Page 11 of 20 FirstFirst ... 234567891011121314151617181920 LastLast
Results 101 to 110 of 197
Thread: RRShoutCast- Shoutcast Plugin
  1. #101
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    your launch command is wrong. Check out skin commands.txt. The command is "RRSHOUTCAST;", "RRSHOUTCAST;GENRE", "RRSHOUTCAST;STATION", or "RRSHOUTCAST;FAVORITES" depending on which load option you want.
    Live mp3Car Facebook Chat
  2. #102
    Feb 2006
    New Jersey
    Quote Originally Posted by Sonicxtacy02 View Post
    Ok, skin loads up now and loads genre list. Now, when I select a genre from the list, it goes to a blank list.
    Debug Log:
    [5/13/2009 9:26:48 PM]Communcation with Riderunner.SDK Enabled
    [5/13/2009 9:26:48 PM]Station Limit Read from RR as
    [5/13/2009 9:26:48 PM]RRShoutcast Resume Read. RRShoutcast resume state is Off
    [5/13/2009 9:26:48 PM]RRShoutcast Audio Resume Read. Audio List Position is and Track Time is
    [5/13/2009 9:26:48 PM]Sort option read.
    [5/13/2009 9:26:53 PM]Internet Found, Downloading Genre.xml
    [5/13/2009 9:26:53 PM]RRShoutcast Not Resumed. Trackname Update Timer Halted.
    [5/13/2009 9:26:55 PM]Command 'RRSHOUTCAST;' pressed
    [5/13/2009 9:26:55 PM]Internet detected at load. No need to download genre.xml
    [5/13/2009 9:26:55 PM]RRShoutcast Status is Off
    [5/13/2009 9:26:57 PM]List Type Set to Genre
    [5/13/2009 9:26:57 PM]loading RRShoutcast.skin
    [5/13/2009 9:26:57 PM]Custom list cleared
    [5/13/2009 9:26:57 PM]genre.xml read
    [5/13/2009 9:27:09 PM]Genre list entry pressed
    [5/13/2009 9:27:09 PM]Internet found. Pulling station list
    [5/13/2009 9:27:10 PM]Station list information timer enabled. Receiving station data.
    [5/13/2009 9:27:10 PM]List type is Station
    [5/13/2009 9:27:15 PM]Last genre Acid writtin to skin.ini
    [5/13/2009 9:27:15 PM]custom list cleared
    [5/13/2009 9:27:15 PM]station from genre 'Acid' downloaded.
    Exception Root element is missing. occurred [Wednesday, May 13, 2009]
    [5/13/2009 9:27:15 PM]Genre pull function initiated.
    [5/13/2009 9:27:15 PM]Genre pull timer stopped.
    I have this in the menu.skin file:
    X,RRShoutCast
    and
    B04,11,186,296,106,"RRSHOUTCAST;","ShoutCast Radio"
    Is there anything wrong with this?
  3. #103
    Woodbridge, VA
    Blog Entries
    55
    hmmm trouble reading the .xml. show me stationlist.xml. What sort type are you using? What station limit?
  4. #104
    Feb 2006
    New Jersey
    It is blank. The plugin creates a blank one. I didn't change any limit or anything.
  5. #105
  6. #106
    Woodbridge, VA
    Blog Entries
    55
    I'll have to do more testing in the morning. The thing is nothing changed in the download procedures. We'll see what we can figure out.
  7. #107
    Feb 2006
    New Jersey
    Yeah, please check it out. I'm very eager to use this, I really like the new setup.
  8. #108
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    just dl'ed works , labels are abit off can't explain right now later for work, but it looks like the now playing is not updateing, the selectable labels i have to come out of shoutcast screen then back in to get them to update or even show atall,also the top labels now playing show next track ,not current track.
    also if i'm reading the cmds right the bottom select labels should give info of station in list while top labels give you info of current playing station.
    now the select labels are not updateing on highlighting a station in list ,
    also having trouble swapping stations i select 1 to play the top labels change, but the station dose not,
    so far thats all , fav's works better now i can load stations back in ok, its just the labels not updateing. any1 else got this . take this test as a possiable problem, i may have to look into things a bit more when i get home tonight.
    cheers Sonicx's great improvment
  9. #109
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by mnetwork View Post
    Quote Originally Posted by pcpete View Post
    Same here now...
    do me a favor and add the following lines to your .skin.ini
    RRSHOUTCAST_STATIONLIMIT=1000
    RRSHOUTCAST_LASTGENRE=Acid
    RRSHOUTCAST_SCANINTERVAL=10
    and run RRSHOUTCAST;genre again. Select a genre, and see if your station list appears. I dont see any reason stationlist.xml isnt downloading.. i'm simply using DownloadFile method from vb.net.
  10. #110
    Woodbridge, VA
    Blog Entries
    55
    Keep in mind that "Now Playing" isnt what its called anymore. Its whatever station is playing when the station was loaded. Technically, the Now Playing song is only shown in TRACKNAME. The select labels are based in the built in "ONCLCLICK" event made available in the april RR release. What RRVer are you using. Do you have any other "ONCLCLICK" events in your skin?
    If you select a station but it doesnt tune but the labels populate check the file shoutcast.m3u in Support folders. It should contain the URL to the station being tuned. Does it?
    Quote Originally Posted by carputer1 View Post
    Thank you all for your feedback. Its only gonna make the plugin better.
  1. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
