Page 3 of 34 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 331
Thread: RRExtended [ v1.20 Updated 01/21/12 ]
  1. #21
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Correction...
    RRWarningWatcher is able to watch and alarm on any number type lable ie...temp, volt, volume,ect.. and alarm can be set off if < or > then alarm setting.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #22
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Added RRResumer
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  3. #23
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Hows about a expanded string match EVAL function that functions like "Select...Case"
    i.e
    BYSTR;< string variable>;Case1<<Case2<<Case3<<Case4 etc.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  4. #24
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Was easy...
    Cmd format is:
    BYSTR;< string variable>;Case1<cmd><<Case2<cmd><<Case3<cmd><<Case 4<cmd><<ect<<<Case Else.
    Example:
    "BYSTR;$MyVar$;a<AUDIO><<b<DVD><<c<VIDEO><<d<cmd4><<<NO"
    The cmd's must be wrapped in "<" and ">".
    Using a "<<<CMD" on the end will execute that cmd if nothing matched...ie a case else.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #25
    Aug 2006
    Sun Diego
    Was easy...
    Cmd format is:
    Example:
    Suh-weet...another script retired...
  6. #26
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    This plugin alone should eliminate a lot of little scipts because it couldn't be done with the std RR cmds.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #27
    Aug 2006
    Sun Diego
    How about a list of available drives on the PC?
    In short, I want to completely retire filemanger.exe from my skin as an embedded plugin and the last detail I need is a list of available drives.
    The way I have it working now is that I have an AI script get the PC drive info, create a txt file and load that info into a CL list.
    I, then take the drive CL info, open a new screen that has a DL and use "SETPATH" to set the dir. From there, I just your filecopy/move cmd and deletefile for...whatever.
  8. #28
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Format suggestions or where to store the info?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #29
    Aug 2006
    Sun Diego
    I haven't tried it yet, but maybe an rrl file that acts in a similar way the audio browser display the browse.rrl file?
    EDIT: I'm thinking something like "$pluginspath$\RRExtended\drives\browse.rrl"
    I figure that loading the first screen, I can set DL list to the path above so that only the drives show.
    Ideally, I would prefer to keep the filemanagement stuff in one screen rather than select a drive from a CL list and browse the drive in a DL list.
    i.e.
    Load;MyComputer.skin
    Has:
    BXX,...,"FILECOPY"
    BXX,...,"FILEMOVE"
    BXX,...,"DELETEFILE"
    with a:
    DL contains
    Local Drive [C:]
    DVD Drive [D:]
    Local Drive [E:]
    From there I can browse thru the drives. Copy files from C:\whatever to E:\whatever with a toggling button to get the source path and destination path.
    Otherwise, a text file in the plugin's directory would work and I can just create two working skin screens.
  10. #30
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Will look into that.,,
    Another feature in prosess of being added is "RRFob"
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Volume too low on AUX line in, coming out of laptop.
    By Silenkiller in forum Car Audio
    Last Post: 10-07-2008, 08:45 PM
  2. iPod Integration Coming
    By Lazyflip in forum Centrafuse
    Last Post: 03-20-2008, 01:14 AM
  3. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 01:07 PM
  4. NEW playstation II portable keyboard coming out soon
    By clean customs in forum Input Devices
    Last Post: 03-04-2005, 04:37 PM
