View Poll Results: I want these features added
Voters
31. You may not vote on this poll
  • GeoCaching - Users can share GPS COORDINATES for GEOCHACE
    9 29.03%
  • Automatic Trapster Downloads and Zone Updates - (INTERNET REQUIRED)
    15 48.39%
  • Stand Alone Version - Not Dependent on RR for anything
    9 29.03%
  • Skinnable Stand Alone Version
    12 38.71%
  • Import Speed Zones to Garmin POI
    11 35.48%
  • More RR integration (Indicators, Label Codes & what ever)
    16 51.61%
  • Dynamic Settings Changer
    7 22.58%
  • Works while GPS Screen is active in RR
    16 51.61%
Multiple Choice Poll.
Page 11 of 13 FirstFirst ... 2345678910111213 LastLast
Results 101 to 110 of 130
Thread: SpeedZone w/GPS Position Alarm - GPS POSITION TRIGGER - 28SEP09
  1. #101
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Setup stop after Merci
    Hi Tunderstick,
    Setup stop after the first GUI .
    - no files languages .SETUP found in /Language folder .
    - the 17/08/2009 setup.exe file run well but not the 22/08/2009 .
  2. #102
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Just use the setup from 17/08/09.. Not too sure what happened here with the 22/08 version. Found this out today.
    New Age Garmin - Skin for RR
  3. #103
    Aug 2006
    West Allis, WI
    BUGS found in 22 AUG 09 version
    Setup program error - Use a previous release that works.
    Not leaving a home zone after entered - Just delete you home zone for now
  4. #104
    Aug 2006
    West Allis, WI
    Quote Originally Posted by pierrotm777 View Post
    Hi Tunderstick,
    You could also try just copying the .stp files in the Language folder to .setup files.
    This should fix this problem as well.
    I was working on organizing the language files and I must have missed a few things.
    Sorry about this... By the way, your french language file is now included.
  5. #105
    Aug 2006
    West Allis, WI
    Ok, squashed the bug with setup. Just a language file issue, NO MORE
    Flattened the bug that would not allow you to exit a home zone and also fixed another bug that was miss numbering Zone names in the Zone Name List.
    Anyway, I truly think this is it. I cant think of anything else that is wrong.
    LMK of any other bugs found. Release in first thread 23AUG09PM
  6. #106
    Jul 2006
    This is what I noticed.
    Aug 23 release as compared to the May 1 release
    Aug 23 now installed.
    -the "-1..." error, seems to have compeletely dissappeared.
    - during boot of RR, everything seems to load nicely. including hte GPS app.
    -so far the trapster zones are coming through OK, but not as often as May1. I could not verify the validaty of the zone locations, so note sure why this is. I just know that i heard more warnings on the May1 release.
    If i can verify the locations, I'll post that later.
    -Overspeed on set speedl imit NOT announced at all. Switching to May1 speedlimit.exe, it works without issue.
    So no overspeed alerts coming through on Aug 23 release.
    Note: i have not yet setup my own zones or home zone. So i dont know if it works. I'll post it after i get a chance to test.
    But all in all...it seems to be very stable.
    Good job!!
  7. #107
    Aug 2006
    West Allis, WI
    Im bangin' out quite a bit of releases lately. It maybe hard to keep up. I also noticed the overspeed is not working and this truly has got me confused.
    There are a few bugs yet, I noticed this morning. I honestly thought today release addressed all of them.
    Damn, guess not.
    Anyway, fear not I am wokig on it...
  8. #108
    Aug 2006
    West Allis, WI
    From your speedzone folder,
    Open up GPS.EXE.
    Go to Options on the top menu
    THen Field Formats
    In the speed drop down box, make sure you have MI/H selected.
    Or KM/H what ever you are using in RR.
    Then press the OK button and restart RR.
    You should only have to do this once.
    MI/H should have been default, but for some reason it may have defaulted to knots
    This should fix the overspeed issue.
  9. #109
    Jul 2006
    Quote Originally Posted by ThunderStick View Post
    Open up GPS.EXE.
    THen Field Formats
    Alright I'll give that a shot on my way home tonight.
    i checked the setting and it was set to knots. We'll see how it works now on Km/h.
  10. #110
    Jul 2006
    Got another question about your overspeed accouncements.
    Can you tell me when and in what order thes events are fired in the language file.
    I'm a little confused as to which are fired for Zones and which are for the default Overspeed limit?
    YOU ARE CURRENTLY GOING OVER THE SPEED LIMIT OF
    IN A
    ZONE
    YOUR SPEED AND POSITION ARE BEING MONITORED. THE DEFAULT SPEED LIMIT IS SET TO
    THIS IS ONE FAST *** CAR BUT THE SPEED LIMIT IS
    SLOW DOWN THIS IS GETTING DANGEROUS AND THE SPEED LIMIT IS
    THIS WILL BE ONE BIG TICKET AND THE SPEED LIMIT IS
    YOU MUST HAVE STOLE THIS CAR BECAUSE YOU SURE ARE DRIVING LIKE IT AND THE SPEED LIMIT IS
    OK SPEED RACER I CAN TELL YOU WONT LISTEN TO ME AND THE SPEED LIMIT IS
    You are going over the speed limit of
    YOU MAY GET A TICKET FOR THIS
    THIS IS YOUR SECOND REMINDER
    Please Slow Down
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2012, 02:35 PM
  2. New Age Garmin - FINAL RELEASE 01OCT09
    By ThunderStick in forum RR Released Skins
    Last Post: 08-31-2011, 12:20 PM
  3. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  4. Speed Limit / Speed Zone Plugin RELEASED
    By ThunderStick in forum RR Plugins
    Last Post: 12-20-2008, 02:03 AM
  5. Hacking into Fan speed switch...
    By Dexter in forum Hardware Development
    Last Post: 07-12-2005, 12:11 PM
