Page 13 of 20 FirstFirst ... 34567891011121314151617181920 LastLast
Results 121 to 130 of 197
Thread: RRShoutCast- Shoutcast Plugin
  1. #121
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by carputer1 View Post
    all fine another pi was crashing , and the directsound i think was just 1 of those things ,
    phew man ya had me worried there.
    Live mp3Car Facebook Chat
  2. #122
    Feb 2006
    New Jersey
    Quote Originally Posted by Sonicxtacy02 View Post
    just double up on one of the buttons. Double the select button so that CLICK selects and HOLD goes back
    B02,-2,544,159,60,"RRSHOUTCAST_SELECT",@RRSHOUTCAST_BAC K@
    Oh, great idea, I did that for the back button. Plugin works great now.
  3. #123
    Feb 2006
    New Jersey
    I'm using the click and hold on the back button now, but if I don't click, hold, and drag the cursor away from the button before I let go of the screen it also exits the skin after bringing up the genre list. Is there anyway to fix this that you know of?
  4. #124
    Woodbridge, VA
    Blog Entries
    55
    hmm that sounds like an odd behavior. Show me your RR debug.txt after you do it. Try using B02,-2,544,159,60,"RRSHOUTCAST_SELECT",&RRSHOUTCAST_BAC K& and see if it does the same thing. I could have the wrong character there.
  5. #125
    Feb 2006
    New Jersey
    This is my code for the back button:
    B02,723,5,77,053,"EXIT",@RRSHOUTCAST_BACK@
    When I hold it down it reloads genre list and then exits right after unless I hold the button down move the cursor away from the button and then let go.
  6. #126
    Feb 2006
    New Jersey
    I just changed it so that click and hold on the select button reloads the genre list and the same thing happens here. If I click hand hold select it will load the genre list and then after it loads the list it will select what ever genre is selected and open that list.
  7. #127
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by mnetwork View Post
    Re-Read my post... show me your debug.txt and try changing the command like i suggested.
  8. #128
    Feb 2006
    New Jersey
    Ok, tried the line you posted, that didn't work at all. A single click would reload the genre list. Put it back to @ signs. I went in the plugin, loaded the alternative genre, clicked and held select to reload the genre list, it reloaded, and then it loaded whatever genre it was set on which happened to be c64... Here is the log:
    [5/15/2009 12:13:33 PM]Communcation with Riderunner.SDK Enabled
    [5/15/2009 12:13:33 PM]Station Limit Read from RR as
    [5/15/2009 12:13:33 PM]RRShoutcast Resume Read. RRShoutcast resume state is Off
    [5/15/2009 12:13:33 PM]RRShoutcast Audio Resume Read. Audio List Position is and Track Time is
    [5/15/2009 12:13:33 PM]Sort option read.
    [5/15/2009 12:13:36 PM]Internet Found, Downloading Genre.xml
    [5/15/2009 12:13:36 PM]RRShoutcast Not Resumed. Trackname Update Timer Halted.
    [5/15/2009 12:13:48 PM]Command 'RRSHOUTCAST;' pressed
    [5/15/2009 12:13:49 PM]Internet detected at load. No need to download genre.xml
    [5/15/2009 12:13:49 PM]RRShoutcast Status is Off
    [5/15/2009 12:13:49 PM]List Type Set to Genre
    [5/15/2009 12:13:49 PM]loading RRShoutcast.skin
    [5/15/2009 12:13:49 PM]Custom list cleared
    [5/15/2009 12:13:49 PM]genre.xml read
    [5/15/2009 12:14:02 PM]Genre list entry pressed
    [5/15/2009 12:14:02 PM]Internet found. Pulling station list
    [5/15/2009 12:14:02 PM]Station list information timer enabled. Receiving station data.
    [5/15/2009 12:14:02 PM]List type is Station
    [5/15/2009 12:14:07 PM]Last genre Alternative writtin to skin.ini
    [5/15/2009 12:14:07 PM]custom list cleared
    [5/15/2009 12:14:07 PM]station from genre 'Alternative' downloaded.
    [5/15/2009 12:14:07 PM]Genre pull function initiated.
    [5/15/2009 12:14:07 PM]Genre pull timer stopped.
    [5/15/2009 12:14:57 PM]Genre list entry pressed
    [5/15/2009 12:14:57 PM]Internet found. Pulling station list
    [5/15/2009 12:14:57 PM]Station list information timer enabled. Receiving station data.
    [5/15/2009 12:14:57 PM]List type is Station
    [5/15/2009 12:15:02 PM]Last genre C64 writtin to skin.ini
    [5/15/2009 12:15:02 PM]custom list cleared
    [5/15/2009 12:15:25 PM]station from genre 'C64' downloaded.
    [5/15/2009 12:15:25 PM]Genre pull function initiated.
    [5/15/2009 12:15:25 PM]Genre pull timer stopped.
  9. #129
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok i just tryed this RRSHOUTCAST_BACK button cmd , as Mnetwork is trying to do .
    so i piggy backed the cmd on the select button @RRSHOUTCAST_BACK@
    works fine, it brings up the genre list everytime, without exiting, crashing, what so ever .
    so it looks to be mnetwork problem on his side of things not the PI .
    i don't know if this is a pi problem but my trackname is showing Http not current playing.
    i don't suppose there's a WA setting that needs to be changed.?????
  10. #130
    Feb 2006
    New Jersey
    Nothing crashes or anything. It acts as if I clicked and held, and then clicked.
  1. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
