Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 53
Thread: RRGrid - A TS Friendly Game/Puzzle Status: Updated 19/09/2010
  1. #21
  2. #22
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I don't know why rrgrid stop the good RR's use . I am obliged to unregistered the dll and after rr run again .
    I have the same problem with the El Camino,'s Movie Info Plugin .
    (On Xp or Vista) .
  3. #23
  4. #24
    May 2008
    Bordeaux, France
    Quote Originally Posted by Enforcer View Post
    So are you saying it still does it, or does it now work?
    Hi enforcer,
    No , it don't run , RR freeze .
  5. #25
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Can you add debug=true to the ini file and then send me the debug.txt, grid.ini and rr.ini and riderunners debug.txt
    Cheers
  6. #26
    May 2008
    Bordeaux, France
    Cheers
    This is my debug files .
    For create them , I have registered the rrgrid dll and RR don't ran .
    I have unregistered the dll and RR ran well .
    I am on vista ultimate
    Attached Files Attached Files
  7. #27
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Looks like it is having an issue with the files in the c:\071028af57e2a4d214d130908f9b2747\amd64 folder.
    I will add an option to omit the harddrive search, plus get it to continue if it can't read a file.
  8. #28
    May 2008
    Bordeaux, France
    Thanks Enforcer, i am impatient .
  9. #29
    Oct 2007
    hello
    in grid.ini you say to use picpath... but which is it?? I must create a folder in RR...?? the file grid.ini where I must put it..??
    best regards
    ammerelli
  10. #30
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Picpath is a setting in RRConfig (RR.ini) for where your pictures are.
    UsePicPath is simply true or false, depending on whether you have this set and want to use the pictures there.
  1. NMC 07 development status
    By netsuo in forum NeoCar Media Center
    Last Post: 11-03-2004, 04:18 AM
