View Poll Results: I want these features added
Voters
31. You may not vote on this poll
  • GeoCaching - Users can share GPS COORDINATES for GEOCHACE
    9 29.03%
  • Automatic Trapster Downloads and Zone Updates - (INTERNET REQUIRED)
    15 48.39%
  • Stand Alone Version - Not Dependent on RR for anything
    9 29.03%
  • Skinnable Stand Alone Version
    12 38.71%
  • Import Speed Zones to Garmin POI
    11 35.48%
  • More RR integration (Indicators, Label Codes & what ever)
    16 51.61%
  • Dynamic Settings Changer
    7 22.58%
  • Works while GPS Screen is active in RR
    16 51.61%
Multiple Choice Poll.
Page 8 of 13 FirstFirst 12345678910111213 LastLast
Results 71 to 80 of 130
Thread: SpeedZone w/GPS Position Alarm - GPS POSITION TRIGGER - 28SEP09
  1. #71
    Jul 2006
    Quote Originally Posted by Maheriano View Post
    I would need to tear apart a keyfob though? Would it be powered from the computer or would I still need to keep the batteries in it?
    You can either.
    1) keep your battery...probably the simplest way.
    2) you can power it from your PC if you connect it to your power supply. Or even another power source in your car. BUT...you will need to get the voltage down to whatever your battery is (1.5V probably). So either get a transformer that can do down voltage or you can built one yourself with resistors.
  2. #72
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Just keep the battery in it. Make sure you put it in an easily accessible spot and you should have no problems.
    New Age Garmin - Skin for RR
  3. #73
    Aug 2006
    West Allis, WI
    Quote Originally Posted by CannonBaller View Post
    getting close and closer. So now everything loads correctly.
    Except of course for the error "variable used without being declared" popup.
    Did you ever get this working?
  4. #74
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    How do you use the Geocache option Tunderstick ?
  5. #75
    Aug 2006
    West Allis, WI
    Tell you the truth, I havent.. It is still a theory. It may work. Create a zone and just include geocache in the name. When this zone is entered it will display a scrolled map on your screen. The idea eventually will be to allow users to share these zones and use them to mark landmarks, points of interest or other things you would like to share.
    Kind of like a geocache club that uses a handheld GPS for a treasure hunting like game.
    This eventually will work the same way.
    Not sure how well it is working yet, but it should notify you when entered. Eventually if enough interest is generated we could maybe get a facebook thing going to support sharing the GEO CACHE zones. Who know where this will go, was just a fun idea I thought I would add....
  6. #76
    May 2008
    Bordeaux, France
    Quote Originally Posted by ThunderStick View Post
    To share poi or track is a very good idea.
    But all guys use different Gps programs, (Garmin,Igo8,Sygic7.71,etc...).
    Each program have his track and poi format.
    Its is important to have a good translator for a best compatibility .
    A good link to share Geocaching : Geocache.com
  7. #77
    Aug 2006
    West Allis, WI
    THis would have to be used with SpeedZone for geocahing
    Maybe not though. It would be simple enough to translate GPS coordinates, the hard part is working with an internet server, creating a subscription system and having realtime use of the GeoCache information from the internet.
    Honestly though, if all you wanted to do is share GPS coordinates and enter them in to SPeedzone this is a pretty simple task.
  8. #78
    Aug 2006
    West Allis, WI
    Small update,
    AutoTrapster fix. 07AUG09
  9. #79
    Jul 2006
    Sorry haven't had the time until now.
    I went over all the settings and install instructions, everything looks fine.
    Still the same thing. Speedzone starts, opens the GPS app, and then comes back with that "-1....." error. Thats when the Speedlimit.exe app terminates.
    As you say i can send you a copy of my whole RR folder. Problem is that is 108MB. Maybe i should send you an email with an FTP link where you can download it. Yea its big, but everything in there is needed. I even cut down the zones files to only 100 entries for testing.
    if your profile supports emailing, i will send you my FTP and email details.
  10. #80
    Aug 2006
    West Allis, WI
    Drop me a PM, with the link. I will download when I get time.
    Not sure what is going on.
  1. New Age Garmin - FINAL RELEASE 01OCT09
    By ThunderStick in forum RR Released Skins
    Last Post: 08-31-2011, 12:20 PM
  2. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-29-2010, 01:06 PM
  3. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  4. Speed Limit / Speed Zone Plugin RELEASED
    By ThunderStick in forum RR Plugins
    Last Post: 12-20-2008, 02:03 AM
  5. Hacking into Fan speed switch...
    By Dexter in forum Hardware Development
    Last Post: 07-12-2005, 12:11 PM
