Page 107 of 134 FirstFirst ... 757979899100101102103104105106107108109110111112113114115116117 ... LastLast
Results 1,061 to 1,070 of 1334
Thread: .net Bluetooth Mobilephone Plugin
  1. #1061
    Feb 2007
    Limassol, Cyprus, Europe
    Thanks for the great plugin!
    I'm looking to execute some code on call start and on call end (eg. set soundcard's volume at a certain level when starting a call and at a different level when ending a call)
    I've partially achieved that by using the mobilephone_pickup and mobilephone_hangup commands but obviously when the other end terminates the call, I have no way to achieve my goal, as this requires me to manually execute the mobilephone_hangup command (ie. pressing the hangup button on the screen)
    This is not a major problem, just annoying as (with the example of setting the soundcard's volume), after the other end terminates a call, I have to be very fast at pressing the hangup button and even then, I'm already late.
    In the events listed on the readme file included with the plugin, I cannot find at least an ONMOBILEPHONECALLENDED event or an ONMOBILEPHONECALLSTARTED event. That would be a nice addition to it and will make the plugin much better, as I've noticed that other users wanted something similar.
    Thanks again!
  2. #1062
    Nov 2009
    I agree with qp
  3. #1063
    lambosprit's Avatar
    Sep 2006
    UK
    I agree as well but I've only managed to do the incall event. I haven't found a way that allways works for finished call, mainly cause I can't trap when the person on the other phone closes the call. Still trying though.
    New events in next release are currently
    ONMOBILEPHONEINCALL
    ONMOBILEPHONENETAVAIL
    ONMOBILEPHONENETUNAVAIL
  4. #1064
    Feb 2007
    Quote Originally Posted by lambosprit View Post
    ONMOBILEPHONEINCALL
    I'm new to using this plugin, but I guess the ONMOBILEPHONEINCALL event will allow us to have a ringing sound when someone calls ?(apart from the pause of music,video etc that we currently have). Or did I miss something? I'm currently using DigitalFX 5 skin, and I don't get a ringing sound when someone calls. When I call someone, I get the standard sound when you call someone through your phone.
    In any case, that's very good news!
  5. #1065
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    hmm... this one is back:
    phone pairs fine when i open RR..... Could it be due to i'm running in profile mode?
    Blessed are the "cracked" for it is they who let in the light.
  6. #1066
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by boelle View Post
    Been looking into this again as I thought I had it fixed. I have made some changes and am testing now to see if I can reproduce and remove it.
  7. #1067
    lambosprit's Avatar
    Sep 2006
    UK
    Have added a disconnect when RR shuts down the plugin. I remember someone asking for this but can't find it. Will be in next release.
  8. #1068
    Low Bitrate topjohn's Avatar
    Oct 2009
    France /Wissous
    Hello,
    We are obliged to install bluesoleil to run your plugin? I find it heavy as software, I would like to avoid installing it again.
    I managed to get my phone (HTC HD2) with Freefone, but it does nothing else, that's why I really want to use your plugin, but the installation of bluesoleil displease me.
    Greetings.
  9. #1069
    Apr 2008
    I have been trying to get this pluggin to work. installed, finally got the dll registered, and added the LOAD line. The problem im having is when i press the phone button rr has error saying "mobilephone.skin could not be found" the plugin is working in the background, i just cant for the life of me get the skin to load. What am i doing wrong?!
  10. #1070
    Aug 2006
    Columbus, OH
    Quote Originally Posted by qpwoeiruty999 View Post
    Thanks again!
    First of all I really want to say "THANK YOU" to you Lambo for such an awesome plugin.
    About the events I actually created one myself with the TIMER command. Basically every 3 seconds (adjustable to whatever I like) it checks the status of the already available indicator:
    MOBILEPHONE_INCALL
    Based on the status of the indicator the Timer checks every X seconds and it creates the 2 events whether I'm on a call (inbound or out) or it just ended (off call).
    With those events I raise the Wave volume to 100, make sure radio is muted (Mobilephone itself sends a pause and radio mute but need to keep it mute with Navipause) and other controls that happen when I'm a call. Here's part of the code:
    Code:
    "TIMER","CALLVOLCONTROL"
    "CALLVOLCONTROL","BYIND;MOBILEPHONE_INCALL;OFF-CALL<<ON-CALL"
    Obviously it will be nice if Lambo can make Mobilephone to generate the events itself
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 09:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 08:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 10:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
