Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 11 to 20 of 103
Thread: RRSched (Calendar/Schedular) [Alfa Released]
  1. #11
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    If that is what is wanted to use a lbl or ind to show days status, could be done easier inter than like that. If that was done, what would the lbl display, or leave to have by user/skinner setting?
    I think that follwing RR STD indicator nomenclature would be the best. That way, we can just use the BYIND command to process our own labels.
    i.e.
    IS:
    RRSched_In dDay;8
    PROPOSED:
    RRSched_In dDay8
    TBH, the only reason why I think I know what Chuck is doing is because I was planning on doing something similar for my implementation. Haven't had the change to test it since I'm at work.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  2. #12
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    When the indicator is on this would display a text label “Event” but I don’t think it will work with the ; in there.
    The reason I do this is so I do not need to add more images to my skin – I only have 14 .jpg for my whole skin set.
    BYIND;RRSched_In dDay;8;<<= Event
    2001 S10 ZR2
    Chucks Skin - to old
  3. #13
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    There is a very simple reason as why i did the labels and ind in my own std. Tons of lesser code and actually makes skinning it easier ( I think ).
    I would just much rather add an event lbl then change the code to keep with the RR std format.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #14
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    That a work - thx
    2001 S10 ZR2
  5. #15
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Will update it within a couple hrs....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #16
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    K, try the RRSched Dll.zip first post
    Event label is: "RRSched_Evnt;x"
    I only had to add 4 lines of code! If you don't want the default display of "Event" then add "RRSchedEvntLBL=xxx" to your skin.ini.
    FYI, for future reference...I'm doing this so if there is something like this that you like to see added, simply ask and I'll say Yay(simple to add) or Nay (to much to make it work) instead of doing what your trying to accomplish using a much messier method..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #17
    Dec 2007
    very nice blue... this is going into my htpc skin..
  8. #18
    Aug 2006
    Sun Diego
    *nvm*
    It's working. I must not have reg'd it properly...
  9. #19
    Dec 2007
    it does bring up the calendar with new dll for me.
  10. #20
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    U using the demo skin or your skin? That calls the "RRSched_Calendar.skin"
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
    By Blue ZX3 in forum RR Released Plugins
    Last Post: 09-27-2011, 02:45 PM
  2. timer ext plugin now RRsched
    By carputer1 in forum RR Plugins No Longer Supported
    Last Post: 10-27-2008, 11:46 AM
Tags for this Thread
