Page 27 of 34 FirstFirst ... 171819202122232425262728293031323334 LastLast
Results 261 to 270 of 340
Thread: RRExtended [ v1.20 Updated 01/21/12 ]
  1. #261
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    RRStrings_FileFromPath
    Hi Blue,
    I try to use this RRextended's option but i don't understand how i must write my command.
    In my skin.ini file, i have defined a variable like that:
    Code:
    CMDEXE2=C:\Program Files\Ride Runner\Skins\Carwings_Dynamic_pm\Scripts\parallelport.exe
    in a screen , i have defined a label on a button like that:
    Code:
    L,178,143,138,33,255,255,255,18,"ARIAL:B","BYVAR;RREXE;=$CMDEXE2$<<=$CMDRR2$","CENTER"
    With your RRStrings_FileFromPath option , i hope to have just the program's name on my button without the program's path .
    I have tried that:
    Code:
    L,178,143,138,33,255,255,255,18,"ARIAL:B","BYVAR;RREXE;RRStrings_FileFromPath;TrackPath;=$CMDEXE2$<<RRStrings_FileFromPath;TrackPath;=$CMDRR2$","CENTER"
    but i don't see nothing !
    Who can i must to write my line please ?
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    Hey Blue,
    One small request, when you are putting up the ZIP files for download, could you put the RRExtended text file outside ofthe EXE, just so we can see the functionality without having to run the EXE ?
    thanks ..
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  3. #263
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ya, I could do that... do you forget where you installed it too...??
    [EDIT]
    Speaking of updating....need to get what i have posted...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #264
    Low Bitrate topjohn's Avatar
    Oct 2009
    France /Wissous
    Hello Blue,
    I love the work you've done in this DLL.
    By cons I found it slowed the launch of RR, would it be possible to get a version with fewer things inside?
    I only use 2 or 3 functions of your DLL (PlayWav, RRResumer mainly), I find it unfortunate slow start with the option that I do not.
    Thank you
  5. #265
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    If you can add/set "RRExtended_Debug=True" in your rr.ini, run RR, then attach the RRExteded_Debug.txt found in the PI folder.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #266
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by pierrotm777 View Post
    Hi Blue,
    Code:
    Code:
    I have tried that:
    Code:
    You can't use it like that. It is a cmd by itself.
    Option:
    Add two more variables, to hold the exe names
    e.g.
    CMDEXENAME2
    CMDRRNAME2
    Then when the skin loads you can use
    Code:
    ...||RRStrings_FileFromPath;CMDEXENAME2;$CMDEXE2$||RRStrings_FileFromPath;CMDRRNAME2;$CMDRR2$||SAVETOSKIN;CMDEXENAME2;$CMDEXENAME2$||SAVETOSKIN;CMDRRNAME2;$CMDRRNAME2$
    Then your label would be:
    Code:
    L,178,143,138,33,255,255,255,18,"ARIAL:B","BYVAR;RREXE;=$CMDEXENAME2$<<=$CMDRRNAME2$","CENTER"
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #267
    Oct 2009
    France /Wissous
    ok so here's what he has in the file
    RRExteded_Debug.txt:
    18/12/2009 08:03:14: RRExtended v1.1.5 Starting
    18/12/2009 08:03:14: ----
    18/12/2009 08:03:14: RRSkinGen: Initz
    18/12/2009 08:03:14: DayNightEvents: DayLightMode: Standard
    18/12/2009 08:03:14: RRResumer: Initz
    18/12/2009 08:03:14: TaskMgr: Getting Computer Info for Labels...
    18/12/2009 08:03:16: TaskMgr: Getting Computer Info for Labels...Done
    18/12/2009 08:03:16: ----
    18/12/2009 08:03:16: TaskMgr: Calculating computers uptime for Labels...
    18/12/2009 08:03:32: ----
    18/12/2009 08:03:32: RRextended Loaded in 18,11 seconds
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    K, I have seen one other persons log that took a bit to load. I have addressed this by adding a setting that will skip the Taskmgr stuff.
    Sys Specs?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #269
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i'm having the same problem blue. and as you know ,appart from the strings section of this pi, i use pretty much most other sections , can task manager load settings on entering the task manager skin,
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  10. #270
    Oct 2009
    France /Wissous
    Sorry I did not understand English well, and I did not understand the purpose of your message.
    I understand that some people had the same problem as me and you were to add an option ..
    that means: Sys Specs?
  1. Volume too low on AUX line in, coming out of laptop.
    By Silenkiller in forum Car Audio
    Last Post: 10-07-2008, 08:45 PM
  2. iPod Integration Coming
    By Lazyflip in forum Centrafuse
    Last Post: 03-20-2008, 01:14 AM
  3. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 01:07 PM
  4. NEW playstation II portable keyboard coming out soon
    By clean customs in forum Input Devices
    Last Post: 03-04-2005, 04:37 PM
