Page 1 of 15 1234567891011 ... LastLast
Results 1 to 10 of 144
Thread: RRUpd8 - Sync plugin for Road Runner Status : Updated 20/11/11
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Press the button below to download from my forum
    or download it from the AutoAppMart - nb registration on my forum still required
    Donation(s) - Thank You
    Chuck
    Current Standalone version
    Version 2.0 Released 20/11/11
    All settings to be done in plugin. ie no editing ini files
    React to *ONWIFIMAN_CONNECTED from WiFiMan to start looking for syncs to sync.
    Ability to upload syncs list from one PC and then download on another.
    Select what can initiate individual syncs (WiFi, USB, Timer, Manual or Single)
    Version 1.2.2 Released 31/07/10
    Added
    Option to have Images for sync actions instead of or as well as text. (Request DaveFocus)
    Button to run only highlighted Sync. (Request Chuck)
    History screen - This will display up to the last 100 files copied or deleted.
    Registration - This allows skinners to distribute the plugin with their skins (or for it to be uploaded to the downloads section here)
    All working files are now transferred to the users profile (local settings\application data) to keep mitchjs and Bill Gates happy.
    Multi language support. Well there is only English at present but if anyone can translate the language file into other languages it would be great.
    Background downloading of new plugin version if available. (exe provided to run when not in RR to upgrade the DLL)
    Changed
    Automatic and Popup in settings screens can now also be buttons instead of just indicators (Request Chuck and JohnWPB)
    Automatic switch to Upd8 screen is now only when an actual filecopy is taking place.(Request JohnWPB)
    Fixed
    Errors when dealing with Archive, readonly etc files in delete routine.
    Released 07/12/08
    What it does
    • Checks for connection to remote location
    • Automatically updates new folder and files (playlists and songs)
    • Removes old folders/files (optional)
    • Unlimited subdirectories
    • User selectable file types or all types
    • Visual indication of connection/no connection
    • User Configure Utility
    • Can be used with Memory Sticks (automatic detection of)
    • Log of all transfers/deletions
    • Indication of free diskspace
    • Multiple Source Locations
    • Multiple Destination Locations
    • Tells RoadRunner to load Upd8 screen when new sync takes place (can be turned off)
    • Upload syncs list to internet to allow download on another PC. (Coming in 2.x)
    Attached are the skincommands
    SkinCommands (2.x)
    Attached Files Attached Files
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    F.a.q.
    Q. Why should I use this plugin version in RR as opposed to the Standalone version?
    A. There is no reason why you shouldn't use the standalone version, however this version has better intergration with RoadRunner skins and can also work with transparent ones
    Q. How can I download this wonderful creation?
    A. Register on my forum at www.en4cer.co.uk/forum , when activated go to the downloads section.
    or download from the AutoAppMart (registration will still be needed on my forum to activate)
    Q. Does this application only work with Road Runner/Ride Runner?
    A. Yes, this is a dedicated RoadRunner/RideRunner Plugin, However there is a standalone version available.
    Q. How do I change the size?
    A. The plugin will run at the same size as RoadRunner.
    Q. Can I use RRSkineditor to edit the skin?
    A. Yes.
    Q. How do I embed this is my skin?
    A. Add a button with the command RRUpd8, and then design the screens to match your skin. Use the Carwings skin files as a guideline
    Q. Would someone care to send me this?
    A. The install rrupd8.exe can be shared
    Q. Will this compare existing files with the source files.
    A. At the moment it compares the modified date, so if changes were made it will copy the latest version or leave the newer version there.
    But no it doesn't compare the files byte for byte. The way the program is written I can add that but it's likely to really slow it down (But I will see if there is an easy way to do that for the future maybe)
    Q. would it be possible for the app to say what the estimates size might be of the files selected ?
    A. Not the way it works a present. Essentially it looks at all the files at the source and then goes through the destination and checks if it exists, if it doesn't or is older it copies the new one over. To have it tell you whether there was enough space before hand it would have to make a list of the differences and then start copy, which don't really want to do as the list might change while it's copying.
    Q. Can it, when selecting files / folders, have the option to 'tick' trees like a lot of AV software does when you selecting which folder / subfolder you want to copy.
    A. The idea is for you to a have a location in the same format as that on your CarPC, I don't think I'll be adding a selectable folder option as it will complicate it too much. (Unless there is a lot of requests for it)
    Q. Can it update RoadRunners Playlists when copying is done?
    A. If RRMedia is running, yes.
    Q. I have set up a sync, but the plugin does not sync any files?
    A. First check that you have the access.ok file in the root of your remote location. This will normally be done automatically if you have used the plugin to set the sync paths. Also make sure you have write permissions to the destination folder.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    v1.2x skins
    Carwings v1.2x
    NB this will install into Carwings_Dynamic, if you are using Carwings_Dynamic_lite then you will need to copy the file there.
    NB2 I have also included some of the default files which the plugin uses, these need not be copied across.
    v1.1x Skins
    Bmv2 v1.1.x
    iDrive Night Red v1.1x
    NB iDrive skin will only work properly with the corresponding full iDrive skin.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Looking good Enforcer. Not sure when I will get a chance to try to integrate it, but definitely something I will add to my skin down the road.
    My Fiero Build Thread
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    workin fine for me.. i've tried all the sync actions.. though honestly i was a little confused between UP and DOWN.. but that was the same in the standalone as well. Is it possible to only allow manual updates? And is it possible to NOT have the database update in RRMedia? My builder tool is giving me errors again
    Live mp3Car Facebook Chat
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well the up and down are supposed to relate to upload and download, ie download from the remote location or upload to the remote location
    Only allow manual updates : No (unless you set then delay a humungously large number)
    Not update the database in RRMedia (Oh so that bit works then?) : No, unless you don't use <musicpath>
    However I will add toggles for those two.
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by Enforcer View Post
    it worked.. but the database looked like it was being updated while the files were transferring instead of after.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well it sends the command after it finishes an individual sync, only if the sync contains "<musicpath>" as the local or remote path.
    So it's possible it sync your music path, send the command and then carry on with the other syncs in your list.
  1. Filesystem Sync Plugin
    By smeesseman in forum CF Plugins
    Last Post: 02-03-2010, 12:11 PM
  2. List of available plugins and features
    By JohnWPB in forum RR Plugins
    Last Post: 10-25-2008, 07:16 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. Replies: 0
    Last Post: 03-31-2007, 11:12 PM
  5. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
