Page 10 of 16 FirstFirst 12345678910111213141516 LastLast
Results 91 to 100 of 153
Thread: RRPDC - RoadRunner park distance control extension plugin
  1. #91
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    just tried to install this
    did the regserv thing but the config util does not lunch and there is no item added to the menu
    installed as instructed... menu.skin attached
    the RRPDC-1.30 folder is in C:\Programmer\RideRunner\Plugins
    the only thing i could not figure for sure is where the skin folder should go, for now i copied the skin folder to C:\Programmer\RideRunner\Skins\Carwings_Dynamic_Lite\Plugins\RRPDC-1.30
    Attached Files Attached Files
  2. #92
    Oct 2008
    Odense, Denmark
    did manage to launch the config tool... but still no menu item in RR
  3. #93
    Oct 2008
    Odense, Denmark
    i got hold of everything except how do you force it to use either the front or back cam? is that done on the basis of the distance?
    could be nice with a short utube video showing that or some screenshoots, not only for me but for other users as well
    i guess that when in reverse it will stick to the rear cam no matter what the front distance shows
  4. #94
    Oct 2008
    Odense, Denmark
    *BUMP*
    how is the change from rear to front made?
  5. #95
    Oct 2008
    Odense, Denmark
    *BUMP*
    got my cam today... and still have thoughts about a cam in front, not only for parking but also for night vission
    but the first page says that the plugin works when you go in reverse gear, but that does not quite add up with the screen shots for the config util that says its based on distance..
    so far i have figured that the kit dejan makes has to be powered all the time, but will the plugin show distance for both front and rear at the same time? or does it switch automatic?
    lets say you are between 2 walls with 10 meters between and the car is 5 meters.. that leaves 2,5 meters at both ends when excatly half way between the walls... now as i go forward and break the setting of 2 meters it should show the distance for the front... but how about image? and now if i reverse it will show the distance to the back when i go less than 2 meters and it will show the rear cam ( as you can set what cam to use for the rear )
    a small "for dummies guide" could be usefull
  6. #96
    Oct 2008
    Odense, Denmark
    another cool feature to this would be guidelines that is put on top of the picture to assist judgement if the car would fit where you have in mind parking
  7. #97
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Quote Originally Posted by joey4 View Post
    can this be used on centrafuse (i assume the answer is no, if thats the case then is there a plugin like this for centrafuse)
    Quote Originally Posted by Enforcer View Post
    No.
    Yes.
    What is the plugin that is like this for Centrafuse?
    No way to port this one to Centrafuse?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  8. #98
  9. #99
    Oct 2003
    Poland, OH
    Thanks a lot.
  10. #100
    Jun 2007
    Hi Robby, i've to ask you one things....
    in your opinion, is possible use your plugin and connect this camera to my carputer on my vw golf ???
    http://cgi.ebay.de/VW-Heckklappenoef...d=p3286.c0.m14
    is the original backup camera, but i don't know the video how is sent (pal, ntsc ecc) ....
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 02-24-2013, 06:59 AM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 06:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 06:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 10:27 AM
