Pics?
Yep, registered the DLL, have X,RRPDC in my menu skin, it only shows the clip region.
here you go...
EDIT, forgot to tell you I do run DX 9.0c
try taking the clip out.
That was the first thing I tryed..no luck.
I even copyed the XVideoOCX.ocx to System32 and registered it..still no good.
I'll have to have a look when I am at home, I don't have a camera here at work![]()
The skin is called pdc.skin if not it won't work.
Also (I think) you need to load the skin with the PDC command and not load;pdc.skin
Normally the screen is automatically loaded when you engage reverse gear, however I added also the command "PDC" to test the plugin, so, as Enforcer said, you need to load the skin with the this command and not load;pdc.skin, otherwise the cameara will not be activated.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Well, I've got my sensors painted and installed. Now I need the stuff to make it work.
Robby, I will send you an e-mail.
