i assume he means task manager can be switched off on load of RR,
Printable View
the plugin will still load .its only 1 section of many sections ,
Ok
to follow
Its gonna be ON by default as the systems that I have used/tested on, only takes <=2 seconds to load..
Because of different load times, I'll use the RR Error screen if you try to use it and have it set to disabled.
on the next release of RRextended, Task manager section of this plugin , will set to on,(Working)
you will need to set it to off in the RR.ini or skin.ini, yourself!! by adding the setting cmd Blue has just made, and making it =False
Hey blue, RRE crashes when Filemanager detects a drive under "My Computer" that does not have a disk inserted (i.e. card readers, removeable storage devices for smartphones, etc.)
Any way to add a prevention against this?
http://www.mp3car.com/vbulletin/imag...0b85c90875.png
This has happened when my blackberry is plugged into my computer when locked, plugging in my Droid and the SD card has not been unmounted from the phone, or when I insert my USB card reader which displays all available memory card slots despite not having any memory cards inserted.
Cheers!
Well if I had any of those thingy's... Would be easier to check for a solution, as my iPhone is of no use here. But I'll see what I can come with
First posted updated to v1.16
@Sal
sorry didn't get a chance to look into that FileMgr issue..have to look and see what i can simulate with..
