Page 12 of 20 FirstFirst ... 234567891011121314151617181920 LastLast
Results 111 to 120 of 197
Thread: RRShoutCast- Shoutcast Plugin
  1. #111
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok i will have a look again in about 2 hrs , i dohave other oncl in the skin but they are set to that percific skin not global in the skin, RRver is yesterdays latest,
    but now i know more about the labels i'll double check for you ,
  2. #112
    Feb 2006
    New Jersey
    Quote Originally Posted by Sonicxtacy02 View Post
    do me a favor and add the following lines to your .skin.ini
    RRSHOUTCAST_STATIONLIMIT=1000
    RRSHOUTCAST_LASTGENRE=Acid
    RRSHOUTCAST_SCANINTERVAL=10
    and run RRSHOUTCAST;genre again. Select a genre, and see if your station list appears. I dont see any reason stationlist.xml isnt downloading.. i'm simply using DownloadFile method from vb.net.
    This fixed it. Now after I select a station, how would i get back the genre list? I really like how when I come back to the plugin (even after exiting rr) it comes back to genre and station selection that I last had, but how do I get back to genre list again?
  3. #113
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by mnetwork View Post
    Thats great news!. To go back to genre list run the command "RRSHOUTCAST;genre". That command can be run from any skin.
    Live mp3Car Facebook Chat
  4. #114
    Feb 2006
    New Jersey
    Yeah I get it. Would you be able to add another button that would bring you back to genres?
  5. #115
    Woodbridge, VA
    Blog Entries
    53
    try RRSHOUTCAST_BACK. I believe thats still in there. It will take you back to a genre list without re-downloading genre.xml. I kinda forgot that command.
  6. #116
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok having major problems here, i miss informed you sonic's sorry i was'nt useing latest rr but the 1 before, so i installed latest and all hell broke lose , could not load shoutcast skin from any cmd, lost my directsound winamp crashies all the time, so to make sure its not your PI i went back to 18/04/09, version the onclclick is not working here sorry mate.
    please read pm sent thanks
  7. #117
    Feb 2006
    New Jersey
    I meant could you make a nother button in the skin, but I just changed the station scan button to be the Genre List button since I will probably never use the station scan feature.
  8. #118
    Woodbridge, VA
    Blog Entries
    53
    just double up on one of the buttons. Double the select button so that CLICK selects and HOLD goes back
    B02,-2,544,159,60,"RRSHOUTCAST_SELECT",@RRSHOUTCAST_BAC K@
  9. #119
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by carputer1 View Post
    I have used the same version you referred to in the PM and it works.. any version AFTER 4-1 should work. First things first make sure the .dll is registered, make sure youre using RRSHOUTCAST;. Delete files RRSHOUTCASTRESUME.TXT and RRSHOUTCASTAUDIORESUME.TXT from your "Support Files" folder. Now load RR and run RRSHOUTCAST;. Does the skin load with genre list?
    Losing direct sound??? My plugin has no functions to handle volume what so ever. And as far as i know, the winamp crashing issue was solved when i removed WinampFrontEndLib.Dll. My plugin does exactly 2 things with winamp:
    1. Loads an m3u (thru RR's LOADLIST command)
    2. Reads the TRACKNAME label from winamp (the same method RR does .. window messages).
    Try my suggestions then post both your plugin debug file and your RR debug file.
  10. #120
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    all fine another pi was crashing , and the directsound i think was just 1 of those things ,
  1. Replies: 63
    Last Post: 03-10-2009, 07:49 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  4. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
