Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #1071
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by topjohn View Post
    Hello,
    We are obliged to install bluesoleil to run your plugin? I find it heavy as software, I would like to avoid installing it again.
    I managed to get my phone (HTC HD2) with Freefone, but it does nothing else, that's why I really want to use your plugin, but the installation of bluesoleil displease me.
    Greetings.
    The plugin works in two modes, bluetooth for which you must have Bluesoleil installed, and ATSM mode. The atsm mode is just lucifers original code which may or may not still work (I may have broken it with all my messing).
    You could try the atsm stuff an see if it works.
  2. #1072
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by SpeedAddict View Post
    I have been trying to get this pluggin to work. installed, finally got the dll registered, and added the LOAD line. The problem im having is when i press the phone button rr has error saying "mobilephone.skin could not be found" the plugin is working in the background, i just cant for the life of me get the skin to load. What am i doing wrong?!
    It would help if you said which skin it was you're using but the following line should work in most skins
    LOAD;mobilephone.skin;Mobilephone.net;Mobilephone. NET
    check that you actually have the mobilephone.skin file in your skins folder.
  3. #1073
    Apr 2008
    well i uninstalled and reinstalled rr and mobilephone and now its working! only thing different that i can think of is the dll registered automatically this time. im not gona complain!
    plugin works great, i can make and answer calls, etc. a few problems;
    mobilephone connects to my phone fine, but wont reconnect. if i play with BS settings and connect/unconnect it for a while it will eventually reconnect. are there specific settings/services/etc that need to be set in BS?
    im also having problems with my mic only providing static. im assuming its probably a windows setting, but playing around with them hasnt fixed it.
    and on a side note, not sure if this even matters, i happened to look at the plugin manager, and mobilephone wasnt listed, even though it was working. i then changed the windows 7 permissions for RR to "run as administrator" and it now shows up.
    Just wana say you're doing awesome work Lambo and everyone else working on this. Phone control has been one of my "holy grail" items, and im really excited this plugin is working as well as it is!
    Windows 7
    RR
    Carwings Dynamic Lite
    MobilePhone.net 1.16
  4. #1074
    Low Bitrate titanicmusic14's Avatar
    Jan 2008
    Pennsylvania
    operation failed for undefined reason
    "You know what I mean? But at the end of the day, it is what it is." - The most articulate thing someone could say.
  5. #1075
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by titanicmusic14 View Post
    Bananas are also yellow.
    It would help if you gave the context and maybe the debug log output.
  6. #1076
    Low Bitrate Strgazr's Avatar
    Mar 2004
    Blanchard, OK
    Installer hangs up at trying to register mobilephone.dll
    This is as far as it gets:
    Checking your .NET Framework version...
    .NET Framework Version found: 2.0.50727, equal or newer to required version: 2.0.5.
    Proceeding with remainder of installation.
    Output folder: C:\Program Files\RideRunner
    Extract: BSWrapper.ini
    Output folder: C:\Program Files\RideRunner\plugins\Mobilephone.NET
    Extract: MobilePhone.dll... 100%
    Extract: ATSMS.dll... 100%
    Extract: ATSMS.xml... 100%
    Extract: BSWrapper.dll... 100%
    Extract: mobilephone.chm... 100%
    Execute: "C:\Windows\Microsoft.NET\Framework\v2.0.50727\Reg Asm" "C:\Program Files\RideRunner\plugins\Mobilephone.NET\mobilepho ne.dll" /tlb:mobilephone.tlb /codebase "
    Windows 7, RR Oct. 2010 in profile mode, DFX5
    also RR 12-12-10 in profile mode and not in profile mode, Car Wings Lite
    Debug log MobilePhoneDebug.txt
    Riderunner can't start unless I delete the Mobilephone.Net folder, there's an error box "Mobilephone Fatal message" - about mobilephone.ini not found and it closes RR.
  7. #1077
    Dec 2007
    Mohnton, PA
    I ran the installation file successfully, but mobilephone is not showing up in my plugin list. I tried to manually register the dll and it was successful even though it gave a warning about renaming the file:
    I also have debugging (level 5) enabled but there is no debug file created.
    C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727>rega sm "C:\Program Files\RideRunne
    r\Plugins\Mobilephone.NET\mobilephone.dll" /tlb:mobilephone.tlb /codebase
    Microsoft (R) .NET Framework Assembly Registration Utility 2.0.50727.1433
    Copyright (C) Microsoft Corporation 1998-2004. All rights reserved.
    RegAsm : warning RA0000 : Registering an unsigned assembly with /codebase can ca
    use your assembly to interfere with other applications that may be installed on
    the same computer. The /codebase switch is intended to be used only with signed
    assemblies. Please give your assembly a strong name and re-register it.
    Types registered successfully
    Assembly exported to 'C:\Program Files\RideRunner\Plugins\Mobilephone.NET\mobile
    phone.tlb', and the type library was registered successfully
  8. #1078
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Strgazr View Post
    The debug says you are trying to use the ATSM code. If you want to use Ble Soliel go to the ini file and change the PhoneLink=Blue. You will also need to set your phones MAC address in this ini.
  9. #1079
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by phuz View Post
    What version of windows are you running?
    Where did you look for the log file? Did you look for the BSWrapper.log as well?
    I know it sounds like a fob off but have you tried uninstalling and reinstalling (after restarting)?
  10. #1080
    MySQL Error
    Oct 2004
    the codebase issue, its probly something that shouldnt be codebased anyway... since it wont ever need to go into the GAC nor will any other application need this .dll
    just remove the /codebase from the regasm code in the installer
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
