Page 11 of 126 FirstFirst ... 2345678910111213141516171819202161111 ... LastLast
Results 101 to 110 of 1260
Thread: .net Bluetooth Mobilephone Plugin
  1. #101
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    thats the same problem i had. Try the latest version and report if you see it again.
    Live mp3Car Facebook Chat
  2. #102
    Feb 2008
    thats the thing it is the latest version
    thats why i asked if it was the same problem
  3. #103
    lambosprit's Avatar
    Sep 2006
    UK
    Have you checked the log file to see which version you are actually running. You can use the carwings screen as per post 1.
    I suspect the phonebook problem is because of the problems your having with the directory location.
    Just to be clear, because this is a dll program the location is irrelevant. Its where its registered that counts. The debug log contains a line that says "Current directory:". this should be where the dll is found. (you will have to set the debuglevel to 4 or higher to see this)
    Have you tried registerig it with the /codebase argument (see post 77). Sometimes it looks like its registered properly when it hasn't been. Again the carwings plugin manager shows you if it has or hasn't.
  4. #104
    Feb 2008
    well here is a copy of the log will try those few thing you sugested
    and get back on what i find
    Attached Files Attached Files
  5. #105
    Woodbridge, VA
    Blog Entries
    32
    i have another small request. Each new version comes out via installer and i believe the installer is overwriting my ini file each time its run. This requires me to change the settings. Can i zip of just the binary files be posted? Or could the installer check for the .ini and avoid overwriting if it exists?
  6. #106
    lambosprit's Avatar
    Sep 2006
    UK
    vtcom. Your log file looks fine but I would still try the things I suggested. I may not have cracked the logging issue yet.
    Sonic. Did you set your debuglevel as I suggested before you did the test? This may have been what actually fixed it for you. As for the installer it does overwrite the .ini file. The problem is I'm adding to it quite regularily at the moment and dont want people to ignore it when they should be updating to the new one.
  7. #107
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by lambosprit View Post
    Dartman. I added the + command but its not in the skin. You will have to do this yourself. On this point does anyone know why * is used. I know about # and + but not star.
    Thank you very much for this great plugin and developing it, you are the man Now I have more questions, how to close mobilecall.skin when hangup? Is't possible to stop BSWrapper logging? Could/can you add option to get caller names from MobilePhone_PC text file? it would be nice to see caller name in mobilecall.skin.
    I don't reseive anything with mobilephone_dc and mobilephone_rc commands? Should I have different custom list than SC01?
    In some countries and operators you need star if you wanna make call transfer or some service like that.
    Keep up excellent work.
  8. #108
    Feb 2008
    im back with some good news.
    i uninstalled rr and the plugin and installed the latest rr
    (before i only had a old version with updates installed)
    and installed the plugin and all is well no more problems
    with the log coming out of hibernate
  9. #109
    Woodbridge, VA
    Blog Entries
    32
    actually no set the level. And i've still not seen the debug error. I believe its fixed.
  10. #110
    lambosprit's Avatar
    Sep 2006
    UK
    good. I'll take it as fixed then.
    I introduced a few bugs with the new saving of recieved and dialed calls. Working on fixing them now.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
