View Poll Results: I want these features added
Voters
31. You may not vote on this poll
  • GeoCaching - Users can share GPS COORDINATES for GEOCHACE
    9 29.03%
  • Automatic Trapster Downloads and Zone Updates - (INTERNET REQUIRED)
    15 48.39%
  • Stand Alone Version - Not Dependent on RR for anything
    9 29.03%
  • Skinnable Stand Alone Version
    12 38.71%
  • Import Speed Zones to Garmin POI
    11 35.48%
  • More RR integration (Indicators, Label Codes & what ever)
    16 51.61%
  • Dynamic Settings Changer
    7 22.58%
  • Works while GPS Screen is active in RR
    16 51.61%
Multiple Choice Poll.
Page 6 of 13 FirstFirst 12345678910111213 LastLast
Results 51 to 60 of 130
Thread: SpeedZone w/GPS Position Alarm - GPS POSITION TRIGGER - 28SEP09
  1. #51
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    That is what it does now.
    Download the 16JUN version, this is a hotfix just copy the two exe's over the current ones. If a language file is not found it will default to English. This should fix the problem.
    If not let me know.
    New Age Garmin - Skin for RR
  2. #52
    Aug 2006
    West Allis, WI
    You can also set the language to english in the setup program.
    You do need to press save to save the settings after they are selected or you will keep getting the same problem.
  3. #53
    Aug 2006
    West Allis, WI
    Automatic Trapster Zone Downloader and Importer
    DOWNLOAD HERE
  4. #54
    Jul 2006
    Im havinig the same issue.
    "3. Trying to import a Trapster file in the setup.exe, I receive AutoIt Error, Line-1: Error: Subscript used with non-Array variable
    I installed the Jun 16th update with same results.
    All my regional and language settings are set to English (US)
    any ideas?
  5. #55
    Aug 2006
    West Allis, WI
    Quote Originally Posted by CannonBaller View Post
    any ideas?
    Download Auto Trapster to import Trapster Zones for now on. THis will eventually be implimented in to the setup.exe.
    The import in the setup program is for upgrading from very early releases of SZ and is basically outdated. It will not work. The setup program however is still very usefull and will work fine for importing trapster zones.
  6. #56
    Jul 2006
    I've noticed that the only info that seems to download from Trapster is SpeedZones.
    What about the Red light Camera database?
  7. #57
    Aug 2006
    West Allis, WI
    -Fixed the setup program so that the update and import button works again
    -Added GeoGate (GPS position activate car alarm with email support)
    -All trapster importing can be done from the setup.exe. Just copy the trapster.csv file to the speed zone folder and then use the trapster import buttons.
    -Setup automatically backsup your zones.csv so no worry there.
    -When upgrading from an earlier version just copy your zones.csv to the speed zone folder then hit the update and import button in setup. It will transfer over all your zone information.
  8. #58
    Aug 2006
    West Allis, WI
    You can download that manually then rename the downloaded file to trapster.csv and copy to your speedzone folder.
    Then just run setup and use the trapster import buttons as normal.
  9. #59
    Jul 2006
    Im still getting another error pop up during certain tasks.
    In comes up during these times:
    1. in the SPEEDSTART Screen, everytime i select a set speed or custom speed.
    2. in the SPEEDZONE screen, when i click START command
    During the command executing above. THE GPSDiag screen reloads itself (everytime!). And its right after this that the error pops up.
    Also, i have installed this on 2 separate PCs with the same error.
    Is there a variable missing somewhere in a skins or ini file?
  10. #60
    Aug 2006
    West Allis, WI
    What happens is when you change the Default speed limit from the speed limit screen it has to restart Speed Zone. This will restart the GPS interface as well. For what ever reason though it is not recieving all the data needed when it restarts.
    I will look in to this and come up with something. Seems odd though because i dont have this issue on my computer with getting that error.
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2012, 01:35 PM
  2. New Age Garmin - FINAL RELEASE 01OCT09
    By ThunderStick in forum RR Released Skins
    Last Post: 08-31-2011, 11:20 AM
  3. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 10:27 AM
  4. Speed Limit / Speed Zone Plugin RELEASED
    By ThunderStick in forum RR Plugins
    Last Post: 12-20-2008, 01:03 AM
  5. Hacking into Fan speed switch...
    By Dexter in forum Hardware Development
    Last Post: 07-12-2005, 11:11 AM
