Small update, added a 5 second delay before the execution of the missed event check. This basically gives rr time to finish up on startup, same thing when resuming from standby or hibernation.
I don't understand why it would speak anything with that command as its just a cmd with no params. Usually the ones that end up making RR speak is the ones that have one or more params as by RR std cmd, to make it speak its like the second or third param that gets spoken but certainly not the case with that cmd.
And ya, this needs to be addressed somehow.
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
Is there a tutor somewhere so I can setup this plugin?
I placed the "X,RRSched" command in the menu.skin file but the plugin has replaced my main menu and is the first thing that is shown when RR starts. I want to be able to call the plugin with a button press or by taping the screen section where the date is shown. How would I go about doing that?
The road is long but we are getting there.
if you downloaded the plugin from the 1st post , you use it like its another skin, not add it to your exsisting skin, blue set it up so the 1st screen you see is the plugin screen . you need to convert it all over to your using skin, if you want to use it.
Any help on how I would go about doing that so I can use it in my RR skin
just take all the skin files out of the downloaded plugin add them to your skin ,
X,rrsched to your menu .skin, look in blues readme for the launch cmd, a nd add it to where you want , not at the right comp to specife what that cmd is,
i think its Bumping time
Riderunner / Genesis
Wifiman_NET:Version 1.0.0
Nah!, had another month to go.![]()
best add that to RRsched, so i know when to ask again lol...
If it works, why the need to bump?
