Page 16 of 16 FirstFirst ... 678910111213141516
Results 151 to 160 of 160
Thread: RRPDC - RoadRunner park distance control extension plugin
  1. #151
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by boelle View Post
    i was a tad to fast.... in car i tried the same but here it will still not load
    rr debug says excatly the same
    Did you find a fix for this. I'm at the same point as you. Win 7 32bit and RR is saying the dll is not registered.
    EDIT: installed vb6 runtime files and that fixed it. Good to go now
    Live mp3Car Facebook Chat
  2. #152
    Jan 2006
    Dublin, Ireland
    Is there a way to use this with a Factory Installed BMW PDC ?
  3. #153
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by championc View Post
    No.
    If you have a BMW with iBus have a look at JanneH0's plugin.
    If you have a canbus based one then then have a look at what trevorc2 is working on
  4. #154
    Jan 2006
    Dublin, Ireland
    Is there somewhere I can download this Plugin from ? Both links are now dead
    Without re-inventing the wheel, is it relatively straight forward to modify the skin to use the USB Camera portion of the plugin combined with the PDC functionality of iBusCommunicatorRR ?
  5. #155
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    PM sent with working link SNO
  6. #156
    Jan 2006
    Dublin, Ireland
    Thanks SNO
    Has anyone managed to modify this skin in order to use the webcam but take the PDC data from the IbusCommunicatorRR Plugin ?
    I'm also stuck at the point where I'm trying to test it out of the car but I don't get the Video to appear. Video is fine in the Config program. In previous posts, it says the run the PDC COMMAND in Menu.ini but I don't know what is meant by this. In my Menu.ini in the skin directory, I have
    rrmenu2item3 = "PDC||BYVAR;VOICEX;<<PLAYSOUND;$SKINPATH$SOUNDS\PD C.wav",PDC,ICONS\PHONE.png
    Is this OK ?
  7. #157
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Thanks SNO
    Is this OK ?
    You should be able to just change the name of the sliders in the skin to that of the IbusCommunicatorRR ones.
  8. #158
    Sep 2012
    Germany - Munich
    In your Case, i think it's better to use RRCam.
  9. #159
    Jan 2006
    Dublin, Ireland
    I'm still stuck at the point where I'm trying to test it out of the car but I don't get the Video to appear. Video is fine in the Config program. In previous posts, it says the run the PDC COMMAND in Menu.ini but I don't know what is meant by this.
    I am a bit of a noob. I do run the PDC Command ?
  10. #160
    Jan 2006
    Dublin, Ireland
    Quote Originally Posted by Enforcer View Post
    PDC
    Any other command does not make the video visible.
    Hi Enforcer / All
    Can you please clarify the LOAD command (using Reborn Skin) for the ExecTBL.ini file. Right now I have :-
    "PDC","LOAD;PDC.skin;;PDC"
    What should I have please ?
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 02-24-2013, 07:59 AM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 07:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 07:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 11:27 AM
