Page 15 of 16 FirstFirst ... 5678910111213141516 LastLast
Results 141 to 150 of 153
Thread: RRPDC - RoadRunner park distance control extension plugin
  1. #141
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    Are I the only one with this issue? ie it will not load in RR
    Blessed are the "cracked" for it is they who let in the light.
  2. #142
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by boelle View Post
    i have trouble getting the plugin to load in rr.... i'm running win7
    robby's tms plugin is working fine
    i have tried to install vb6 runtime but no luck... also trying to port it to .net but it complains about xvideo license
    The whole plugin doesn't load or just the video?
    post a debug from RR.
  3. #143
    Oct 2008
    Odense, Denmark
    Whole plugin
    04-06-2011 21:44:00: Plugin Manager: Plugin Found: RRPDC plugin found but will be unable to create (most likely NOT registered)[skipped].
    and i tried to create a reg.bat that i run as admin... did not help..
    funny thing is that the config tool can show the video, also both my video usb dongle and the pdc hardware have drivers loaded and working in win7 (no error in device mangager).
  4. #144
    Oct 2008
    Odense, Denmark
    rrpdc was only mentioned on that single line so that's why i figured it would not make sense to post more than the single line... if whole debug file is required i can post it
  5. #145
    Oct 2008
    Odense, Denmark
    04-06-2011 21:43:32: Start -- Version: 24-05-2011
    04-06-2011 21:43:32: OS Type: Windows 7
    04-06-2011 21:43:32: FileManager: FileMode = Profile
    04-06-2011 21:43:32: FileManager: mypath = C:\Program Files\RideRunner\
    04-06-2011 21:43:32: FileManager: ProfilePath = C:\Users\-BO-\Documents\RideRunner\
    04-06-2011 21:43:33: Start Sequence: Starting Player...
    04-06-2011 21:43:33: PLAYER: Initialization creating object
    04-06-2011 21:43:35: PLAYER: Started
    04-06-2011 21:43:35: PLAYER: BASSRR Version: ( 2.4 )
    04-06-2011 21:43:35: PLAYER: Restored rrpl.m3u8
    04-06-2011 21:43:35: PLAYER: Initialization complete
    04-06-2011 21:43:35: Start Sequence: Starting Radio Device...
    04-06-2011 21:43:35: Start Sequence: Starting Serial Devices...
    04-06-2011 21:43:35: Start Sequence: Starting Mixer...
    04-06-2011 21:43:35: VMC---> Set object successful
    04-06-2011 21:43:35: VMC---> SOURCE: Mixer line #1: "Speakers"
    04-06-2011 21:43:35: Start Sequence: Starting Speech...
    04-06-2011 21:43:39: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
    04-06-2011 21:43:39: No Phidgets interface detected.
    04-06-2011 21:43:39: Plugin Manager: loading Global Plugins...
    04-06-2011 21:43:41: Plugin Manager: Plugin Found: BASSRR
    04-06-2011 21:43:41: Plugin Manager: Plugin loaded (Global): BASSRR
    04-06-2011 21:43:58: Plugin Manager: Warning loading BASSRR (Attempt load more then once, most likely duped in globals and/or in skin).
    04-06-2011 21:44:00: Plugin Manager: Plugin Found: RRTMS
    04-06-2011 21:44:00: Plugin Manager: Plugin loaded (Global): RRTMS
    04-06-2011 21:44:00: Plugin Manager: Warning Plugin RRTMS does not support Enabled Method
    04-06-2011 21:44:00: Plugin Manager: Warning Plugin RRTMS does not support Initialize Method
    04-06-2011 21:44:00: Plugin Manager: Warning Plugin RRTMS does not support Properties Method
    04-06-2011 21:44:00: Plugin Manager: Plugin Found: SkinTool
    04-06-2011 21:44:00: Plugin Manager: Plugin loaded (Global): SkinTool
    04-06-2011 21:44:00: Plugin Manager: Plugin Found: Weather
    04-06-2011 21:44:00: Plugin Manager: Plugin loaded (Global): Weather
    04-06-2011 21:44:02: Plugin Manager: loading Global Plugins Completed.
    04-06-2011 21:44:02: LoadSkin: C:\Users\-BO-\Documents\RideRunner\Skins\Genesis\
    04-06-2011 21:44:02: Plugin Manager: loading SkinDir Plugins...
    04-06-2011 21:44:05: Plugin Manager: Plugin Found: Genesis(.NET)
    04-06-2011 21:44:05: Plugin Manager: Plugin loaded (SkinDir): Genesis
    04-06-2011 21:44:06: Plugin Manager: loading SkinDir Plugins Completed.
    04-06-2011 21:44:09: Enter Exec: False, menu.skin, "ONRESTORED", False
    04-06-2011 21:44:09: Que Exec: True, menu.skin, "ONRESTORED", False
    04-06-2011 21:44:09: Executing: ONRESTORED
    04-06-2011 21:44:09: Que Exec: True, menu.skin, "*BASS_ONDBBUILD", False
    04-06-2011 21:44:09: EXECTBL Translation: *BASS_ONDBBUILD -> SETVAR;CONFIRMLABEL1;!!!Building Database!!!
    04-06-2011 21:44:09: Executing: SETVAR;CONFIRMLABEL1;!!!Building Database!!!
    04-06-2011 21:44:09: Que Exec: True, menu.skin, "*BASS_ONDBBUILDDONE", False
    04-06-2011 21:44:09: EXECTBL Translation: *BASS_ONDBBUILDDONE -> SETVAR;CONFIRMLABEL1;Database Complete||Wait;3||SETVAR;CONFIRMLABEL1;
    04-06-2011 21:44:09: Executing: SETVAR;CONFIRMLABEL1;Database Complete
    04-06-2011 21:44:09: Que Exec: True, menu.skin, "Wait;3||SETVAR;CONFIRMLABEL1;", False
    04-06-2011 21:44:09: Executing: Wait;3
    04-06-2011 21:44:10: Enter Exec: True, menu.skin, , False
    04-06-2011 21:44:11: Enter Exec: True, menu.skin, , False
    04-06-2011 21:44:12: Enter Exec: True, menu.skin, , False
    04-06-2011 21:44:13: Enter Exec: True, menu.skin, , False
    04-06-2011 21:44:13: Que Exec: True, menu.skin, "SETVAR;CONFIRMLABEL1;", False
    04-06-2011 21:44:13: Executing: SETVAR;CONFIRMLABEL1;
    04-06-2011 21:44:13: Que Exec: True, menu.skin, "ONSTART", False
    04-06-2011 21:44:13: Que Exec: True, menu.skin, "ONLINE", False
    04-06-2011 21:44:13: Leave Exec: False, menu.skin, ONLINE, False
    04-06-2011 21:44:13: Global Hotkey: Successfully registered keycode:2112
    04-06-2011 21:44:14: CheckResume: ResumeMusic=0 WasRadio=0
    04-06-2011 21:44:14: AudPlayerStart: music player: PLPosition=0 TrackPosition=-11
    04-06-2011 21:44:14: AudPlayerStart: player volume be 0: 0
    04-06-2011 21:44:14: AudPlayerStart: player should be playing: PLAYING
    04-06-2011 21:44:14: AudPlayerStart: Player.GetTrackLength: 195264
    04-06-2011 21:44:14: CheckResume: Resuming to music player: PAUSED
    04-06-2011 21:44:14: Enter Exec: False, menu.skin, , False
    04-06-2011 21:44:14: Que Exec: True, menu.skin, "ONSKINSTART", False
    04-06-2011 21:44:16: EXECTBL Translation: ONSKINSTART -> 1STRUN
    04-06-2011 21:44:17: Executing: 1STRUN
    04-06-2011 21:44:17: Command not executed: 1STRUN
    04-06-2011 21:44:17: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
    04-06-2011 21:44:17: Executing: ONCOMMANDINVALID
    04-06-2011 21:44:17: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
    04-06-2011 21:44:17: Leave Exec: False, menu.skin, ONSOURCECHANGE, False
    04-06-2011 21:44:17: Enter Exec: False, menu.skin, , False
    04-06-2011 21:44:17: Que Exec: True, menu.skin, "ONSONGSTART", False
    04-06-2011 21:44:17: Leave Exec: False, menu.skin, ONSONGSTART, False
    04-06-2011 21:44:19: Enter Exec: False, menu.skin, "ONBTNPRESS||ExitMenu", False
    04-06-2011 21:44:19: Que Exec: True, menu.skin, "ONBTNPRESS||ExitMenu", False
    04-06-2011 21:44:19: EXECTBL Translation: ONBTNPRESS -> PLAYSOUND;$SKINPATH$ButtonPress.wav
    04-06-2011 21:44:19: Executing: PLAYSOUND;C:\Users\-BO-\Documents\RideRunner\Skins\Genesis\ButtonPress.wav
    04-06-2011 21:44:19: Que Exec: True, menu.skin, "ExitMenu", False
    04-06-2011 21:44:19: Executing: ExitMenu
    04-06-2011 21:44:20: Que Exec: True, exit_menu.skin, "ONSCREENCHANGE", False
    04-06-2011 21:44:20: Leave Exec: False, exit_menu.skin, ONSCREENCHANGE, False
    04-06-2011 21:44:23: Enter Exec: False, exit_menu.skin, "ONBTNPRESS||QUIT", False
    04-06-2011 21:44:23: Que Exec: True, exit_menu.skin, "ONBTNPRESS||QUIT", False
    04-06-2011 21:44:23: EXECTBL Translation: ONBTNPRESS -> PLAYSOUND;$SKINPATH$ButtonPress.wav
    04-06-2011 21:44:23: Executing: PLAYSOUND;C:\Users\-BO-\Documents\RideRunner\Skins\Genesis\ButtonPress.wav
    04-06-2011 21:44:23: Que Exec: True, exit_menu.skin, "QUIT", False
    04-06-2011 21:44:23: Executing: QUIT
    04-06-2011 21:44:23: Enter Exec: True, exit_menu.skin, "ONEXIT", False
    04-06-2011 21:44:23: Queued: "ONEXIT"
    04-06-2011 21:44:23: Shutdown: (1)
    04-06-2011 21:44:23: Shutdown: (2)
    04-06-2011 21:44:23: Shutdown: (3)
    04-06-2011 21:44:23: Shutdown: (4)
    04-06-2011 21:44:26: Plugin Manager: Warning Plugin rrtms does not support Terminate Method
    04-06-2011 21:44:26: Plugin Manager: Warning Plugin skintool does not support Terminate Method
    04-06-2011 21:44:26: Plugin Manager: Warning Plugin weather does not support Terminate Method
    04-06-2011 21:44:26: Plugin Manager: ALL Plugins unloaded.
    04-06-2011 21:44:27: Shutdown: (5)
    04-06-2011 21:44:27: Player is running
    04-06-2011 21:44:27: Shutdown: (6)
    04-06-2011 21:44:27: Shutdown: (7)
    04-06-2011 21:44:27: OSUnloadMode: 1
    04-06-2011 21:44:27: Global Hotkey: All keys unregistered
  6. #146
    Oct 2008
    Odense, Denmark
    the .BAT file i use to reg pi with:
    @echo off
    @regsvr32 /s RRPDC.dll
    ps: of course i right click and choose run as admin
  7. #147
    Oct 2008
    Odense, Denmark
    hmm for some reason its loading fine now....
    09-06-2011 11:08:37: Plugin Manager: Plugin loaded (Global): RRPDC
    09-06-2011 11:08:37: Plugin Manager: Warning Plugin RRPDC does not support Enabled Method
    09-06-2011 11:08:37: Plugin Manager: Warning Plugin RRPDC does not support Initialize Method
    09-06-2011 11:08:37: Plugin Manager: Warning Plugin RRPDC does not support Properties Method
  8. #148
    Oct 2008
    Odense, Denmark
    only thing i have done after it would not load was to try reg it as a .net pi...
    regasm /codebase /tlb rrpdc.dll
    then i did it via my bat file:
    @echo off
  9. #149
  10. #150
    Oct 2008
    Odense, Denmark
    i was a tad to fast.... in car i tried the same but here it will still not load
    rr debug says excatly the same
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 02-24-2013, 06:59 AM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 06:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 06:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 10:27 AM
