Page 101 of 136 FirstFirst ... 51919293949596979899100101102103104105106107108109110111 ... LastLast
Results 1,001 to 1,010 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #1001
    Aug 2009
    UK
    Sounds like a good idea.
  2. #1002
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    Quote Originally Posted by porto View Post
    I have a Samsung i9000 Galaxy S on Android 2.1 (JM5 firmware) and can say that it works great with BS and with the .net Mobilephone plugin. It connects in 3 seconds to BS and is simultaneously recognized in my skinfile. I have not yet configured it the way I want it but I can make calls, receive calls and transfer audio. BS recognizes it as a smartphone with 3 services (dialup, file transfer, BT-audio).
    Pairing was a piece of cake, PUSH files also. It connects automatically to BS.
    Tonight I'll try if the battery- and reception bars work. Maybe even SMS?!
    My PC (Mac Mini 2.0) is set as desktop... I can change this option but somehow BS changes it back to desktop! ... %-)
    I haven't had mine connected in a while because I don't have my microphone properly connected, so no point. But my Motorola Milestone(Droid) (FW2.1) connected with no problems. Could make and receive calls easier than with my previous BB8301/8330?. Bluetooth audio also worked right off, so Trapster notifications played though the stereo. Battery and signal is hit and miss, and never accurate - though I haven't had a phone to show those properly yet.
    Haven't dove into checking SMS or email options, but I don't recall getting any notifications when receiving new messages.
    The BS setting for desktop/laptop has no affect as the plugin forces the change to desktop to establish the connection - Lambo mentioned this a few posts ago.
    One of these days I'l get my microphone connected back and used this more often... just gotta figure out/deal with the echo I still get...ugh
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  3. #1003
    Nov 2006
    Russia
    Lambosprit, I have the same problem as opelastrah: RR log shows this error:
    Code:
    Plugin Manager: Plugin Found: MobilePhone(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped]
    Plugin does not create any log, even with debug level set to 5. Plugin registered correctly (same message as in opelastrah post).
    Any ideas? Where to dig? Please help.
    System: WinXP SP3 Tablet, RR august version, .NET version 2.0, 3.0 and 3.5 installed, Blutooth WidComm 5.0.
    Have tried to setup plugin w/ and w/o bluetooth support - same results.
  4. #1004
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by glouck View Post
    Code:
    Try the method sugegsted in post 986. Installing vc++ redistributable. Others are having the same problem but haven't figuired out why yet.
  5. #1005
    Nov 2006
    Russia
    Quote Originally Posted by lambosprit View Post
    Already tried that (have installed VC++ 2010 package) - same results.
  6. #1006
    lambosprit's Avatar
    Sep 2006
    UK
    Copy the dll you currently have for both mobilephone and the bswrapper then try installing this version and copying the dll's back. Make sure you have vc++ 8.0.50727.42 only installed.
    if it works please tell me as I want to find out why this is happening.
    Attached Files Attached Files
  7. #1007
    Nov 2006
    Russia
    lambosprit, thanks for help.
    Here what I've done:
    1. Uninstalled latest version (1.15)
    2. Uninstalled VC 2010 redist
    3. Installed version 1.14 from your archive w/ ATSM
    4. Installed VC redist from your archive
    At this point plugin is able to start and create it's own log:
    Code:
    RR Log:
    04/09/2010 20:35:45: Plugin Manager: loading Global Plugins...
    04/09/2010 20:35:46: Plugin Manager: Plugin Found: MobilePhone(.NET)
    04/09/2010 20:35:46: Plugin Manager: Warning Plugin MobilePhone does not support Initialize Method
    04/09/2010 20:35:46: Plugin Manager: Plugin loaded (Global): MobilePhone
    Plugin log:
    04/09/2010 20:35:46:Info   : Starting MobilePhone version: 1.14.3583.27140
    04/09/2010 20:35:46:Info   : Current directory: D:\Car\RoadRunner\plugins\Mobilephone.NET
    04/09/2010 20:35:46:Debug  : Path being set to C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;D:\Car\RoadRunner\plugins\Mobilephone.NET
    04/09/2010 20:35:46:Info   : Device address: 00:12:D2:A6:30:3E
    04/09/2010 20:35:46:Info   : Pair code:
    04/09/2010 20:35:46:Info   : International prefix = 007
    04/09/2010 20:35:46:Info   : International shortcut prefix = +7
    04/09/2010 20:35:46:Info   : National prefix = 0
    04/09/2010 20:35:46:Info   : Using ATSMS for phone connection
    04/09/2010 20:35:46:Info   : MobileCall.skin: on
    04/09/2010 20:35:46:Info   : Trying to connect to phone.
    04/09/2010 20:35:46:Info   : Com port set to COM7
    04/09/2010 20:35:46:Info   : BaudRate set to 115200
    04/09/2010 20:35:46:Info   : DataBits set to 8
    04/09/2010 20:35:46:Info   : StopBit set to 1
    04/09/2010 20:35:46:Info   : FlowControl set to None
    04/09/2010 20:35:46:Info   : Connected to phone
    After changing dll's to the 1.15 version, problem returns - plugin isn't loaded, no log created.
    With 1.14 version I have another issue - it ignores COM port setting in the .ini file and always uses COM7. In the log above, it stated, that it has connected to the phone - but it isn't true - no phone was connected to the COM7 at the moment.
  8. #1008
    lambosprit's Avatar
    Sep 2006
    UK
    Code:
    RR Log:
    Plugin log:
    I didn't realise you where using the atsm. This is lucifers code and I dont know if it still works, I have probably broken it with all my tinkering. Are you using ATSM intentionally?
  9. #1009
    Nov 2006
    Russia
    Well, as i'm not using bluesoleil, i use ATSM mode to connect phone by com port and connect headset gateway manually. Moreover, I get it work on my desktop computer using cable connection and setup phone on COM7. Also I've tried bluesoleil (current version 8.0.338) on desktop computer - plugin cannot connect to the phone using bluetooth.
  10. #1010
    lambosprit's Avatar
    Sep 2006
    UK
    ok. I found a bug with reading the ini settings so that should now be fixed.
    As for BS, I noticed they had a new version out and have been trying it out. I cant get BS to see my phone now let alone pair with it. I also cant see the SDK listed on their site anymore so I have a fear that this new version may be a problem for th plugin.
    Anyway, if you want the new version to test with atsm just pm me with an email address.
    EDIT. Well the news is good. I managed to get BS 8 to work with the plugin.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
