Page 10 of 20 FirstFirst 12345678910111213141516171819 ... LastLast
Results 91 to 100 of 197
Thread: RRShoutCast- Shoutcast Plugin
  1. #91
    Feb 2006
    New Jersey
    Cool can't wait for the next release...
  2. #92
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    ok the 5/13 version is now available for download. Check post 1. Summary of changes:
    -Removed use of winampfrontendlib.dll. (delete file from your plugin folder for existing installations)
    -Added SELECTED labels as well as CURRENT labels
    -Changed/Added skin files
    -Added debug log
    -Added Sort by options: ListenerCount, ABC(alphabetically), and Bitrate *See Note
    -Changed track update interval to 3 seconds
    -Added ability to set SCAN interval
    *Remember that ABC and Bitrate sort options still follow the Station limit guideline. So if channels are missing from either of those lists please increase your station limit. Also, the bitrate sort option results are limited to the following bitrates: 320,256,192,160,128,96,64,56,48,32. If you know of another bitrate that shoutcast streams at by all means let me know and i will add it.
    Live mp3Car Facebook Chat
  3. #93
    Feb 2006
    New Jersey
    Just tried it.. when I press the button I have set for the plugin nothing happens. Here is the debug log:
    Exception Cannot create ActiveX component. occurred [Wednesday, May 13, 2009]
    Exception Object reference not set to an instance of an object. occurred [Wednesday, May 13, 2009]
    [5/13/2009 4:52:11 PM]RRShoutcast Resume Read. RRShoutcast resume state is Off
    [5/13/2009 4:52:11 PM]RRShoutcast Audio Resume Read. Audio List Position is and Track Time is
    [5/13/2009 4:52:11 PM]Sort option read.
    [5/13/2009 4:52:14 PM]Internet Found, Downloading Genre.xml
    [5/13/2009 4:52:14 PM]RRShoutcast Not Resumed. Trackname Update Timer Halted.
  4. #94
    Woodbridge, VA
    Blog Entries
    55
    did you re-register? what version of RR are you using?
  5. #95
    Feb 2006
    New Jersey
    Yes, and I'm using 11/07. Your original version worked fine for me.
  6. #96
    Woodbridge, VA
    Blog Entries
    55
    my original version used RoadRunner.sdk... the new version uses Riderunner.sdk. I'll send you a .dll that reverts back to Roadrunner.sdk in the morning... as i understand ur reservations in updating. I just dont know that all featurewill work with Roadrunner.sdk. Stay tuned.
  7. #97
    Feb 2006
    New Jersey
    I just updated... same problem
  8. #98
    Feb 2006
    New Jersey
    Updated... still not working, but debug log changed...
    [5/13/2009 6:14:13 PM]Communcation with Riderunner.SDK Enabled
    [5/13/2009 6:14:13 PM]Station Limit Read from RR as
    [5/13/2009 6:14:13 PM]RRShoutcast Resume Read. RRShoutcast resume state is Off
    [5/13/2009 6:14:13 PM]RRShoutcast Audio Resume Read. Audio List Position is and Track Time is
    [5/13/2009 6:14:13 PM]Sort option read.
    [5/13/2009 6:14:22 PM]Internet Found, Downloading Genre.xml
    [5/13/2009 6:14:22 PM]RRShoutcast Not Resumed. Trackname Update Timer Halted.
  9. #99
    Feb 2006
    New Jersey
    I had my radio button set to load RRShoutcast like this "B04,11,186,296,106,"RRShoutCast","ShoutCast Radio""... that always worked until the new version. My friend told me to try this "B04,11,186,296,106,"LOAD;rrshoutcast.skin;","Shou tCast Radio"". This loads the skin, but nothing happens, no station list loads or anything.
  10. #100
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    Same here, skin shows , nothing happens...
    [5/13/2009 8:33:16 PM]Communcation with Riderunner.SDK Enabled
    [5/13/2009 8:33:16 PM]Station Limit Read from RR as
    [5/13/2009 8:33:16 PM]RRShoutcast Resume Read. RRShoutcast resume state is Off
    [5/13/2009 8:33:16 PM]RRShoutcast Audio Resume Read. Audio List Position is and Track Time is
    [5/13/2009 8:33:16 PM]Sort option read.
    [5/13/2009 8:33:17 PM]Internet Found, Downloading Genre.xml
    [5/13/2009 8:33:17 PM]RRShoutcast Not Resumed. Trackname Update Timer Halted.
  1. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
