Page 1 of 34 1234567891011 ... LastLast
Results 1 to 10 of 331
Thread: RRExtended [ v1.20 Updated 01/21/12 ]
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    This is a both a HUGE collection of very useful cmds and a combination of all my smaller plugins, all in one plugin.
    Feature Set
    -RRCalc
    -RRStrings
    -RRSpeak (Curr ver req Sapi5)
    -PlayWav
    -RROSKTOCMD
    -RRNUMOSKTOCMS
    -RRFileCopy
    -RRFileMove
    -"ONSCREENCHANGE"
    -DayNightEvents from my other plugin
    -RRWarningWatcher [HL]*updated[/HL]
    -RRResumer
    -"BYSTR" Cmd
    -RRVolRamper (req's RoadRunner build 10/10/08 or latter)
    -RRFob
    -RRFileMgr
    -RRSkinGen
    -RRHostWatcher
    -RRPlyr
    -TxtBoxToVar
    -RunningApps ( from my other plugin and upgraded )
    -ProcWaitClose
    -IniKeyToVar
    -VarToIniKey
    -FileSrchRepl
    -Global Timer(s)
    -LoadFontList
    -GetMouseColor
    -SetFontPV
    -SetFontPVColor
    -IndPoller
    -GpsIndFix ( from my other plugin )
    -"PresetList" command
    -"BYRANGE" command
    -"BYSCRN" command
    -"BYLBL" command
    -TaskManage
    -ElaspedTmr
    -DateOSK
    -TimeOSK
    -LCASE
    -UCASE
    -PCASE
    -SmoothAvg
    -SAVENSETTOSKIN
    -SAVENSETTOINI
    -RndVar
    History
    ver 1.20 [ Released 01/21/12 ]
    Fixed issue when RR player was set to BASSRR
    Updated most of code to use RR SDK's Get/Set UserVar methods
    ver 1.19 [ Released 05/01/11 & 05/05/11]
    Fixed GblTmr_Del cmd
    Fixed RndVAR cmd, now immediately set var to new value before returning
    Added Additional GblTmr logging (Started,Stopped,Reset)
    ver 1.18 - 1.00
    See History.txt in plugin folder
    See the RRExtended Notes.txt for feature cmds & syntax's
    Attached Files Attached Files
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    * RRSpeak *
    Description
    Functions the same as the internal cmds execpt that it can be set independantly of RR's voice setting.
    Main reason for this was to make a work around for when RR starts saying all the executed cmds instead of
    only speaking when told to speak.
    Commands
    "RRSpeak"
    Syntax: "RRSpeak;<phrase to speak> or <ON>,<OFF>"
    Example: "RRSpeak;Road Runner, welcome to thee number 1 front end!"
    Result: Phrase spoken
    Example: "RRSpeak;<ON>"
    Result: Turns on RRSpeak for speaking and saves setting
    You can do that already with the TALK command. Turn Voice off in rrconfig and use TALK instead of SAY. Only problem is the volume. TALK Command is overlaid. Are you planing on lowering the volume of other sources when RRSpeak is executed?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Well, I wasn't aware of the diff Talk/Say, but could do something to fix/add said issue.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Cool.
    For RR Calc, can you add a "tickertape" feature?
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    When I revise that func, I'll see. Output to a CL? Could then save for latter if wanted.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Aug 2006
    Sun Diego
    A CL is what I figured.
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Blue do you think you could add a command called ONSKINCHANGE similar to ONSONGSTARTso when you go from skin to skin it would trigger it. You could use it for many things such as every time you go to a skin or exit from another skin to that skin you could have that trigger like.
    Code:
    "ONSKINCHANGE","Showwindow;windowname;true||MUTE||SETLABEL;MESG;gogo”,Clock.Skin
    "ONSKINCHANGE","PlayWav;$RRPATH$GAME\GAME.MP3",GAME.Skin
    Would be nice if it was in RR it self but this woud be a good place for it.
    2001 S10 ZR2
    Chucks Skin - to old
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That can and will be added, but called "ONSCREENCHANGE" and will be executed (before/after?) the "LOAD" or "MENU" cmds.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    I guess it would be after the load or menu or when “RRSCREEN” name changes so it would trigger after going into or after exiting a skin.
    “ONSONGSTART” triggers after the song changes
    2001 S10 ZR2
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ok, this now executes a "ONSCREENCHANGE" when loading,exiting,escaping,canceling on any screen.
    Also RRCalc will have a TicketTape via a customlist
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Volume too low on AUX line in, coming out of laptop.
    By Silenkiller in forum Car Audio
    Last Post: 10-07-2008, 08:45 PM
  2. iPod Integration Coming
    By Lazyflip in forum Centrafuse
    Last Post: 03-20-2008, 01:14 AM
  3. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 01:07 PM
  4. NEW playstation II portable keyboard coming out soon
    By clean customs in forum Input Devices
    Last Post: 03-04-2005, 04:37 PM
