View Poll Results: I want these features added
Voters
31. You may not vote on this poll
  • GeoCaching - Users can share GPS COORDINATES for GEOCHACE
    9 29.03%
  • Automatic Trapster Downloads and Zone Updates - (INTERNET REQUIRED)
    15 48.39%
  • Stand Alone Version - Not Dependent on RR for anything
    9 29.03%
  • Skinnable Stand Alone Version
    12 38.71%
  • Import Speed Zones to Garmin POI
    11 35.48%
  • More RR integration (Indicators, Label Codes & what ever)
    16 51.61%
  • Dynamic Settings Changer
    7 22.58%
  • Works while GPS Screen is active in RR
    16 51.61%
Multiple Choice Poll.
Page 10 of 13 FirstFirst 12345678910111213 LastLast
Results 91 to 100 of 130
Thread: SpeedZone w/GPS Position Alarm - GPS POSITION TRIGGER - 28SEP09
  1. #91
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Ill try out what I got in the car in the morning.
    Truly, my carpc project has been on the back burner for a while. So there are probably some bugs with the speed zone code that need to be worked out.
    New Age Garmin - Skin for RR
  2. #92
    Jul 2006
    Quote Originally Posted by ThunderStick View Post
    So I'm assuming you were able to download OK then.
    I also sent you a PM with the DEBUG log results.
  3. #93
    Aug 2006
    West Allis, WI
    Sorry still unable to download from your FTP server..
    Try the latest relese in the first post or from mediafire.
    I did find a ton of problems in the code this morning.
    I can't believe all that I am finding now...
    Anyway.. let me know how this works.
    Should be good. I think ive said that before.
  4. #94
    Jul 2006
    Probably because your IE is still in FTP PASive mode. If you uncheck it, it will dwld, no probs.
    And i just tried your Aug16 on my test system. So far so good. This could be the one!!
    I'll be putting this in my car tommorrow, let you know how it goes.
  5. #95
    Jul 2006
    On another note.
    Is there any chance of being able to edit some of the non-user spoken warnings.
    (example: the overspeed warning)
    Or is this hard coded and too difficult to implement?
  6. #96
    Aug 2006
    West Allis, WI
    Quote Originally Posted by CannonBaller View Post
    On another note.
    You can edit any of the text the program uses by editing the language files.
    Using notepad to edit english.lng, you can edit line 18 through 27. THese lines are used for the over speed limit warnings.
  7. #97
    Aug 2006
    West Allis, WI
    Releases are on hold until bugs are worked out...
  8. #98
    Jul 2006
    So what i the latest release Aug16 or Aug19?
    Also...(i will test again tonight)
    The Aug16 Speedlimit.exe, it doens't actually track anythiing.
    (eg does not call out zones or overspeeds)
    I had to go back to the May 1 release.
    I'll give you some more bug details later.
  9. #99
    Aug 2006
    West Allis, WI
    I got a version now, but I am having trouble with being able to change speed limits.
    That is the only issue I have right now.
    Release coming SOON...
  10. #100
    Aug 2006
    West Allis, WI
    UPDATE:
    -Fixed the bugs and releaed a new version.. EVERYTHING should work as advertised now
    -Auto Trapster updated to accomodate changes to trapster website
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2012, 02:35 PM
  2. New Age Garmin - FINAL RELEASE 01OCT09
    By ThunderStick in forum RR Released Skins
    Last Post: 08-31-2011, 12:20 PM
  3. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  4. Speed Limit / Speed Zone Plugin RELEASED
    By ThunderStick in forum RR Plugins
    Last Post: 12-20-2008, 02:03 AM
  5. Hacking into Fan speed switch...
    By Dexter in forum Hardware Development
    Last Post: 07-12-2005, 12:11 PM
