Page 11 of 16 FirstFirst ... 2345678910111213141516 LastLast
Results 101 to 110 of 153
Thread: RRPDC - RoadRunner park distance control extension plugin
  1. #101
    Jun 2007
    robby, i've done my skin to embed the video from my cinergy 600 by 1 button, but i think there's somethings wrong...
    if i was playing music with player....all is ok....i go into the pdc skin, i see the video ecc...and the music don't stop....
    BUT
    if i was playing the radio (always cinergy 600), when i'll go to the pdc skin, the radio stops...and if i want listen something, i've to click the next button....
    same when i'll go back from the pdc skin... if i'm listening the radio....the radio stops again and i've to click some player buttons...(next ecc...) to hear it...
    is correct?? or there's a bug???
  2. #102
    Mar 2005
    Great looking plugin ! But I noticed it was missing a swedish translation so, here it comes.
    Attached Files Attached Files
  3. #103
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    when i try to enable my backupcam in config i get this:
    and when i then save and rerun the config i get this:
    my ini for the moment:
    [UNITS OF MEASUREMENT]
    DistanceUnit=0
    [AUDIO SETTINGS]
    PausePlayer=False
    ChangeVolume=False
    VolumeLevel=10
    [VIDEO SETTINGS]
    VideoEnabled=True
    VideoDevice=0
    VideoInput=0
    VideoStandard=AnalogVideo_None
    [SKIN SETTINGS]
    AutoStartDelay=0
    AutoExitDelay=5
    FrontEnabled=False
    AutoStartDistance=100
    [CONFIGTOOL LOCALIZATION]
    Language=0
    any idea what could cause the error?
  4. #104
    Oct 2007
    hello
    RR with the new vers. of 02-12-09 it doesn't load the image in the window of the skin PDC....
    when I activate the config the image is visible....
    help me
    hi and thanks
  5. #105
    Dec 2009
    roadrunner park distance control
    Hi can you explain more specific... how you get it to work? where the files should be copyed or moved to?? wich folders?
    I have downloaded the RRPDC that is listed... but I canīt figer it out..?
    please help?
    Iīm using the Igobmw skin on RR, and IbusRR interface
  6. #106
    Oct 2007
    rrpdc
    hi
    I have realized a home puter with monitor touch from 15."...I have integrated pdc in an only skin with the commands for k8055...
    if you want I anticipate you an image of the skin and send to you at PM the files menu.skin and pdc.skin....
    the folder rrpdc is inside c:/program/riderunner/plugins
    ammerelli
  7. #107
    Oct 2008
    Odense, Denmark
    has any tried to fit sensors at oth front and back and can post a screenshot when going forward against something and the same for reverse....
    Blessed are the "cracked" for it is they who let in the light.
  8. #108
    Oct 2007
    skin pdc
    hi..
    these are my 2 files of the skins menu.skin and pdc.skin....
    ammerelli
  9. #109
    Dec 2009
    Hi! is there anyone that has managed to get RRPDC to work with the "igobmwskin"
    or just post step by step how to install rrpdc??
    Iīve read all this forum and i canīt find out where to put all the files... and what has to be changed..?
  10. #110
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Did you read the 1st post?
    How to install:
    Copy the files provided in the RoadRunner folder (or better, in the PLUGINS folder) and the skin files in your favorite skin folder (you can also use the skin provided (that is part of my BMW-E36 skin) as a guideline to develop your own skin.
    Register the DLL, from a command prompt type: regsvr32 <your plugin path>\RRPDC.dll
    Add in your "MENU.SKIN" the command "X,RRPDC".
    Launch the tool “RRPDC Config” and set all the stuff.
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 02-24-2013, 06:59 AM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 06:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 06:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 10:27 AM
