Page 12 of 16 FirstFirst ... 2345678910111213141516 LastLast
Results 111 to 120 of 151
Thread: RRUpd8 - Sync plugin for Road Runner Status : Updated 20/11/11
  1. #111
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Doug, can you check that the folders you are trying to sync up aren't ReadOnly.
    I have found that for some reason all my folders on a couple of PC's are now ReadOnly, when they weren't before.
    I suspect one of MS's updates is responsible for this.
  2. #112
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by Enforcer View Post
    I'll check into this when I get home. I haven't tried a sync in a while but am preparing to re try. I created a Separate "Sync Only" or "Leave my music alone windows media" folder. Windows media destroys my music collection with garbage album art and incorrect tagging, but I use it on my htpc. This folder of music is a direct copy and dedicated to the sync and trying to get it right. It is hosted on a Windows Home Server and the folder should be full access to the Carpc. Ill check into the "read only" properties when I get home. Thanks.
  3. #113
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Enforcer, can you add an indicator that is on when the plugin is loaded? This is the way all of the plugins have gone now, so one plugin can tell if another is running,and to show that the plugin is loaded and active.
    This will help when they download your plugins to add to the skin to see if they have installed them correctly or not.
    An indicator something like "rrupd8_Loaded" would be perfect. I have all the other plugins showing their status on a screen: Youtube, RRMedia, Skype, MobilePhone.net, Vehicle Maintenance, OBD_MPG & Fusion Brain. All have these indicators except for RRUpd8, Traffic Cams, and RRGas.
    Wasn't it you that helped to define the new standards for plugins? Heheh thanks much!
    My Fiero Build Thread
  4. #114
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I started to add indicators and labels to them, in fact RRTrafficam has an indicator rrtrafficcam which always returns true when RRTrafficam is running.
    RRGas, RRUpd8,RRTrafficcam,RRPetrol all have labels which return their version.
    <plugin prefix>_version
    or
    <plugin prefix>_program
    ie
    rrgas_version
    or
    rrtc_program
    However t I got a bit p!$$3d around that time as no one from the development team even bothered looking at the standards we were trying to set up so gave up.
    I will add Indicators which are the same as the plugin name for the others.
  5. #115
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Cool, thanks! Yea, the dev team has had a lot to then and it was a mess with the whole RR switch and stuff, so things got brushed aside. Luckily the standards were created, a new plugin source code example created, and most of the stuff that has been recently released follows it.
    You know how it goes, look how long it took to get the new Skins & Plugins sections
  6. #116
  7. #117
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    No sync
    Hi Enforcer,
    I try to use your plugin in the skin Carwings_Dynamic_lite with last RR release.
    my ini file is :
    Code:
    [General]
    Delay=60
    Pop=True
    Success=5
    useRRMedia=False
    Automatic=True
    [Locations]
    Loc1=Home Music,C:\Users\pierre\Music\Mp3\Beatles\,E:\Mp3\,aup,*
    So, I want to copy all folders and files who are under C:\Users\pierre\Music\Mp3\Beatles\
    and to have the copy in the E:\Mp3\ folder .
    But , noting .
    My config is ok for that i want to do ?
    I upload my debug file.
    Attached Files Attached Files
  8. #118
  9. #119
    May 2008
    Bordeaux, France
    You need to have an access.ok file in the root of the remote location.
    I can't to have a remote way link mine : E:\Mp3 . If I change the remote by E:\ , no problem.
    Can I change re-write option of my Mp3 folder and to have an issu (it is just for the fun) .
    I have tested this issue but no update possible .
  10. #120
  1. Filesystem Sync Plugin
    By smeesseman in forum CF Plugins
    Last Post: 02-03-2010, 12:11 PM
  2. List of available plugins and features
    By JohnWPB in forum RR Plugins
    Last Post: 10-25-2008, 07:16 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. Replies: 0
    Last Post: 03-31-2007, 11:12 PM
  5. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
