Update v1.0.6
See first post.
If you have the other ones registered then...IDK.
I'm running out of ideas....
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Update v1.0.6
See first post.
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
Dare I say...
Update v1.0.7
See first post
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
HI Blue Zx3,
I try and try again RRExtended on Vista or XP, and always the same issue .
Nothing .
So I had tried to see if RRExtended.dll is well registered .
I had found this thread :
RR Com Cleanup Tool
but RR Com Cleanup Tool don't run on vista .
I can't use your .cmd for registered the dll .
So , I had found this software :
Emsa Dll Register.
So , on the same thread I had found this link COM Explorer and , wonderfull , I see your dll .
But always same probleme .
24/02/2009 13:44:37: Start -- Version: 02/02/2009
24/02/2009 13:44:37: OS Type: Vista
24/02/2009 13:44:37: VMC---> Set object successful
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Front Green In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Rear Blue In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Front Pink In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Rear Pink In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Rear Grey In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Rear Orange In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Rear Black In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Rear Green In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "CD audio"
24/02/2009 13:44:38: Shell: "C:\Program Files\Ride Runner\Gamma\"
24/02/2009 13:44:38: No Phidgets interface detected.
24/02/2009 13:44:38: Plugin Manager: loading Global Plugins...
24/02/2009 13:44:38: Plugin Manager: loading Global Plugins Completed.
24/02/2009 13:44:38: LoadSkin: C:\Program Files\Ride Runner\Skins\Carwings_Dynamic\
24/02/2009 13:44:38: Plugin Manager: loading SkinDir Plugins...
24/02/2009 13:44:38: Plugin Manager: Plugin Found: MovieTimes
24/02/2009 13:44:38: Plugin Manager: Plugin Found: RRExtended plugin found but will be unable to create (most likely NOT registered)[skipped].
24/02/2009 13:44:38: Plugin Manager: Plugin Found: SkinTool
24/02/2009 13:44:38: Plugin Manager: Plugin loaded (SkinDir): MovieTimes
24/02/2009 13:44:38: Plugin Manager: Plugin loaded (SkinDir): SkinTool
24/02/2009 13:44:38: Plugin Manager: loading SkinDir Plugins Completed.
????HHHHHHHHHHHHHEEEEEEEEEEEEEEEEELLLLLLLLLLLLLLPP PPPPPPPPPPPPP??????????
I have some news.
I had uninstalled all Ride and Road Runner on my XP partition .
I had too all unregistered with Com Explorer .
I had used CCleaner for to clean my XP .
I had installed just the 2/2/2009 Ride Runner version .
I had registered with the cmd command .
I see your dll on Com Explorer , Well!
I run without your rr.ini option and I have this debug.txt file :
If I add your rr.ini file , RRextended don't run .24/02/2009 15:59:54: LoadSkin: C:\Program Files\Ride Runner\Skins\Carwings_Dynamic\
24/02/2009 15:59:54: Plugin Manager: loading SkinDir Plugins...
24/02/2009 15:59:54: Plugin Manager: Plugin Found: MovieTimes
24/02/2009 15:59:54: Plugin Manager: Plugin Found: RRExtended
24/02/2009 15:59:54: Plugin Manager: Plugin loaded (SkinDir): MovieTimes
24/02/2009 15:59:54: Plugin Manager: Plugin loaded (SkinDir): RRExtended
24/02/2009 15:59:54: Plugin Manager: loading SkinDir Plugins Completed.
oi, stop using one of my trademarks![]()
I had found than if i add all your options , the plugin don't run (rr.ini or skin.ini) !
If I add just these lines it is ok :
But , I have no indicator ![RRExtended]
RRExtended_Debug=True
RunningApps_Enabled=True
RunningApps=que.exe
And for the first time , I have a RRExended_debug.txt file with that:
Is it good ?24/02/2009 15:58:04: RRSkinGen_Initz
24/02/2009 16:15:23: RRSkinGen_Initz
24/02/2009 16:16:31: RRSkinGen_Initz
24/02/2009 16:16:31: ---->Window Hooked
24/02/2009 16:16:31: ---->Window UnHooked
24/02/2009 16:16:47: ---->Window UnHooked
Thats better... if you could slowly add the option lines one at a time till you see that it causes that prob, and let me know which one it was so that i can take a look so that someone else might not have these issues that you were having..
After a little bit while running RR you should see some lines like this in the RRExt debug log, and if not you still have a prob somewhere...
2/19/2009 12:38:31 AM: Doing ProcessExists
2/19/2009 12:38:31 AM: ----->Checking if QUE.EXE IS RUNNING
2/19/2009 12:38:31 AM: -----> QUE.EXE IS NOT RUNNING
AND/OR
2/19/2009 12:38:31 AM: -----> QUE.EXE IS RUNNING
AND/OR
2/19/2009 12:43:34 AM: ----->Status: QUE.EXE HAS STARTED
2/19/2009 12:43:34 AM: ----->Status: Executing > ONSTARTQUE.EXE
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
