Page 7 of 20 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 197
Thread: RRShoutCast- Shoutcast Plugin
  1. #61
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    Have .net 2.0? I dont think there are any other dependencies. Using XP? Nlited or anything? Which winamp version are you running?
    Live mp3Car Facebook Chat
  2. #62
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    standard xp sp2
    winamp 5.13
    .net 3.5 (I also have .net 2 in 'C:\WINDOWS\Microsoft.NET\Framework' folder)
    riderunner in default path
  3. #63
    Mar 2008
    Toronto Canada
    could it be the plugin looking for roadrunner in the path?
    here is the complete error dump
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.IO.FileNotFoundException: Could not load file or assembly 'WinampFrontEndLib, Version=1.0.2168.40014, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
    File name: 'WinampFrontEndLib, Version=1.0.2168.40014, Culture=neutral, PublicKeyToken=null'
    at RRShoutCast.Form1.UpdateTrackname_Tick(Object sender, EventArgs e)
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    WRN: Assembly binding logging is turned OFF.
    To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
    Note: There is some performance penalty associated with assembly bind failure logging.
    To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    HDRadioComm
    Assembly Version: 1.3.0.2
    Win32 Version: 1.3.0.2
    CodeBase: file:///C:/Program%20Files/RideRunner/MJS%20Gadgets/HDRadio/HDRadioComm.DLL
    System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    RRShoutCast
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/RideRunner/RRShoutCast/RRShoutCast.DLL
    Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Web
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
    System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  4. #64
    Woodbridge, VA
    Blog Entries
    41
    Try this .dll and see if the same error appears (remove .txt). This one provides reference to riderunners sdk and provides riderunner as a reference.
    Quote Originally Posted by pcpete View Post
    mscorlib
    HDRadioComm
    System
    RRShoutCast
    System.Drawing
    System.Web
    System.Xml
    Accessibility
    enabled.
    For example:
    <configuration>
    </configuration>
    Attached Files Attached Files
  5. #65
    Mar 2008
    Toronto Canada
    Same error, I did do the uninstall and reinstall cmds...
    Could be something on my end? Anyone else have similar issue?
    mscorlib
    HDRadioComm
    System
    RRShoutCast
    System.Drawing
    System.Web
    System.Xml
    Accessibility
    enabled.
    For example:
    <configuration>
    </configuration>
  6. #66
    Woodbridge, VA
    Blog Entries
    41
    this is really really odd.. i just put both my .dll and the frontendlib.dll thru a depency walker and there's nothing there that doesnt come with windows. If you dont mind testing something for me.. start winamp and run this .exe. Does it show the trackname? upon pressing "Popup current track title" does it show you whats playing? Im interested to see if its something on your end. Because that .dll isnt even called until shoutcast is tuned.
  7. #67
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    yet to have WA crash , but the RRSHOUTCAST;STATION gives all kinds of errors
    also getting nothing in RRSHOUTCAST_PLAYINGTRACK
    but i have only just got round to playing with this,
  8. #68
    Mar 2008
    Toronto Canada
    The test worked....no problems...
    Could it be some winamp setting? I think I have idtags disabled and some other stuff...
  9. #69
    Woodbridge, VA
    Blog Entries
    41
    if the test works the winampfrontendlib.dll should work. I'm gonna post a RRshoutcast.dll version with a log shortly.
  10. #70
    Mar 2008
    Toronto Canada
    Whoa!! Update! Moved rrshoutcast to root of c: drive, the error message has stopped!
    Will further test now....
  1. Replies: 63
    Last Post: 03-10-2009, 07:49 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  4. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
