Hi Blue,
Nice plugin. With the DNE section, does this fire off on resume from hibernate ? I'm asking because I don't think the Gamma gets set correctly after a resume with RREXT.
Val.
Having a bit of trouble w/ the "BYSTR" command.
RR v020209
RRE v1.03
Hangs everytime it executes. Here's the snipet of the debug file:
Code:2/5/2009 6:34:34 PM: Executing: SETVARBYCODE;temp2;LISTTEXT 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "BYSTR;$temp2$;OTHER<SETCSTR><<NEW<SETNEWF><<BACK<<BTNCFGR><<<SETBTTN", False 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "setcstr", False 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "SETVAR;btnedit;1", False 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "SETVAR;btnedit;1", False 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "SETVAR;btnedit;1", False 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "SETVAR;btnedit;1", False 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "SETVAR;btnedit;1", False 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "SETVAR;btnedit;1", False 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "SETVAR;btnedit;1", False 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "SETVAR;btnedit;1", False 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "SETVAR;btnedit;1", False 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "SETVAR;btnedit;1", False 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "SETVAR;btnedit;1", False 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "SETVAR;btnedit;1", False 2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "SETVAR;btnedit;1", False
Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
Hi Blue,
Val.
The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
It fires which ever event's time it is anytime that its past that time. That feature only fires off events, for which you have to define what you want RR to execute. If you want to exec a gamma cmd then you have to set that using the custom fired events.
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
hi blue ...
"DAYTIMEEVENT","SAVETOSKIN;BACKGROUND;$DAYBKGND$|| RELOADSKIN||DAYGAMMA"
"NIGHTTIMEEVENT","SAVETOSKIN;BACKGROUND;$NIGHTBKGN D$||RELOADSKIN||NIGHTGAMMA"
these are my day and night events ... but the gamma doesnt seem to kick in on a resume from hibernate ...
C&P only the DNE settings from the rr.ini or skin.ini that you are using along with a debug log. Turn on RR's debug, leave for a day or one hib/res that should have one of those being executed and attach to your post.
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
I Blue ,
This is a ver complete plugin .
I try the RunningApps option .
I have these lines on rr.ini file :
Code:[RRExtended] RRExtended_Debug=False RRWW_Enabled=False RRWW_Watch1=volume;42;>;Volume RRWW_Interval=2 RRWW_Snooze=5 RRSpeak_Enabled=False RRSpeak_ReduceVolBy=75 RRResumer_Enabled=False RRResumer_Interval=5 RRFob_Enabled=False RRFob_Last= RRSkinGen_Enabled=True DNE_Enabled=False DNE_DayEventTime=7:00 AM DNE_NightEventTime=5:45 PM DNE_Lat=0.000000 DNE_Lon=0.000000 DNE_OffSet=0 RunningApps_Enabled=True RunningApps=que.exe;notepad.exe
CODE and /CODE before and after on rr.ini file is it necessary or not ?
Do i to add X,RRExtended on Plugins.txt file ?
I had added these lines on my menu.skin file:
I,625,8,47,53,"QUE.EXE"
I,570,12,50,45,"NOTEPAD.EXE"
I had added this line on my Exectbl.ini file :
"ONSKINSTART","CWDSETUP||ONSTARTNOTEPAD.EXE||ONSTA RTQUE.EXE"
I use the last RideRunner version 2/2/2009
I see no indicator .
Where is my error ?
Can you help me please ?
Thanks again![]()
yes you need to add X,RRExtended to plugins.txt if not already there.
its my understanding that the onstartXXX and onendXXX cmds
will show indicator when that app is running, as you have them in the onskinstart , unless the app is running from when you start the skin you won't see any ind show up.
plus how are you have the indcator show , have you used a image, or a label or a graphic in the on skins,
this is my understanding
The code & /code was only for posting in the forums, so is not needed in the ini...Originally Posted by pierrotm777
Using the latest RR, you really don't need to add any ref to the plugin as long as you have it in either the RR root\Plugins\RRExtended or skinpath\Plugins\RRExtended.Originally Posted by pierrotm777
Those lines are correct, as long as there is an on image in that location(s).Originally Posted by pierrotm777
Those (ONSTARTNOTEPAD.EXE & ONSTARTQUE.EXE) are events that get fired when those app start/stop by RRExt. A different example for those would be like..Originally Posted by pierrotm777
This line would load the xxx.skin when the notepad.exe process exists
"ONSTARTNOTEPAD.EXE","LOAD;XXXX.SKIN"
This line would load the Menu screen when the notepad.exe process no longer exists.
"ONENDNOTEPAD.EXE","MAIN"
Same actions as above but using the QUE.exe process name.
"ONSTARTQUE.EXE","LOAD;XXXX.SKIN"
"ONENDQUE.EXE","MAIN"
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
I don't understand,
I had modified the Exectbl.ini file :
"ONSTARTQUE.EXE","LOAD;GMPC.skin"
And Nothing !!!!
Only thing else that i can think of would be did you reg the dll by running the _Install.cmd in the plugin folder?
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
