Page 14 of 34 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 131 to 140 of 331
Thread: RRExtended [ v1.20 Updated 01/21/12 ]
  1. #131
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Last news
    With these lines (all) , RRExtended run very well :
    [RRExtended]
    RRExtended_Debug=True
    RRWW_Enabled=False
    RRWW_Watch1=volume;42;>;Volume
    RRWW_Interval=2
    RRWW_Snooze=5
    RRSpeak_Enabled=False
    RRSpeak_ReduceVolBy=75
    RRResumer_Enabled=False
    RRResumer_Interval=5
    RRFob_Enabled=False
    RRFob_Last=
    RRSkinGen_Enabled=True
    DNE_Enabled=false
    DNE_DayEventTime=7:00 AM
    DNE_NightEventTime=5:45 PM
    DNE_Lat=45,253865
    DNE_Lon=-0,266360
    DNE_OffSet=0
    RunningApps_Enabled=True
    RunningApps=que.exe;notepad.exe
    But I don't see any indicator !
    On ExexTbl.ini file, I had added these lines :
    ****************** RREXtended **************************
    "ONSTARTQUE.EXE","SETVOL;WINAMP;255||MENU;QUE.SKIN ||SAY;LANCEMENT DE GARMIN MOBILE PC||SETVOL;WINAMP;40||SETLABEL;!WARNING;GARMIN||SE TLABEL;!WARNING1;MOBILE PC||WAIT;3||EXIT"
    "ONSTARTNOTEPAD.EXE","SETVOL;WINAMP;255||MENU;NOTE PAD.SKIN||SAY;LANCEMENT DE NOTEPAD||SETVOL;WINAMP;40||SETLABEL;!WARNING;NOTEP AD||SETLABEL;!WARNING1;NOTEPAD||WAIT;3||EXIT"
    "ONENDQUE.EXE",""
    "ONENDNOTEPAD.EXE",""
    On my menu.skin I have these lines who replace "online" and "phoco..." indicators (just for a test):
    I,575,10,47,53,"NOTEPAD.EXE"
    I,624,9,47,53,"QUE.EXE"
  2. #132
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Well now that you have gotten this far do you see any of those lines in the rrext log now?
    And what were those two lines set to before? 0.0000000?
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #133
    May 2008
    Bordeaux, France
    Yes , I had retried on my Vista partition the same modification :
    DNE_Lat=45,253865
    DNE_Lon=-0,266360
    and RRExtended run very well :
    Code:
    24/02/2009 18:16:39: Start -- Version: 02/02/2009
    24/02/2009 18:16:39: OS Type: Vista
    24/02/2009 18:16:39: VMC---> Set object successful
    24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Front Green In"
    24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Rear Blue In"
    24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Front Pink In"
    24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Rear Pink In"
    24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Rear Grey In"
    24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Rear Orange In"
    24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Rear Black In"
    24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Rear Green In"
    24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "CD audio"
    24/02/2009 18:16:40: Shell: "C:\Program Files\Ride Runner\Gamma\"
    24/02/2009 18:16:40: No Phidgets interface detected.
    24/02/2009 18:16:40: Plugin Manager: loading Global Plugins...
    24/02/2009 18:16:40: Plugin Manager: loading Global Plugins Completed.
    24/02/2009 18:16:40: LoadSkin: C:\Program Files\Ride Runner\Skins\Carwings_Dynamic\
    24/02/2009 18:16:40: Plugin Manager: loading SkinDir Plugins...
    24/02/2009 18:16:40: Plugin Manager: Plugin Found: MovieTimes
    24/02/2009 18:16:40: Plugin Manager: Plugin Found: RRExtended
    24/02/2009 18:16:40: Plugin Manager: Plugin Found: SkinTool
    24/02/2009 18:16:40: Plugin Manager: Plugin loaded (SkinDir): MovieTimes
    24/02/2009 18:16:40: Plugin Manager: Plugin loaded (SkinDir): RRExtended
    24/02/2009 18:16:40: Plugin Manager: Plugin loaded (SkinDir): SkinTool
    24/02/2009 18:16:40: Plugin Manager: loading SkinDir Plugins Completed.
    But I don't see any indicator .
  4. #134
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    K, now I see the issue... the old comma/period thing. I will add a check for this and get that fixed in the next update.
    I was asking about the RRExtended_Debug.txt. we now know that the PI is getting loaded so I don't care about RR's debug log anymore. Delete it ("RRExtended_Debug.txt") and then restart up RR, let run for a few and then post some of the "RRExtended_Debug.txt" contents..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #135
    May 2008
    Bordeaux, France
    This is my last RRExtended_debug.txt file:
    24/02/2009 19:02:19: RRSkinGen_Initz
    24/02/2009 19:02:19: ---->Window Hooked
    24/02/2009 19:02:19: ---->Window UnHooked
    24/02/2009 19:03:34: ---->Window UnHooked
  6. #136
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Found another issue on my end...crap!
    Until I release another version change your
    "RunningApps_Enabled=True" to "ProcRuningInd_Enabled=True"
    That is the reason that it is not working... Try that and then report back.
    Carputer1 has asked for a slight modification to the GetMouseColor feature, so I will be posting an update when I get home with the following additions/fixes:
    *Comma/period in the static gps settings for the DayNight feature
    *One more format for the GetMouseColor, adding a "SC" format to output a RGB in a "xxx,xxx,xxx" format to be a direct replacement for skin file format (carputer1 request)
    *Changing the "ProcRuningInd_Enabled" setting that it's looking for to a "RunningApps_Enabled" which is what it should be.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #137
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Enforcer View Post
    oi, stop using one of my trademarks
    Who are you talkin to and bout what?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #138
    May 2008
    Bordeaux, France
    Wonderfull !!!!!!!!!!!!!!!!!!!!! I see all indicators ...
    Thanks Blue ZX3 . Your are the best !
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Might I also encourage you to try my RRSpeak instead of the say cmds that you were using ealier. You will not have to so the whole setting of WA's vol as it will auto do that or if using another source, should lower which ever one is current before speaking and returns it back to same after its done
    Code:
    "ONSTARTQUE.EXE","RRSPEAK;LANCEMENT DE GARMIN MOBILE PC||MENU;QUE.SKIN ||SETLABEL;!WARNING;GARMIN||SETLABEL;!WARNING1;MOBILE PC||WAIT;3||EXIT"
    "ONSTARTNOTEPAD.EXE","RRSpeak;LANCEMENT DE NOTEPAD||MENU;NOTE PAD.SKIN||SETLABEL;!WARNING;NOTEP AD||SETLABEL;!WARNING1;NOTEPAD||WAIT;3||EXIT"
    "ONENDQUE.EXE",""
    And use these settings
    RRSpeak_Enabled=True
    RRSpeak_ReduceVolBy=85
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #140
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You, using my 'upd8' in your descriptions of things that have been updated.
  1. Volume too low on AUX line in, coming out of laptop.
    By Silenkiller in forum Car Audio
    Last Post: 10-07-2008, 08:45 PM
  2. iPod Integration Coming
    By Lazyflip in forum Centrafuse
    Last Post: 03-20-2008, 01:14 AM
  3. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 01:07 PM
  4. NEW playstation II portable keyboard coming out soon
    By clean customs in forum Input Devices
    Last Post: 03-04-2005, 04:37 PM
