quote Originally Posted by GizmoQ View Post
    try this version, and let me know how it goes. as for the radio issue, i'll see what i can do.
    Attached Files Attached Files
  6. #36
    EL CAMINO's Avatar
    Jul 2005
    yes why not.
  7. #37
    Dec 2007
    "mariah carey" or "mariah" Not sure if its search word related.. I think i got some results using the same words.. Just don't seem to work consistently
  8. #38
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Was any of the stuff over at Open Pandora helpful in writing your plugin? http://openpandora.googlepages.com/
    I love Pandora and use it in my car all the time. I actually use the open pandora window right now because it is so simple.
  9. #39
    EL CAMINO's Avatar
    Jul 2005
    i did a pandora plugin as well some time ago, it is included in my dead skin(polaris) for RRtube i did some research in youtube's api and thanks to pandoras plugin legacy, it was fairly easy to put this together, i was planning to use a flash based controller, but the way RR handles flash, might be useless in most CarPc. so i went this route, thanks for the link i will take a look and see if i can ge something out of it.
  10. #40
    Dec 2007
    i found this, "E.m. Youtube Video Tool" It's working awsome so far.. multiple download and very fast... I've downloaded a tons of music video last 30 min...
  1. Replies: 15
    Last Post: 12-04-2009, 04:47 PM
