Page 7 of 15 FirstFirst 123456789101112131415 LastLast
Results 61 to 70 of 150
Thread: RRPDC - RoadRunner park distance control extension plugin
  1. #61
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    This is sooooo bad ***.. What cameras are people using? I don't have a TV card but I guess I could install one if need be.. Easiest would be a USB camera?
    Thanks!
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  2. #62
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    It work with USB cameras, composite camera with external video input card. If I remember must use WDM drivers.
  3. #63
    Oct 2003
    Poland, OH
    Curious what specific model # cameras people are using..
  4. #64
    Oct 2003
    Poland, OH
    Would this work for a video capture device coupled with a composite camera?
  5. #65
    Newbie astraologo's Avatar
    Aug 2007
    Italy
    it's good i have this and work perfectly.
    mobo asrock K7S41gx- Amd atlon 1,2Ghz -512Mb ram- hd 2,5" 160Gb- lilliput 7" 619 touch-gps Holux- bluetooth digicomm palladio-usb park assist (RRPDC) -obdII elm327-hubusb trust
  6. #66
    Dec 2008
    I am a newbie to write plugin. Just looked into the source code of RRPDC and can not understand how the slider works. GetDataFromDevice() was called on timer event, but no code in this sub to update the slider.
  7. #67
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by efun View Post
    The sliders are updated from the sensor() array values in the RRExtension.cls.
    The sensor() array values are updated in the GetDataFromDevice() routine.
  8. #68
    Dec 2008
    Quote Originally Posted by Enforcer View Post
    So once the sensor() array was updated, the slider will refresh automatically? No need to call the ReturnSlider() function explicitly? I can not find any trigger or event to do this.
  9. #69
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    ReturnSlider is called from within RoadRunner (as is everything within the RRExtension.cls) at a set period, normally I think every 1/10th second (this can be changed by the user)
  10. #70
    Oct 2003
    Poland, OH
    I'm trying to set this up in RR now.. The add "X,RRPDC" to the menu.skin... I'm guessing the "X" should be actual value? For the stupid what do I put there?
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 12-25-2011, 04:15 PM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 07:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 07:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 11:27 AM
