Page 7 of 34 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 331
Thread: RRExtended [ v1.20 Updated 01/21/12 ]
  1. #61
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    so can or will it be be an option, so we can choose which form of time format to use ,
    either autogps with fall backs or manual time enetered by user without gps
  2. #62
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok i admit defeat on this , if i look at my code anymore i will go blind.
    sorry still day/night event , i have it enabled (true), i'm only useing times as a fall back.
    it seems like the plugin is trying to do somthing because my tag scroll slows when a plugin is doing its thing. but no changes at times set.
    i know my execute cmd is good as i use this for a manual switvh to switch between day/night settings, so it only leaves the plugin. i even switched all other plugins off .
    also the rrnumosk rrenter is doing nothing too , so some help would be good please.
    i was going to try another part of the plugin , but i fear i will end up with the same result something dose'nt work, i know the plugin is running otherwise i would'nt get the rrnumosk to appear i would persume.
    sorry and cheers for any help.
  3. #63
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    If you don't have the skintool, get it. Then with it properly added open skintool.exe to the live debug and start up rr with that feature enaled and see if you get any night/day event cmds issued. If not, open up your sys clock and change the am/pm, apply and within a few seconds you should see the cmd for which time of day you switched to in the log window.
    Other than that, show your rr.ini lines for this PI, lines from the exectbl.ini file for cmds to execute and what is your sys time format.
    Then we'll go from there..
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #64
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    will do , mmmmmm sytem time that might be it mines 24hr standard way for me
  5. #65
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok got skintool running , started rr , in live de-bug nothing to do with your plugin atall in there, changed system clock from am - pm and back again with skintool running nothing.
    system clock is now 12hr format displayed as 05.45pm and 06.30am
    attached is my exectbl.ini lines ,rr.ini with settings there ( only useing times)
    as i have no gps .also added my rr de-bug just incase.
    now this is running on a freash installed comp XP pro, and latest rr apart from editor and Photoshop there is no other apps on this system , all other plugins installed are working fine.
    its bound to be somthing simple , thanks
    Attached Files Attached Files
  6. #66
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by carputer1
    Funny.....It was!
    Now Fixed! And added new setting.
    DNE_Mode= (0=Auto, 1=Static Lat/Lon, 2=Static Time)
    If setting not specified or is missing, will default to auto.
    Also, you have a "(" on the end of your nighteventtime setting that needs to be removed.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #67
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    thanks blue , the ( was a miss type error , when i was last playing with got put there by accident.
  8. #68
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    FYI it works , on 1st run i did set the wrong exe it set night when it was in night already , but then 1 mim later it changed to day setting, then after that changing the am/pm in system clock ,changed my settings correctly.
    and thanks for adding the mode setting just what i was after,
  9. #69
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    "ONSCREENCHANGE" not working?
    "ONSCREENCHANGE","PlayWav;$SKINPATH$Installs\sound\page.wav"
    some screen changes work and some don't
    2001 S10 ZR2
    Chucks Skin - to old
  10. #70
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Today I tried to setup the day night stuff and I can't get it working and when I Enable the DayNightEvents the PLAY;whatever stops working.
    ini
    DNE_Mode=2
    DNE_Enabled=True
    DNE_DayEventTime=7:14 AM
    DNE_NightEventTime=4:44 PM
    ExecTBL
    "DayTimeEvent","DAYTIME"
    "NightTimeEvent","NIGHTTIME"
    "SunSetEvent","NIGHTTIME"
    "SunRiseEvent","DAYTIME"
    2001 S10 ZR2
  1. Volume too low on AUX line in, coming out of laptop.
    By Silenkiller in forum Car Audio
    Last Post: 10-07-2008, 08:45 PM
  2. iPod Integration Coming
    By Lazyflip in forum Centrafuse
    Last Post: 03-20-2008, 01:14 AM
  3. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 01:07 PM
  4. NEW playstation II portable keyboard coming out soon
    By clean customs in forum Input Devices
    Last Post: 03-04-2005, 04:37 PM
