Thread: .net Bluetooth Mobilephone Plugin
  1. #1111
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    I used the regard in the .net 2 folder... used the exact command line in the readme file. The vc++ isn't even installing with the setup. I uninstalled the vc++ and ran mobilephone and told it to install the vc++ and it doesn't
  2. #1112
    Oct 2007
    Haledon, NJ
    I ended up going back to BlueSoleil 6 and copied over the directory from my old RR installation that I had saved and it works now...
  3. #1113
    Jul 2004
    Brazil
    @maidenfan: I was having the same problem. It was indeed the pin keypad popping up, if I didn't enter '1234 ENTER' (for example pressing cancel ou back) the numbers on mobilephone.skin wouldn't work. The funny thing is that the keypad pops up every single time I run RideRunner, and my phone is there all the time and connects with no problems.
    I didn't find where to configure the phone search timeout or how to disable that feature... also, there seems to be a problem with the battery and signal indicators, sometimes they show as "5", but sometimes they show as a corner ascii character or some weird sign... I wasn't able to make the jpg indicators work...
  4. #1114
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by crisr View Post
    The pin keypad should not popup by default. It should only happen when you set it in the ini file. I will check its off by default. I'll also check it got into the installer ini setup as I may have missed that.
  5. #1115
    Jul 2004
    Brazil
    It might be that... there is nothing in my ini file about the keypad. What is the option I should set?
  6. #1116
    lambosprit's Avatar
    Sep 2006
    UK
    I just checked and it defaults to enabled. Fixed it and in the installer also. Just trying to sort out the registring and vcredist problems before releasing.
    To disable the Alarm just add a section [ALARM] and AlarmEnabled=False to the ini file. The code is set with AlarmCode=1234
  7. #1117
    Jul 2004
    Brazil
    Quote Originally Posted by lambosprit View Post
    I tried adding the section and settings on MobilePhone.ini, but it didn't work...
    I am still in the testing phase, so I guess I will just wait for the next release then. Thanks!
  8. #1118
    lambosprit's Avatar
    Sep 2006
    UK
    I've updated the automart so it has the new installer which sets the ini correctly for the alarm stuff. I will try to fix the vcredist stuff as soon as possible.
    ---------- Post added at 02:31 PM ---------- Previous post was at 02:23 PM ----------
    For you you should change the AlarmEnabled to just Enabled. For anyone downloading the latest version it is AlarnEnabled
  9. #1119
    Jul 2004
    Brazil
    Thanks, but there seem to be more bugs. When I disable the alarm (disabling the pin keypad), as soon as it connects to the phone a dialog box pops up:
    Code:
    Mobile Phone
    System.NullReferenceException: Object reference not set to an instance of an object.
      at MobilePhone.MobilePhone.internal_connectBlue()
      at MobilePhone.MobilePhone.connectProcess()
    And then when I press any number on mobilephone.skin, RideRunner throws an exception screen:
    Code:
    Mobilephone.NET
    Exception
    at MobilePhone.RRExtension.ProcessCommand(String& CMD, Object& frm)
    If I keep the alarm enabled and I enter the code, everything works fine.
    I have tried downloading the updated installer from autoappmart and the behavior is the same.
  10. #1120
    lambosprit's Avatar
    Sep 2006
    UK
    I knew there'd be bugs....sorry about this but thanks for testing. I have fixed and posted a new version on app store
    ---------- Post added at 11:47 PM ---------- Previous post was at 10:11 PM ----------
    Quote Originally Posted by bratnetwork View Post
    I have a new installer that should detect the vc++ properly now. Fancy testing it?
    ---------- Post added at 11:49 PM ---------- Previous post was at 11:47 PM ----------
    Quote Originally Posted by Maidenfan View Post
    Hi guys, I have a slight problem with the plugin. It connects to my HTC Desire, I can recieve and make calls through contacts, and I can hear and speak through my PC. The only problem is that I can't dial through the on screen keypad. Numbers 0 to 9 and C(del) don't work, but the asterisk, hash and all the other buttons work. This is the popup I get
    SetErrorScr;Mobilephone.NET;Exception;System.NullR eferenceException:
    Object reference not set to an instance of an object.at MobilePhone.RRExtension.ProcessCommand(String& CMD, Object& frm);5
    I'm using Bluesoleil 8 and Carwing dynamic lite skin. I have .net 2.0 and VC runtime installed. Any ideas? I'm pretty sure the first time I ran it the numbers worked, I think there was a security thing use to come up and I had to enter 1234 on the keypad and it worked but now that doesn't come up anymore.
    Thanks.
    Thanks.
    This is a bug that happens when the alarm code is disabled. The new installer on the app mart fixes it so it should work now.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 09:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 08:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 10:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
