Page 4 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 150
Thread: RRPDC - RoadRunner park distance control extension plugin
  1. #31
    May 2008
    Great, thanks for clearing that up, just wanted to be clear on that.
  2. #32
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Damn it...i don't think I have enough room on my pico for all this stuff...how awesome...
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  3. #33
    Aug 2007
    Is it possible to utilise the camera witihin RR without using the sensor kit? Reason for this is I use the sensor seperately and want to have it available even if the PC is switched off. What I am looking to do is to use a manual switch (connected to reversign lights?) to tell RR that I have gone in to reverse at which time it displays the image. I am not concerned about the sensor input as the existing unit will alert me regarding distance to the object behind.
    Thank you
  4. #34
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    you would either need a relay board or try to use the com port with some trickery.
    Both have be done so a little search should give you an answer.
  5. #35
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by jean001luc View Post
    Thank you
    There is a better way to use the sensor seperately.
    You can connect the sensor main unit to the USB interface trough a cable as explained in the thred, without remove the receiver from the display.
    In this way, you can use the original display and the PC simultaneously.
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  6. #36
    Feb 2008
    Robby, Can you add an option to display two sensers in front and two sensors in rear in your plugin? If one installs the sensors in the front he has no option but to use the display which shows the sensors in the rear.
  7. #37
  8. #38
    Aug 2005
    Italy
  9. #39
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    small request of sorts....
    I'm trying to implement this and the TMI into my flash skin. Unfortunately, flash cant use slider code in any shape or form. So is it possible to define variables or labels for each angle of slider. It doesnt even need to use the sliders range, just 4 to 1 or whatevers easiest.
    Doah. just now saw the source is posted lol.. i guess i can do this myself
    Live mp3Car Facebook Chat
  10. #40
    Aug 2005
    Italy
    Quote Originally Posted by Sonicxtacy02 View Post
    You might have some difficulty in recompiling the code, if so, send me the source with yours changes and I will recompile it for you.
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 12-25-2011, 04:15 PM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 07:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 07:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 11:27 AM
