Page 12 of 34 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 331
Thread: RRExtended [ v1.20 Updated 01/21/12 ]
  1. #111
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Booooo
    I am sorry but I have always the same issue .
    I don't understand .
    I am on Vista and my install folder is :
    C:\Program Files\Ride Runner\Skins\Carwings_Dynamic\Plugins\RRExtended
    See some debug's line
    14/02/2009 20:19:37: Start -- Version: 02/02/2009
    14/02/2009 20:19:37: OS Type: Vista
    14/02/2009 20:19:37: VMC---> Set object successful
    14/02/2009 20:19:37: VMC---> SOURCE: Playback Input line: "Haut-parleurs"
    14/02/2009 20:19:39: No Phidgets interface detected.
    14/02/2009 20:19:39: Plugin Manager: loading Global Plugins...
    14/02/2009 20:19:39: Plugin Manager: loading Global Plugins Completed.
    14/02/2009 20:19:39: LoadSkin: C:\Program Files\Ride Runner\Skins\Carwings_Dynamic\
    14/02/2009 20:19:39: Plugin Manager: loading SkinDir Plugins...
    14/02/2009 20:19:39: Plugin Manager: Plugin Found: MovieTimes
    14/02/2009 20:19:39: Plugin Manager: Plugin Found: RRExtended plugin found but will be unable to create (most likely NOT registered)[skipped].
    14/02/2009 20:19:39: Plugin Manager: Plugin Found: RRGas
    14/02/2009 20:19:39: Plugin Manager: Plugin Found: SkinTool plugin found but will be unable to create (most likely NOT registered)[skipped].
    14/02/2009 20:19:39: Plugin Manager: Plugin loaded (SkinDir): MovieTimes
    14/02/2009 20:19:39: Plugin Manager: Plugin loaded (SkinDir): RRGas
    14/02/2009 20:19:39: Plugin Manager: loading SkinDir Plugins Completed.
  2. #112
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    FYI just tryed VarToIniKey section perfect , this dll is a great AI killer, i have now managed to remove 8 scripts from my skin lol... Thankyou
  3. #113
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Update v1.0.5
    See first post.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #114
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  5. #115
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
  6. #116
    May 2008
    Bordeaux, France
    Red face No RRExtended registried
    I Blue,
    I had tried this morning to use RRExtended on XP .
    I have the same issue than whith Vista and I don't know why .
    Can you give me a solution please ?
    I send you again my debug file
    Attached Files Attached Files
  7. #117
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I think that all that pond water is upsetting your comps...
    Edit the _Install.cmd, remove the "@" char... I don't even know how it got there...
    Then it should work...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #118
    May 2008
    Bordeaux, France
    Red face Booooooooooooooo
    I don't understant where is my problem !!!!
  9. #119
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    What exactly do you get when you run the _Install.cmd? You should get a message box saying either registration successful or that there was an error. On the vista comp you have to run that cmd using the run as admin, and on the XP one you have to have admin privileges.
    I sooo don't understand why your having so much trouble, as i see you have other PI's that got properly registered according to your debug log.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #120
    May 2008
    Bordeaux, France
    Thank you Blue again for your help.
    When I registry the dll I have no message . I had tried on Xp and Vista with
    administrator option and I have the same issu .
    I had erased the @ on .cmd file too .
    I have no problem with other plugins; RRgas,Skintool,Movietimes,
    PluginManager, etc...
    What is necessary if I want to use your plugin .
    I have not vb6 but I donc think that is it important .
    I have .NET 3.5 .
    Thanks again
  1. Volume too low on AUX line in, coming out of laptop.
    By Silenkiller in forum Car Audio
    Last Post: 10-07-2008, 08:45 PM
  2. iPod Integration Coming
    By Lazyflip in forum Centrafuse
    Last Post: 03-20-2008, 01:14 AM
  3. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 01:07 PM
  4. NEW playstation II portable keyboard coming out soon
    By clean customs in forum Input Devices
    Last Post: 03-04-2005, 04:37 PM
