That update should take care of your issues Chuck...
The problem was becuse you only spec the setting that you were gonna use, and it was looking for all of them...
Let me know if you still have probs after that..
Update...v1.02
See first post
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
Thanks Blue
I will check it out.
Just some FYI..
The DayNightEvent (DNE) times can be in either 12 or 24 time format..
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
excellent will try tonight
ok looking good here so far short test on DNE.
reset my system clock to 24hr again plugin dose its job .
1 thing i have noticed (useing times only ) i get a double exe on night change.
is this because i have the 4 exe's in my exectbl file, i don't see anything in skintool.
but its not always happeneing,
i persume the dayevent/nightevent, are for the times and fall backs
and the sun/rise exe's are for the auto gps part,
if this is the case can the sun/rise exe's be turned off if set to another setting not auto.
if i'm wrong in my set up please say
thanks
ENJOY
You are a little off base...
All of the events are using the same fall back mode. I'm thinking that the reason that your are getting dbl executions is because you have both the day/rise and night/set set to the same thing. ie... the sunset time comes up and then executes that cmd..then the nighttime rolls around and executes that command for which you have both set.
Simple solution for what your using it for, is to just eliminate the rise/set cmds.
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
The day night stuff seems to be working now but I notice that you cannot change stuff on the fly so if you change a setting you need to restart RR or it will not take affect.
SETVAR;DNE_Enabled;TRUE||SAVETOSKIN;DNE_Enabled;TR UE
SETVAR;DNE_Enabled;FALSE|| SAVETOSKIN;DNE_Enabled;FALSE
SETVAR;DNE_DayEventTime;7:00 AM
So if you use hibernation and change a setting you need to restart RR
ok thank you
thought it might be that ,
@chuck
i have not incountered that myself , but saying that all my settings are in my skin.ini not rr.ini.
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
