Page 9 of 20 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 197
Thread: RRShoutCast- Shoutcast Plugin
  1. #81
    Nov 2004
    St Louis
    Quote Originally Posted by carputer1 View Post
    has anybody had any joy with Fav's, i can add stations no problems, but to load them back in RR locks up ,actually it looks like WA locks up , i noticed in skintool the loadlist cmd is fired twice
    LOADLIST;http://yp.shoutcast.com/sbin/tunein-....pls?id=836012
    this is onclclick cmd to set fav station
    I created a favlist using the addfav command and am able to scan the favs in shoutcast_player, but you're right when I click a selection the third or fourth time, it crashes. Haven't done much diagnoses on this yet but you're not alone.
    Is there a way to slow down the SCAN mode? The current timing works great on my dev machine (2.8G, DSL on ethernet) but the car is 1.2G with 128K on cellular and is too slow to actually buffer up before rrshoutcast loads the next stream. My winamp library scanmode is set at 15 seconds which gives my car time to buffer and update the streamtitle.
    OBTW, some streams have an automatic intro of 5-10 second for station ID before the music starts playing which is all I hear with the current rrshoutcast scanmode. In addition to those some other streams change the streamtitle two or three times throughout a single song and rrshoutcast misses them all.
  2. #82
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    yesterday i noticed on my car system winamp crash when i tune to a favorite channel sometimes. No idea why.. but when i remove activewinamp the problem was solved. I need to figure out a way to use activewinamp to pull trackname... that would get rid of the 3rd party dll.
    Scan mode was added at the last second. I will make the scan time setable thru OSK for the next release. And i didnt forget the sort by bitrate i just wanted to get get the rest of the core stuff working well before throwing in another wrinkle lol. This certainly isnt a final release so stay tuned.
    Live mp3Car Facebook Chat
  3. #83
    Woodbridge, VA
    Blog Entries
    55
    Fixed a bug that occurs with certain connection types not being able to send/receive ping data (pda net users rejoice!). I'm working on the sort issue now. RRShoutcast.skin will be modified so that upon clicking a station name the labels display information for the selected station, not the currently playing station.
    EDIT- Changed my mind that quick. There will be two sets of labels.... "selected" labels will show the selected content and "current" labels will show the tuned labels. Gonna have to edit the damn skin file again! Also, sort options include bitrate,listener count(default shoutcast sort), and alphabetical. Am i missing anything there?
  4. #84
    Nov 2004
    St Louis
    Great news!
  5. #85
    Woodbridge, VA
    Blog Entries
    55
    Sorting by bitrate is giving me problems. Any of you coding gurus know how to sort an array by the value of one of its elements? There's no way to request the data sorted from the shoutcast server so i have to read it in and sort on the fly. All other sort methods are done. If there were a finite number of bitrates it'd be easy but i dont know shoutcast's minimum and maximum bitrate values.
  6. #86
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    I am his holyness, the Guru Pitka. My goal is to say , Gee, You are You.....Do not mess with the elements!
  7. #87
    Feb 2006
    New Jersey
    Quote Originally Posted by pcpete View Post
    I've got a Riderunner install, just tried it , got this error....
    This occurs while rr starts up....
    I'm getting this same error... nothing I do makes it go away...
    Tried putting files everywhere, I never had a problem until this version. I get the same error about WinampFrontEndLib.
  8. #88
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by mnetwork View Post
    tomorrow i'm dedicating my day to getting rid of the extra .dll and reading directly from winamp. TODAY i finally got sorting done. Sorting by bitrate was a glorified PITA. Its limited to the bitrates 32,48,56,64,96,128,160, & 192. If any other bitrate is found it will be ignored and not added to station results. I can however add any bitrate to the function. I just havent found a station that doesnt use one of those bitrates. So Yay or Nay here? Any other requests.. speak now!
    At some point i will be adding a filter option to add a little bit more flexibility. Basically, you will be able to limit your station results to bitrates higher/lower than a specified number. Hopefully this will help you get only the stations you want to listen to. If all goes well with reading directly from winamp i should have a new version out tomorrow. All future versions will include an easy to use debug log.
  9. #89
    Mar 2008
    Toronto Canada
    320 and 256....
    Just wanna say, really appreciate what you are doing, this is one of the plugins I've been longing for....thx
  10. #90
    Woodbridge, VA
    Blog Entries
    55
    added 320 and 256.
    Also figured out how to read directly from winamp. No more 3rd party library
  1. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
