Page 6 of 34 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 331
Thread: RRExtended [ v1.20 Updated 01/21/12 ]
  1. #51
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Looking Good
    2001 S10 ZR2
    Chucks Skin - to old
  2. #52
    Variable Bitrate kelmk's Avatar
    Aug 2007
    SF
    Can I use the day/night events to switch the background image?
  3. #53
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    You can do that, and any other day/nigth task that might need to be done...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #54
    Aug 2007
    SF
    Do you know what the code is to change the background image?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    small fix for next version
    RRCalc will right align the textbox to look more like a calc is supposed to look and keep the cursor at the right.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #56
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    You can use "SaveToSkin;background;<path to file to use>||Reloadskin".
    You will need the reloadskin on the end because rr will use the same set background for each screen once it has been loaded, even if you change it after.
    Your example event commands in your Exectbl.ini might look like this.
    Code:
    "DayTimeEvent","SaveToSkin;background;$RRPATH$BACKGROUND\Day.jpg||Reloadskin"
    "NightTimeEvent","SaveToSkin;background;$RRPATH$BACKGROUND\Night.jpg||Reloadskin"
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #57
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok from running the risk of getting called dumb again, i'm having problems here
    1st off the day/night events, dos'nt seem to do anything,
    1: X,RREXTENDED in plugins.txt and plugin in plugin folder (rr Root)
    2: have the settings for this section in skin.ini
    3: exetbl.ini i have
    "DayTimeEvent","RUN;$skinpath$DAY_NIGHT.exe|DA Y"
    "NightTimeEvent","RUN;$skinpath$DAY_NIGHT.exe|Nigh t"
    "SunSetEvent","RUN;$skinpath$DAY_NIGHT.exe|DAY "
    "SunRiseEvent","RUN;$skinpath$DAY_NIGHT.exe|Ni ght"
    i'm assuming the the 1st 2 CMD's are for DNE_Enabled= false in skin.ini and the 2nd 2 are for DNE_Enabled= true.
    but nothing is happening
    2nd problem
    RRNumosktocmd i do get the scr appear but the enter button (B,x,x,x,x,RRENTER)
    is not working.
    i'm using this line to launch
    RRNUMOSKTOCMD;1;DAYTIME;SAVETOSKIN;DNE_DayEventTim e;#DAYTIME#
    i thank you
  8. #58
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No, all four of those are the custom cmds that it executes at those times. The reason you are getting nothing is that your "DNE_Enabled=false" is turning off that feature.
    Try setting that to true, other than that, i'm not sure what fall back your using for the time/loc, ie current gps, static gps coords, static time or nothing with will use the hard coded times.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #59
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    so its 1 or the other execute cmds
    the switch yes i was hoping it was to turn off the automatic gps times so the end user can use their own times , which was read from the ini times .
    because the gps mouse is on all the time i thought the plugin uses that and the switch ,switchs it off to use the fall back ,
  10. #60
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The enable setting completely turns the feature On or Off. As for the fall backs, they are built in and work in the order thats posted. As of current, there is no way to specify which method to use for the time calculation.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Volume too low on AUX line in, coming out of laptop.
    By Silenkiller in forum Car Audio
    Last Post: 10-07-2008, 08:45 PM
  2. iPod Integration Coming
    By Lazyflip in forum Centrafuse
    Last Post: 03-20-2008, 01:14 AM
  3. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 01:07 PM
  4. NEW playstation II portable keyboard coming out soon
    By clean customs in forum Input Devices
    Last Post: 03-04-2005, 04:37 PM
