Results 1 to 5 of 5
Thread: MJS UAS4 Plug-In
    MySQL Error
    Oct 2004
    Arrow MJS UAS4 Plug-In
    The setup will do all the work for you
    06/14/10 UPDATED to support change of HDRadioPort to RadioPort (either will work)
    12/19/09 UPDATED with the new Hardware PID
    ALL UPDATED with the new RR API
    from the readme...
    Code:
    RoadRunner Extension Plugin for MJS Gadgets UAS (USB Audio Selector)
    MJS Gadgets UAS - available at www.mjsgadgets.com
    !	Requires .net 2.0 framework
    ** SKIN COMMANDS
    mjsuasinput1				- switches to input #1
    mjsuasinput2				- switches to input #2
    mjsuasinput3				- switches to input #3
    mjsuasinput4				- switches to input #4
    ** SKIN LABELS
    mjsuasinput					- returns current input
    ** RR.INI
    [MJS Gadgets UAS]
    radiouasinput=x			- switch to input x (1-4) when "RADIO" is executed
    xmuasinput=x				- switch to input x (1-4) when "XM" is executed
    sruasinput=x				- switch to input x (1-4) when "SIRIUS" is executed
    										- set x to 0, or leave out of RR, and no UAS switch occurs
    ** USAGE NOTES
    The simplest way to use the plug in, is to use 1 or more of the
    RR.INI options then when say "XM" command is executed, it will
    automagicly switch the input.
    ** THANKS
    I want to thank sonicxtacy02, for his general prodding and poking
    and answering questions about RR Extension plugins
    ** HISTORY
    V1.1.0.3  updated for change in RR.ini setting (HDRADIOPORT is now RADIOPORT)
    V1.1.0.2  updated for new RR API (Initialize)
    V1.1.0.1  updated for new RR API
    Attached Files Attached Files
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    Updated
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    Updated to 1.2.0.1
    only change is API (now at SDK Standard)
    ALSO... INSTALLER IMPROVED
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    Updated to 1.2.0.2
    supports new hardware PID
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    Updated to 1.2.0.3
    fixed internal issue with newest RR, using RadioPort, vs HDRadioPort
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. MJS Gadgets UAS - Centrafuse Plug in!
    By mitchjs in forum CF Plugins
    Last Post: 09-03-2008, 08:06 AM
  2. USB plug hard wired to glovebox
    By sky_lennard in forum Power Supplies
    Last Post: 09-30-2007, 12:52 AM
  3. Where to Buy 3 Contact DC Power Plug
    By tallyman in forum General MP3Car Discussion
    Last Post: 03-18-2007, 10:53 PM
  4. EPIA MII 10000 onboard USB plug help
    By guizai in forum General Hardware Discussion
    Last Post: 01-26-2007, 07:08 PM
  5. Replies: 5
    Last Post: 07-12-2003, 02:43 AM
