Page 10 of 126 FirstFirst 123456789101112131415161718192060110 ... LastLast
Results 91 to 100 of 1260
Thread: .net Bluetooth Mobilephone Plugin
  1. #91
    Jul 2006
    Brisbane, Australia
    Quote Originally Posted by lambosprit View Post
    thanks rodweb. that helped me find some stuff. JUST FOR TESTING heres a dll with the new logging. Can you try it sonic and tell me if it works.
    Hmm, I better stop lurking and actually give this go Lambospirit Glad I could help in a small way.
    RodW
    2007 Toyota Hilux with a CarPC..
    Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
    OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
  2. #92
    lambosprit's Avatar
    Sep 2006
    UK
    @Dartman 71. If you mean can you have a text file that the plugin reads rather than going to the phone itself then yes. It already exists. In Lucifers skin (see post 2) you can select a phone list type (I suggest PC rather than sim or mem) and then add numbers to it. After that you can select the PC again and you'll see the numbers and can select them for use. The file is stored in the plugin directory and is called mobilephone_pc.txt.
    I am going to start making the plugin store the dialled calls,missed calls as well but this isn't a perfect solution because it wont know about calls on the phone that where done without the plugin.
    The phone book and sms stuff is due soonish. Keep watching.
  3. #93
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Thank's lambosprit. Now I have new question. I try to change Robby's BMW E36 skin work with Mobilephone plugin but your commands work only in skin which name is mobilephone.skin. I change phoco.skin to mobilephone.skin and change button command, everything works fine but when I try to change commands in contacts.skin it doesn't work. Is there way to get this working?
  4. #94
    lambosprit's Avatar
    Sep 2006
    UK
    the dll is coded to only accept commands from mobilephone.skin, this is a legacy of Lucifers code. I thought it was a good idea but now thinking about it , it means the mobilecall.skin wont work as well. I'll remove it and post a new version after sonic has tested the new logging.
  5. #95
    Feb 2009
    Finland
    That's very good news and if you could add character +
  6. #96
    Nov 2007
    Just wanted to say thanks for taking your time to make this RR plugin!
  7. #97
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    15 hibernates today... zero debug errors. Very nice
    Live mp3Car Facebook Chat
  8. #98
    Oct 2005
    Hi guys,
    I'm doing testing of this plugin on my test computer and I've got a question. How do you go back to the previous screen? I can only go back why hitting "ESC" on my keyboard. Is there another way to go back to the previous screen bc I can't imagine having to have a keyboard while using this in the car. I must be over looking something.
    Let me know.
    Thanks.
  9. #99
    lambosprit's Avatar
    Sep 2006
    UK
    Thanks for testing Sonic. Released new version. See first post.
    Dartman. I added the + command but its not in the skin. You will have to do this yourself. On this point does anyone know why * is used. I know about # and + but not star.
    J007w. Thanks for the thanks. It may seem small but it goes a long way to keeping my enthusiasm up and tells me people are actually getting benefits.
    d0tech. Are you using lucifers skin or bmv2. The reason I ask is the plugin dosn't control the going back, its the skin. In the first version of lucifers skin I used QUIT instead of EXIT. If you look at your mobilephone.skin file check for this. Otherwise I would need to see the skin file your using.
  10. #100
    Feb 2008
    hi all
    i am running in to a few problems when i restart from hibernate
    is this some thing i have done wrong or is it the same problem that sonicx
    was having
    and why can i only get the plugin to work when i copy the files
    from the mobilephone plugin folder to the rr folder is this normal
    and with the phone book the text doc is getting saved but
    the names and numbers are not coming up in the skin
    where have i gone wrong with that
    apart from those few small things all is working great
    thanks lambo for putting in the time to do this keep the the updates coming
    p.s sorry for the spelling and grammar it's not one of my strong points
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
