Page 106 of 136 FirstFirst ... 65696979899100101102103104105106107108109110111112113114115116 ... LastLast
Results 1,051 to 1,060 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #1051
    Jun 2010
    Hey guys, Great plugin.
    After a bit of fiddling around i managed to get it all working, makes calls, pauses music etc.
    However, the one problem i have is that the microphone won't work for the audio.
    I can hear the person i've called, but they can't hear me. I have to switch the phone to speaker before they can. Any ideas? I'm waiting to get this working before i pay for a BlueSoleil license.
    Using version 8 with framework 3.5 and newest RR.
  2. #1052
    Jun 2010
    Ignore my last post. After slowly backtracking through the posts, i found the Wavein info. This fixed my problem, now to just tinker with the volume level and i'm done!
    Well, that and work out how the contact lists work
  3. #1053
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    i just installed this and got this error:
    what is says is that it cant access the file because another process is using it.
    Since i run RR in profile mode i checked that no logs are in the RR folder in my docs...
    What could be the culprit?
    Also this error comes at intervals if i click ok
    Blessed are the "cracked" for it is they who let in the light.
  4. #1054
    Sep 2008
    I have also gotten this error on waking from hibernation. Never have figured out how to stop it.
  5. #1055
    Oct 2008
    Odense, Denmark
    problem solved
    problem was that i ages ago paired the phone with my pc, but i have changed name on the pc and hence the phone would no longer auto accept the connection
    the fix was to delete the pairing in the phone and create it again
  6. #1056
    Oct 2008
    Odense, Denmark
    the name i'm talking about is the name of the pc as it appears on network
    that one will also be the BT name of the pc/dongle and that has to match up with what the phone knows... of course device id is the same but the phone rejects if the name is not same as when the pairing is done
    and if the phone rejects it will throw the error, at least that was the case for me
  7. #1057
    Oct 2008
    Odense, Denmark
    i'm wrong in that the connection to the phone should be broken once i quit RR ?
    for me that is not the case, there is still handsfree connection to the phone once i exit RR
    EDIT: skin files not done yet... my skinner has not made it that far
  8. #1058
    Nov 2006
    Quote Originally Posted by boelle View Post
    I'm getting the same error and it does indeed seem to be periodic but I can't tell exactly why.
    There aren't by chance multiple threads or processes trying to access the log file without serialization are there? I ask only because I have had that happen to me.
    Regards,
    Jim
  9. #1059
    Oct 2008
    Odense, Denmark
    i only discovered the pairing due to i read the log and found that the log was where it should and then i saw in the log that it could not connect to the phone
    after i re-paired the phone it worked
    now i only have to figure why its still on handsfree after i exit RR
  10. #1060
    Dec 2009
    Quote Originally Posted by obrienj View Post
    Regards,
    Jim
    I used to get this error, I think what I did was changed the debug level in the ini file to 0 thereby turning off debugging and these errors stopped.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
