Page 7 of 15 FirstFirst 123456789101112131415 LastLast
Results 61 to 70 of 144
Thread: RRUpd8 - Sync plugin for Road Runner Status : Updated 20/11/11
  1. #61
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Dougw133 View Post
    Did a quick setup here at work with a flash drive on my "Riderunner" test laptop and everything worked great! Wow! What a nice feature. Plug in the flash drive and it adds the new music automatically, and then scans RRmedia.db ..Great work, I cannot wait until I get it setup to access and sync my remote location (home media server). Thanks again Enforcer!
    Good to know the Flash drive and the RRMedia bits work, as I don't really use those two. I just use the Wireless connection.
    What you may need to do if you sync from more than one location is make sure they don't both point to the same destination folder if one or more them is set up to mirror
  2. #62
    MySQL Error
    Oct 2004
    there is no issues in RiderRunner with indicators in this plugin...
    i dropped in the upd8 dir into my plugins dir, registered it, and copyied the BMV2 skin files in, and did some syncing!!
    E, i must say, this is a GREAT Plugin, very VERY VERY well done
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #63
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I also just tried this plugin and it seems to do everything it's supposed to and show everything it's supposed to. The Indicators worked (green/red lights + folder disk/icons + buttons) -- I could not find anything wrong with it, there may even have been an issue with a specific version of RR, but it is working fine on the latest versions.
    Ride Runner RR's Myspace
  4. #64
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Like I said, I think it was one of the versions around February where their was a general indicator issue.
    Good to know it all works though.
  5. #65
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by Enforcer View Post
    Soo..I guess what I was shooting for was to have the flash drive "ADD" and the "Wireless Mirror" all to the same "MUSIC" folder on my HDD. You are saying this might cause a problem?
    Basically have the Wireless mirror so my Carpc is always , well, Synced"...I would like to use the Add feature for the flash because obviously I do not have my whole collection on it and it would be if I was running out the door and wanted to add some files on the way, or got them elsewhere away from home.
  6. #66
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well yes, because the 'mirror' will find media that is on the destination drive, but is not on the source.
    Options
    1. Just use add for both. (disadvantage, nothing ever gets deleted)
    2. Have a Music folder and then two subfolders Main and Temp e.g. The main is mirror'd and the temp is add. Point RR to Music, it will still pick up all the media. (This is what I have had to do).
  7. #67
    Nov 2007
    PA
    Options
    Good suggestions, thank you...
    I think I'll just stick with the mirror, if I really need to get a new set of music on the PC i can take the 2 minutes it takes to copy the files...Plus, DFX4 has a media copy skin that allows me to essentially do the same think sync does but manually..I will certainly benefit very much from the mirror sync..Thanks again, and as always, perfect necessity driven plugins from Enforcer!
  8. #68
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Doesn't matter how the other music gets there, if it ain't on the mirror source, it won't be on the destination for long
  9. #69
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Question Automatic Syncing question
    Ok, I started skinning the RRUpd8 plugin for the DFX skin. This is a really cool plugin!
    I am having one issue however... When I have the auto sync turned on, and the auto switch to the sync screen, it keeps going to the screen when nothing is being synced.
    I have it set to 10 seconds for testing, and if I go to the main menu, in 10 seconds it switches to the sync screen. Is there a way to have it switch only if there are files actually being synced, and not just when the plugin checks?
    Here is a screen cap of what I have thus far:
    My Fiero Build Thread
  10. #70
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by JohnWPB View Post
    At present no.
    Will look into that for future versions.
  1. Filesystem Sync Plugin
    By smeesseman in forum CF Plugins
    Last Post: 02-03-2010, 12:11 PM
  2. List of available plugins and features
    By JohnWPB in forum RR Plugins
    Last Post: 10-25-2008, 07:16 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. Replies: 0
    Last Post: 03-31-2007, 11:12 PM
  5. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
