Page 9 of 34 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 331
Thread: RRExtended [ v1.20 Updated 01/21/12 ]
  1. #81
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    day night event is working smoothly FYI
    also found out , well for me anyway, for the times in the skin.ini / rr.ini
    you don't need am or pm written in the settings, which for me is a good thing.
    cheers blue , i shall move on to something else in exteneded and let you know.
    ENJOY
  2. #82
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I have seen some minor issues with some of the other features but I'm working on getting them all squashed, so that I can jump to do the same with my other PI's.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #83
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    just a thought if pos. on change from day - night, and visa versa, can the scipt remeber the last scr it was in and reload that scr after a reload of skin
    ie. say i was in browser when then event takes place, it reloads the skin, then takes you back to browser.
    i assume you the only way is by useing the screen name in the skin files.
  4. #84
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That is easy...can do that all in RR code.
    1. Put current screen into a variable (SETVARBYCODE;CURRSCRN;RRSCREEN)
    2. Save to the skin.ini file for latter (SAVETOSKIN;LSTSCN;$CURRSCRN$)
    3. Duh ( RELOADSKIN )
    4. Load back original screen using saved variable (LOAD;$LSTSCN$)
    PHP Code:
    "SETVARBYCODE;CURRSCRN;RRSCREEN||SAVETOSKIN;LSTSCN;$CURRSCRN$||RELOADSKIN||LOAD;$LSTSCN$"
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #85
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    thanks for the spoon feed , will try it tonight
    all good mate cheers, had to add it to my AI script, as i have a reload in there.
    but works a charm.
    again thanks
    ENJOY
  6. #86
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    day / night event now works as i invisioned it to be like . thanks for the time blue i think unless you have spotted anything else this 1 can be put to bed now.
    the mode switch now works stand alone , meaning on which ever mode you have it on , it will only use those times, giving the user 3 choices of times that can be used.
    gps time via gps mouse, gps static time via manual enter of lon/lat cords and finally manual times via manual entereing your prefered times.
    all these setting can be set from within the skin, i have also added use rrgps cords, so where ever you are you can save these cords to static lon/lat times,
    for me this is tops, finally a theme change timer that works great, well worth the time i put in over my time off.
    again cheers
    ENJOY
  7. #87
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Insight for version 1.03
    Fixed RRNumOskToCmd, not working properly
    Fixed RREnter, now clears osk textbox on exit
    Added DNE_Refresh cmd, to use the current saved settings w/o reloading skin (Req by chuck)
    Added DNE_Enable cmd, realtime on/off of feaure w/o saving setting
    Added TxtBoxToVar cmd, sets a var from the contents of a textbox, for super custom osk's
    Added RRCalc_Func label, displays current function
    Release of RRHostWatcher (RRHW), previously hidden
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #88
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Update...
    v1.03 released, see first post
    I also added reference skins in the skin folder inside the plugin folder
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #89
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Thank you
  10. #90
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Nice.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  1. Volume too low on AUX line in, coming out of laptop.
    By Silenkiller in forum Car Audio
    Last Post: 10-07-2008, 08:45 PM
  2. iPod Integration Coming
    By Lazyflip in forum Centrafuse
    Last Post: 03-20-2008, 01:14 AM
  3. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 01:07 PM
  4. NEW playstation II portable keyboard coming out soon
    By clean customs in forum Input Devices
    Last Post: 03-04-2005, 04:37 PM
