Page 1 of 15 1234567891011 ... LastLast
Results 1 to 10 of 150
Thread: RRPDC - RoadRunner park distance control extension plugin
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Arrow RRPDC - RoadRunner park distance control extension plugin
    This plugin is intended to work with my custom PDC USB interface.
    A detailed description of the whole project can be found here.
    How it works:
    The plugin is automatically activated when you engage reverse gear, RoadRunner will switch to the plugin skin and alerts you about the presence of obstacles.
    If a buzzer is connected to the hardware, this one gradually increases in frequency as you approach the object. A continuous tone denotes that you are within 0.30 m (about 0.98 ft) of the obstacle.
    The plugin can be configured to show the distance in meters, inches or feet and optionally it can display a live video from a backup camera.
    All the video capture devices that come with a WDM driver, such as framegrabbers in conjunction with a CCD camera or camcorder, USB cameras (webcams) and digital camcorders through Firewire (IEEE 1394), are compatibles with this software.
    For example, in my car, I have installed one of these wide-angle mirrored camera and I have connected it to the composite video input of my Cinergy 600 Radio TV card.
    Video of the plugin in action:
    [media]http://it.youtube.com/watch?v=rqjL37QVe2M[/media]
    How to install:
    Copy the files provided in the RoadRunner folder (or better, in the PLUGINS folder) and the skin files in your favorite skin folder (you can also use the skin provided (that is part of my BMW-E36 skin) as a guideline to develop your own skin.
    Register the DLL, from a command prompt type: regsvr32 <your plugin path>\RRPDC.dll
    Add in your "MENU.SKIN" the command "X,RRPDC".
    Launch the tool “RRPDC Config” and set all the stuff.
    Added skin commands:
    COMANDS/BUTONS:
    “PDC” – Go to the plugin screen (for testing propouse).
    “PDC_BUZZER” – Toggle mute/un-mute the buzzer.
    "PDC_CAMERA" – Start the fullscreen camera view (doesn't require additional skin, a click on the screen will turn off the view).
    INDICATORS:
    “PDC_BUZZER” – Indicates if the buzzer is muted.
    "PDC_STOP" - Indicates that the obstacle is at less then 0.30 m (0.98 ft).
    LABELS:
    "PDC_DISTANCE" – Shows the distance when an obstacle is under 2.00 meters (6.56 ft) in rear of the vehicle.
    SLIDERS:
    "PDC_SENSOR_A" – Shows visually the distance detected by the ultrasonic sensor A (Rear extreme left).
    "PDC_SENSOR_B" – Shows visually the distance detected by the ultrasonic sensor B (Rear center left).
    "PDC_SENSOR_C" – Shows visually the distance detected by the ultrasonic sensor C (Rear center right).
    "PDC_SENSOR_D" – Shows visually the distance detected by the ultrasonic sensor D (Rear extreme right).
    "PDC_SENSOR_E" – Shows visually the distance detected by the ultrasonic sensor A (Front extreme left).
    "PDC_SENSOR_F" – Shows visually the distance detected by the ultrasonic sensor B (Front center left).
    "PDC_SENSOR_G" – Shows visually the distance detected by the ultrasonic sensor C (Front center right).
    "PDC_SENSOR_H" – Shows visually the distance detected by the ultrasonic sensor D (Front extreme right).
    OTHER:
    "Axx, X, Y, W, H, R, G, B" - Defines the live video "confine" position (you must also CLIP this area). Please note that the image from the camera always maintains its aspect ratio.
    "Cxx, X, Y, W, H" - Clip window region, this tag must to have the same parameters of the tag above.
    Look at the skin provided for more details on how to use these commands.
    Screen shots:
    - the plugin in action -
    - the config utility -
    - the config utility (advanced settings)-
    The configuration utility is multilingual, curently it has been translated into:
    English
    Spanish - Thanks to Aveigal
    Italian
    German - Thanks to Zorro
    French - Thanks to Coucouillu
    Russian - Thanks to Kadyroff
    Hungarian - Thanks to FPeter
    Netherlands - Thanks to Servowire
    Slovenian - Thanks to Dejan
    Romanian - Thanks to Dexter4000
    Portuguese - Thanks to Myrus
    Turkish
    Greek - Thanks to 85755
    Danish - Thanks to Boelle
    Finnish - Thanks to Tumeski
    Klingon - Thanks to... Worf
    Would you like to get it translated also in your language?
    Downlad this file: "English.txt", translate it and post it back, I will be happy to include also your language.
    Change log:
    1.00:
    -First release.
    1.10:
    - Fixed the indicators in agreement with this thread.
    1.30:
    - Added support for two devices (front and rear).
    - Added configurable delays (users request).
    - Added fullscreen camera view.
    Downloads (Robby's Server):
    RRPDC 1.30 Binary
    RRPDC 1.30 Source
    Downloads (Mirror):
    (It could not be updated with the last release)
    RRPDC 1.10 Binary
    RRPDC 1.10 Source
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
    Constant Bitrate almera's Avatar
    Aug 2004
    Thumbs up
    Another excellent project, thanks again Robby..
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    wow, this is just awesome, good job Robby!!
    Aug 2004
    Aug 2005
    Italy
    Maybe my second nikname
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I really need to rob a bank or something to get to put in some of these awesome plugin's!!
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    EL CAMINO's Avatar
    Jul 2005
    Quote Originally Posted by Enforcer View Post
    gobby? who is gobby?
    ups, fixed!!
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Well, did all the things you said, run the config tool, set everything, shows the image in the config tool, camera working. After that, start RR go to the camera skin but it does not show anything from the camera. Do I need an external program and embed it?
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 12-25-2011, 04:15 PM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 07:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 07:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 11:27 AM
