Page 1 of 6 123456 LastLast
Results 1 to 10 of 53
Thread: RRGrid - A TS Friendly Game/Puzzle Status: Updated 19/09/2010
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    This is just a quick, simple and fun plugin.
    Updated 19/09/2010
    Click the button below to get it from my forum
    v1.2
    Save best times and moves per image
    Display Previous best times and moves.
    Added a settings screen.
    Choose an image from the list of images
    Pause game (clock stops but image disappears (no extra cheating )
    Retry last image.
    Support for other extensions other than just .jpg's (ie BMP, PNG)
    v1.1
    Q. What does it do?
    A. Basically it searches your drive (well first it looks in your picspath folder and then your backgrounds folder) and makes a list of all the .jpgs it can find. It then randomly chooses one which it then displays and then jumbles it up.
    Your job is to put it back together.
    Your have a cheat button which will display a small thumbnail for 5 seconds, upto 3 times.
    If you solve it you will be told how long and how many moves it took you.
    Too hard? then you can skip that image.
    Skin commands
    Buttons
    rrgrid - loads grid.skin
    main screen
    rrgrid_start - Jumbiles tiles
    rrgrid_cheat -show a thumbnail of image (max 5 times)
    rrgrid_skip - skip current image
    rrgrid_retry - ReDo last image
    rrgrid_imageselect - Load image browser
    rrgrid_pause - Pause current game
    rrgrid_settings - Bring up settings menu (this can be done in any screen of rr)
    Image browser
    rrgrid_select - Select image from browser
    rrgrid_up - Up
    rrgrid_pgup - Page Up
    rrgrid_pgdown - Page Down
    rrgrid_down - Down
    Settings Screen
    rrgrid_drive - bring up OSK to type in path to search for images
    rrgrid_extensions - Bring up extensions select list
    rrgrid_settingsapply - Apply changes to settings
    extensions Select list
    rrgrid_addextension - Add highlighted extension
    rrgrid_delextension - Delete extension
    Labels
    rrgrid_time - elapsed time
    rrgrid_moves - Number of moves made
    rrgrid_status - Lets you know what is going on.
    rrgrid_best - used with status to compare how you did against previous best scores
    rrgrid_localdrive - Current path to search for images
    rrgrid_bestmoves - Lowest no of moves for image
    rrgrid_besttime - Best time for this current image
    rrgrid_extensions - The extensions currently selected.
    Indicators
    rrgrid_cheat - Cheat thumbnail
    In the following # is (0-15)
    rrgrid_# - Tile images
    rrgrid_cheat - shows cheat image.
    rrgrid_picpath - Show whether RR picpath should be used
    rrgrid_backgrounds - show whether RR's backgrounds should be used
    Screenshots
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Example skin files
    Default skin
    Carwings Dynamic, this is included with the installer
    _
    Optional Skins
    iDrive Transparent 3.00 (RRGrid-iDriveT.zip)
    _
    iDrive Night Red 3.00 (RRGrid-iDriveNR.zip)
    _
    iDrive Night Green 3.00 (RRGrid-iDriveNG.zip)
    _
    Attached Files Attached Files
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    F.a.q
    f.a.q.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    this should be fun , the wife dose these sort of puzzles all the time on the net.
    i have to have this , as its another shut the wife up while driving programs , i love these lol...
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I love it
    Hello all ,
    Very very fune puzzle for RR .
    I love it .
    Thanks for all Enforcer !!!
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    strange i'm getting nothing , X,rrgrid in plugins.txt , rrgrid folder and contents in plugins folder (RR root), skin files in the skin folder , rrgrid as the launch button nothing.
    its like the plugin is not starting i even removed my INC,Plugins.txt and put X,rrgrid in the menu.skin still nothing
    and yes i did read this time lol... evrything is correct
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Did you run register.bat?
    Check the RoadRunner debug.txt to see if there is an error loading the plugin.
    Add debug=true to grid.ini
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i have the power to keep my wife quite lol...
    missing a OCX file PICCLP32.OCX
    cheers E
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Request if pos, a score Board , on complete of puzzle it creates a file which holds the jpg name , time taken , amount of moves, and by who , then you can have a button that loads a popup with that info in it , may need to be able to scroll up and down , or just saves the top 10 scores ,
    and would it be pos to force a image manually picked from a list . image ind i think will be needed as well.
    cheers E
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by carputer1 View Post
    cheers E
    Damn, that thing again.
    OK added to download file.
  1. NMC 07 development status
    By netsuo in forum NeoCar Media Center
    Last Post: 11-03-2004, 04:18 AM
